Question about Samsung SAM1100 LCD Remote Control
Button Problems When I began programming my remote, some of the buttons no longer operated correctly. Specifically, when I tried programming the VCR function button, the LCD display no longer displays VCR, but displays TV. When I tried doing the same for the Audio, and the Audio button now displays TV on the LCD panel. Is there any way to reverse or fix this?
  • Philomancer Sep 24, 2007
    I've looked on my remote and the instruction manual, and all I can tell is that I have an Axession Samsung (America Inc.) Learning Universal Remote with LCD, SAM 1100. Given that I am posting in the SAM 1100 LCD remote Control section of the Samsung forums, I assumed this was already known. If the model number is not included in the information I have provided, could you please tell me where I might find it?
    Novelist:
    Scholar:
  • 149 Answers
What is the model# for your remote? It's hard to trouble shoot the error with out checking the information on the correct remote. Let me know so we can check into it further for yah!
Posted on Sep 24, 2007
SOURCE:
I need code(s) for my DVD Video, Model #: NB093 remote control to program my Philips DVD Player/VCR, Model #: DVP3345V/17. Can you please help me? I would greatly appreciate it. Here is a picture of it.
http://remotecodelist.com/remotes/magnavox/magnavox.htm lists the code for your device as possibly being 1000, 1001, 1002, 1003, 1004, or 1005. Of course, you also have the option of using the remote controller's "Code Search" button. 25300580-iv4burzhkawezvl2jbah1xae-2-0.jpg With Codes:
Turn on the DVD/VCR unit directly. Continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Enter the four-digit code (1000, 1001, 1002, 1003, 1004, or 1005) for the DVD/VCR unit. The remote controller's light should go off. Press the remote controller's power button, & when the DVD/VCR unit turns off, then you will know that the remote controller has been correctly programmed.
Without Codes:
With the DVD/VCR unit on, continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Continue to tap the remote controller's UP or DOWN channel button ONLY UNTIL the DVD/VCR unit responds. Then, press the power button on the remote controller once the channel has changed. If the DVD/VCR unit shuts off, then press the power button again to turn it back on. If the DVD/VCR unit turns on, then the remote controller has been correctly programmed. Otherwise, repeat this whole process until the remote controller is correctly programmed.
Nov 29, 2014 | Televison & Video
Remote menu button not working
Sometimes you can enter a code that will work nearly all the buttons, but is not the correct code for your DVD player. You should try other codes. But sometimes a universal remote will NOT work every function.
Dec 22, 2012 | Toshiba SD-V392 DVD Player/VCR
My 1.5 IR Dish remote has all of a sudden stopped working with our Sanyo tv. I've changed the batteries. When I push the power button it will only light up the VCR button if anything at all. Our other...
sandyannsamp
If the VCR button lights up when you press the Power button, you are not in the correct mode to operate the TV. If the remote is programmed correctly, when you are in SAT mode, you can press the large RED button to turn your receiver off/on. The RED TV button will turn your TV off/on. I have provided links to program your remote to your TV again. I have also provided codes for your Sanyo TV.
Instructions to program your remote to your TV (begin with step 6):
http://www.dishnetwork.com/SupportSection/remote-setup
Here are the TV codes: 590, 683, 589, 542, 652
I hope this helps.
Ray Calo
DISH Network
Nov 18, 2010 | DISH Network IR Remote Control
My GE Universal remote no longer works. The battery is fine but the signal is no longer working on my TV. I would like to try to reset the remote to my TV.
Please try to programme your GE remote to your TV
Manual code entry
1.Turn on your television or other electronic component that you want to program the remote control for.
2.Hold down the "Code Search" or "Setup" button until the LED indicator light turns on.
3.Hit the button for the component that you are programming (TV,DVD VCR, etc.). The LED light should flicker and stay on.
4.Enter the 3-digit or 4-digit code that corresponds to the TV or device that you're operating.The LED light should go off if the code is valid, but will flash if it is not. Try other codes you have.
5.Try turning the television or other programmed component off to ensure that the remote works properly, once the light has gone off.
