You can purchase new Remote Keyless Entry (RKE) transmitters from the dealer or you can order them online at the web sites listed below or several others. Your vehicle provides for programming the RKE transmitters without the use of a scan tool. Follow the instructions below.
2000 PONTIAC GRAND AM RKE TRANSMITTER PROGRAMMING
WITHOUT A SCAN TOOL
1. Close all vehicle doors. Remove key from ignition lock cylinder
NOTE: STEPS 2 AND 3 MUST BE COMPLETED WITHIN 25 SECONDS OF PRESSING THE DOOR UNLOCK SWITCH
2. Press and hold door UNLOCK switch. While holding UNLOCK switch, insert and remove the key in the ignition lock cylinder twice. Do not rotate the lock cylinder.
3. Insert the key a third time, leaving the key in the lock cylinder. Keep the lock cylinder in the LOCK position for the remainder of the procedure. Release the door UNLOCK switch. The chime will sound 3 times to signal that the programming/diagnostic mode is active.
4. Press and hold LOCK and UNLOCK
at the same time on the RKE transmitter for approximately 4 seconds. The chime will sound 2 times signaling that the transmitter has been programmed.
5. Repeat step 4 for each transmitter being programmed. (You can program up to 4 transmitters.)
6. To exit program mode, turn the key to the RUN position then back to the LOCK position and remove the key. Your transmitters should now work to lock and unlock your doors.
2000 Pontiac Grand Am Transponder (direct links)
- autotransponder.com
-keylessremotes.com
-ikeyless.com
