Question about Karcher K 5.85 M Electric Pressure Washer
Hose replacement or7
How do i replace the hose
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
I fixed mine works good easy too watch my video step by step i put it on youtube
http://www.youtube.com/watch?v=UFXSLOBL0Mg
Posted on Oct 18, 2013
I have an upright GE Freezer, and outside door panel usually says 6 or 7, to the high temp light is on, and the led screen us blank. Everything in the freezer is frozen solid. Should I be worried?
The 6 or7 may be a setting number or a degree readout, which is a little on the warm side, should be around a -10 to-15.
Consult your users manual for details ,.Does not sound like an emergency, but keep monitoring it'
https://www.repairclinic.com/RepairHelp/Freezer-Repair-Help
This site may be of help.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Dec 08, 2017 | GE Freezers
My pu starts fine in the morning but after getting up to operating temp it will not start.wait 6 or7 hours and it will start,why?
This sounds like the ignition control module or related electronic items are overheating. Have you been able to check and see if it has spark when it's hot and wont start?
Nov 09, 2015 | Cars & Trucks
I need to know the correct position of the rear wheel assembly and spring to istall in a electrolux renaissance power nozzle model#n106a in the base.Is this power nozzle refered to as PN5,6 or7? I also...
any Aerus deler will have the plate go to aerusonline.com they have dealer listing in your area. Beware they will try to sell you a new one. Part should be around $10 you may want them to put that axle and spring and cover on it is hard to do. A hint though for a DYI the spring barb goes in a little square hole in the weel channel. Good luck .
Apr 03, 2014 | Electrolux Guardian Bagged Canister Vacuum
Fan keeps running
the safety built in is when the sequencer goes bad it turns on the fan so it doesnt create a fire. replace sequencer. to make sure check amps if over 6 or7 amps sequencer is faulty
Jun 08, 2013 | Goodman Heating & Cooling
Replace pressure house on 1985 mustang
For procedure to replace power steering hoses,click the link below :----http://technoanswers.blogspot.in/2012/02/how-to-replace-power-steering-pressure.html
----------Also its advisable to go through this additional help links.Click the link to go through the procedures:----How to Remove Power steering Pressure Hose?
http://schematicsdiagram.blogspot.com/2011/12/how-to-remove-power-steering-pressure.html
Vacuum hose Routing diagram?
http://repairhelpcenter.blogspot.com/2011/11/vacuum-hose-routing-diagram-for-acura.html
Ac line and evaporator drain hose?
http://repairhelpcenter.blogspot.com/2011/10/ac-line-and-evaporator-drain-hose-on.html
How to disconnect the hose form the Evap Canister?
http://schematicsdiagram.blogspot.com/2011/12/how-to-disconnect-hose-form-evap.html
Vacuum Hose Routing Diagram For Throttle Body?
http://schematicsdiagram.blogspot.com/2011/12/vacuum-hose-routing-diagram-for-1995.html
How exactly the Vehicles A/C Hose works?
http://repairhelpcenter.blogspot.com/2011/11/how-exactly-vehicles-ac-hose-works.html
HOW TO REPLACE AN UPPER RADIATOR HOSE
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-upper-radiator-hose.html
HOW TO REPLACE A LOWER RADIATOR HOSE
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-lower-radiator-hose.html
Fail smog test due to gas filter hose?
http://repairhelpcenter.blogspot.com/2012/01/fail-smog-test-due-to-gas-filter-hose.html
EGR Hoses melting?
http://repairhelpcenter.blogspot.com/2011/12/egr-hoses-melting.html
EVAP connecting hose to PCV valve Collapse?
http://schematicsdiagram.blogspot.com/2012/01/evap-connecting-hose-to-pcv-valve.html
--------How to replace Power steering rack and pinion gear? http://technoanswers.blogspot.in/2012/02/how-to-replace-power-steering-rack-and.html
--------How to replace Power Steering Pump?
Also bleeding:
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-power-steering-pump-on.html
How to replace Steering Linkage? http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-steering-linkage-on.html
-----Car steering wheel makes noise?
http://schematicsdiagram.blogspot.com/2011/12/car-steering-wheel-makes-noise.html
Car makes clicking or tapping sound? http://schematicsdiagram.blogspot.com/2011/12/car-makes-clicking-or-tapping-sound.html
---------This will help.Thanks.
Feb 16, 2012 | 1985 Ford Mustang
Laptop will not finish installing windows xp / vista or7 but it does finish installing windows me and no drivers work it stops after windows logo
Have you done a full format (not quick format) of the Harddrive? all previous versions of software should be removed so you start with a clean slate so to speak
Nov 30, 2010 | Dell Inspiron 6400 Notebook
Error c446
Hi how are you this is jack hear in pk ....(jack_pak@hotmail.com)
First Step copier ON 0+8 press 400 press start Baton.
copier show one value ...5or 6 or7.. any xyz then you press 0 and enter... copier off... simple copier ON....
Thanks
Best Regards,
Aug 06, 2010 | Toshiba E-Studio 3511 Color Copier
My sound card is not install
setup windows black or7 version soundcard will be install automatially
Apr 09, 2010 | Intel Pentium 4 1.7G, 1.7 GHz...
Pressure hose worn
ebay do plenty of replacement hose for the domestic and proffessional machines.
Jul 18, 2009 | Garden
Karcher K 5.85 M Electric Pressure Washer Logo
48 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
