Question about Garmin zumo 550 GPS Receiver
I cannot get audio at all for my garmin zumo 550. all it says onscrean is to connect zumo to holder which i have done or to connect to bluetooth headset.i think i may have a problem with my power lead but would this affect audio?
  • roobzmurray Apr 20, 2009
    do i need a power lead to power up mt base unit as i only have 12v mini usb adaptor
  • 469 Answers
The 550 relies on the car base for audio as it has no speaker. If the base is not powered up it will not amplify the sound out of the GPS unit, Check the in-line fuse on the power cord, it is usually located in the tip of the cigarette lighter adapter. twist off the tip and this should expose a fuse.
HAve you tried connecting to it with a bluetooth headset, this should work regardless of whether or not it is on the base.
Hope this is of some help.
Ed
Posted on Apr 20, 2009
  • Ed
    Ed Apr 20, 2009
    I have included a link to the garmin website, it will show you what you should have received with the unit. The list shows 2 power cables.
    Have a look at the list and you can determine if you are missing something.
    https://buy.garmin.com/shop/shop.do?cID=...
    Hope this is of some assistance.
    Ed
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,001 Answers
  • Small and Simple: Its outline feels like a mini iPhone 6, petite and charming, it doesn't need much space in your car; Simple design, easy operation, you can get away from complicated operation of some other Bluetooth receivers.
Amazon com Charm sonic Wireless CSR4 0 Portable Bluetooth Receiver...
Posted on Dec 16, 2016
How to fit zumo 550 to honda goldwing 1800a6
What I did was got an aftermarket holder for the GPS and plugged it
into a cigarette lighter holder, commonly available at auto parts stores, that I wired to the battery .
Aug 03, 2014 | Garmin zumo 550 Motorcycle GPS Unit
How can I my 2004 Honda Goldwing mic to work with my Garmin Zumo 665 to answer my cellphone? The phone bluetooth connection works fine with the Garmin in my car, but my Honda mic does not work through the...
The microphone input from the Zumo 665 motorcycle mounting cradle is the smaller 2.5mm jack.
Be sure to use this one as some microphone jacks will require a 3.5mm to 2.5mm adapter.
The audio output is the 3.5mm jack.
Be sure not to confuse the two.
It may be necessary to have a custom 5 or 7 pin DIN adapter made to connect between the GW audio system and the Zumo.
It would be best to consult with your local Honda GoldWing dealer for more information on interfacing the GW audio system.
Oct 07, 2011 | Garmin zumo 665 GPS Receiver
Bluetooth connection for phone is very jumbled. Both with blackberry and iphone
try updating the bluetooth software via the web updater for garmin
Apr 15, 2010 | Garmin zumo 550 GPS Receiver
Crackling noise then no audio at all while on motorcycle
In my opinion I suspect either a bad internal connection to the built in speaker or a faulty Bluetooth connection. Does the problem occur on both the helmet and speaker? If so, then the unit has likley had a circuit malfunction. If the helmet works fine but not the speaker, then I'd guess a broken or damaged speaker and/or speaker wire. Crackling noise is typical for broken wires or lose connections. Any decent TV repair place would be able to sort through it about 10 mintues before you have to return to for factory repair.
Sean
May 24, 2009 | Garmin zumo 550 GPS Receiver
Can't end Bluetooth phone call with Zumo 550
I have a motorola phone, and it's fine.
I have paired the phone to the zumo, and the phone is set to connect to the zumo automatically.
Check the phone is set up this way, and all should be well.
Hope this helps.
Dec 24, 2008 | Garmin zumo 550 GPS Receiver
Zumo won't power from either cradle
Connector block at the base is stuffed. Needs to be replaced.
Aug 15, 2008 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 bluetooth pairnig problem
Have you connected the device to the computer and run webupdater? Mine showed up with a bluetooth firmware upgrade. Bluetooth works fine, however, lost the functionality of the phonebook after the update. Sometimes you win sometimes you loose
Mar 28, 2008 | Garmin zumo 550 GPS Receiver
Zumo 550 - Failure of call functionality on Bluetooth
Try the garmin webupdater with the unit connected to the computer to see if your bluetooth firmware is the latest. Beware however, I lost phonebook functionality!
Mar 04, 2008 | Garmin zumo 550 GPS Receiver
Connection problem between a nokia n95 8gb and zumo 550
I have recently purchased a Zumo 550 and successfully copied across selected phone book entries from a Nokia N95 without the need to use any additional apps:-
1) Assuming the N95 and Zumo are paired via BlueTooth
2) In N95 Contacts - use 'Mark' / 'Mark All' as necessary to select the contact entries you wish to transfer to the Zumo 550
3) In N95 Contacts - select 'Options' then 'Send Business Card' then 'Via Bluetooth'
4) Select the Zumo 550 device from the list of paired Bluetooth devices
5) Contact data is transferred from N95 phonebook to Zumo 550 phonebook
Interestingly, Garmin don't seem to list the Nokia N95 as being a supported device on their website, but the above process worked for me!!
Feb 15, 2008 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 GPS Receiver Logo
347 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