Auto configuration
3.Hit the button for the component that you are programming (TV, DVD, VCR, etc.). The LED light should flicker and stay on.
4. Press and release the "Power" until the television or other component turns off while waiting at least 2 seconds between each press.
5.Press "Enter" or "Save" once the remote has effectively turned the power off. The LED light will shut off and the remote will now operate the device.
You can get your codes from below website
http://www.jascoproducts.com/support/universal-remote-codes.asp
Thanx
Aug 04, 2010 | GE RM24930 Remote Control
I have this RCA remote and I misplaced the guidebook.
You must first find out why the remote control is not working properly. These remote controls have been having problems with new batteries. The battery holder on the positive side need to be adjusted out to make sure its making contact with the batteries. This may be the reason the remote control is not working. After you find the problem with the functioning of the remote control you can go to the RCA customer support website http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=1769&p_created=1209688350&p_sid=6-sdxLAj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9ODE4LDgxOCZwX3Byb2RzPTE1OCZwX2NhdHM9MCZwX3B2PTEuMTU4JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1yY2Egc3lzdGVtIDUgcmVtb3RlIGNvbnRyb2w*&p_li=&p_topview=1 find the codes for the components you want to use with the remote control. Use the codes to make the remote operational . This should be all you have to, if the remote control is working properly. If you cannot get the remote control to work properly, you can call the RCA customer support at this telephone number 1-800-645-4994. Give them the model number of the remote control and ask them for assistance with the problem. I hope this information help you with the problem you are having with your remote control. Thank you for using FixYa and have a nice day!
Apr 07, 2009 | RCA DIRECTV Satellite Remote Control
Cannot program dish remote to operate tv
Please follow the steps below to program your remote control to equipment other then your DISH receiver:
Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
2. Press the numbers 5-0-0 on the remote control.
3. Press the Pound (#) button on the remote.
4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
5. Press and release the Power button on the remote control.
6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
8. To verify the code works try several different functions for that equipment.
We cannot guarantee our remotes will work all other devices. If this does not correct the issue, unfortunately our remote will not work for that device. We apologize for any inconvenience this may cause.
Let me know if I acn assist further. Please rate this solution.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Mar 02, 2009 | Philips Magnavox 42MF521D/37 Television
Remote control not working
have you program first the remote control, to work on your TV..??
Heres a few instructions how to programmed your remote..
  1. Test your remote control. To find out whether your remote control can operate the component without programming, turn on the component such as a VCR and press the corresponding MODE button (VCR) on the remote control, while illuminating on the selected component. Test the POWER button to see if the component responds properly. If not, the remote requires programming to operate the device.
  2. Turn on the component to be programmed, then press the corresponding MODE button on the remote control.
  3. Press the MENU and MUTE buttons simultaneously for 2 seconds, the button selected component lights on the remote control. If you don't press any button for 20 seconds, the button selected component will turn off on the remote control. At a moment, you have to repeat from step 2.
  4. Enter a code number using the number buttons on the remote. When pressing the button, the light is blinked at a time. Programming code numbers for the corresponding component can be found on the following pages. Again, if the code is correct, the device will turn off.
  5. Press the MENU button to store the code. After blinking twice, this code is stored.
  6. Test the remote control functions to see if the component responds properly. If not, repeat from step 2.
Try 001 as the PCode.
Thanks..
May 08, 2008 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
Sylvania 6313CB 13" TV/VCR replacemnt remote
We have a Sylvania 6313CB TV/VCR combo.  I bought a universal remote and the code would not work when I tried to program it to the "TV" button using all those possible codes listed in the books.  So, on the universal remote, there was a button named "VCR" and when I programmed in the code "0000" all worked.  This was a $6.00 universal remote named "One For All"  we bought at the Big Lots store.
Specifically, here is what I did:
Turned TV on Pushed the "VCR" button and light blinked once Pushed and held the "set" button until it blinked twice Released the "set" button and entered the numbers "0000" Pushed the on/off button and it worked including volume, channel up/down and channel change by entering the channel number.
Hope this works for you too.
Jan 14, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
Samsung SAM1100 LCD Remote Control Logo
117 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
