Question about Akai LCT2662 Television
Value Cap's in C19, C18 and C16 In power supply
Need to know what cap's go into C19, C18 and C16. In the LCT 2662 power supply. Thank you Can you Help Me
All three are 100uF 450WV 105 degree C
Posted on May 26, 2009
    Problem Solver:
  • 26 Answers
What are the locations for the capacitors on the LN26A330 power supply circuit board? What capacitors go in what location.
All the capacitors will have location numbers printed on the bottom and top of the circuit board next to them like C18 etc--the values of each will be printed on each capacitor--as well as one side of each will have a strip with - which means it is the negative side of the cap and the other side will be the + or positive side--look for ones that are puffed up on top---see attached photo of a new and good cap--the silver top with the creases should be perfectly flat.
Any bad ones should be visible to the naked eye.
Let me know what you find---if you find puffed up ones they will be marked also with a value like 1000 mfd (microfarad) at 10 v (means the cap is rated at 10 volts.)
If you find bad ones it is a good idea to replace with a higher voltage rated cap of the same value--it may present a small problem as the higher the voltage rating is the bigger the part will be.
The reason (if you have puffed up ones) they fail is because too low a voltage rated cap was used when the set was made---saves the company who makes the sets a few cents on each part.
Let me know if you have questions of need advice.
SD TECH
note the gray band on the left side--negative lead (each has 2 leads) is indicated that way.
Feb 12, 2010 | Samsung LN26A330J LCD TV
Re: Onkyo DV-CP500 DVD player stuck in standby mode (by 7 users)
Hi Yes, sorry just saw this comment. Swap out C7, C17 and C18 in the power supply. Also I would check if you are getting 9Volts to the motor control IC's pin 7 coming off of C005 on the Mechanism Board which is under the unit. The hole for the C005 cap was drilled into a very narrow section of the circuit board and has marginal connection at best.. mine stopped working because of this 6 months after I fixed the power supply.
Oct 23, 2008 | Onkyo DV-CP500 Multi-disc DVD Player
Planar pdp42bk problem
change the c97,c19 and c16 caps below is where I got mines.
Got it from a site called digi-key.com their phone # is 1800-344-4539. The part #s are EF6225-ND you need 1of these, and E6105-ND you need 2 of these, the cost is $16 for all. Let me know how it went.
Aug 27, 2008 | Planar PDP-42BK 42 in. Plasma HDTV
Help - please explain
these are capacitors. The c18 and c36 are the location of the capacitors on the power supply board. The 2200uf is the capacitance of the capacitor and the 10v in the voltage the capacitor can handle. You should be able to purchase these at radio shack or most electronic supply stores. However to replace them you will need to know how to desolder the old caps and resolder in the new ones. I just got through repairing one of these units and to extend the life I used a higher voltage value cap. If you need anymore help or can't find the caps feel free to contact me philbertduncan@yahoo.com
Jul 01, 2008 | LG Electronics LRM-519 Digital Media...
Planar PDP-42BK 42" Green Light just Flashes no picture.
Email this guy @ exoticimports360@yahoo.com, he has planar parts to sell he might have a power board
or change the c97,c19 and c16 caps below is where I got mines.
Got it from a site called digi-key.com their phone # is 1800-344-4539. The part #s are EF6225-ND you need 1of these and E6105-ND you need 2 of these, the cost is $16 for all. Let me know how it went.
May 15, 2008 | Planar PDP-42BK 42 in. Plasma HDTV
I have the same problem with my Akia LCT 2662 Television
Did you fix this yet?Please let me know.Thank You very much!
Tyler
May 01, 2008 | Akai LCT2662 Television
Akai LCT 2662 will not turn on
I'm surprise to see the repair shop telling you there nothing they can do.
The power supply can be fix if you take the time to troubleshoot it. However this is not a DIY project.
The failure is in the capacitors that are bulging out of the top or bottom. Quite visibly defective.
4- 3300uf @35V
8- 2200uf @25V
7- 1000uf @10V
1- 1000uf @6.3V
3- 100uf @25V
Feb 27, 2008 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
DVR-220-S Capacitor C19
I just purchased the following capacitors from Mouser.com. I bought 2 of each and with shipping it cost me about $10:
C17: 1800uF, 25V, D 15mm L 20mm - 647-UPW1E182MHD6
C19: 3300uF, 10V, D 12mm L 25mm - 647-UHM1A332MHD
C23: 1000uF, 10V, D 10mm L 17mm - 647-UPW1A102MPD
I could not find a replacement for the C24. My C19 blew and after replacing it the DVR came back to life.
Nov 05, 2007 | Pioneer DVR-220 DVD Recorder
Bose lifestyle 12 music center display inop
My display has not been working for years. Replaced c17 cap wich was 33uF 63 volts on lower pcb board( only one on system) . Old cap was good so this was not the problem. Replaced c16 wich was 100uF 25 volts with a 100uF 63volts. Display works, old cap read low. Both c17, and c16 are located on the lower left hand corner of the larger pcb looking from the front of the unit. Hope this helps.
Aug 16, 2007 | Bose Lifestyle 12 System
Planar PDP42BK Plasma TV
It is the power supply. Replace the C97, C19, and C16 Capacitors with 2.2 uF ones.
Jul 10, 2007 | Planar PDP-42BK 42 in. Plasma HDTV
Akai LCT2662 Television Logo
204 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
