Question about Olympus Camedia C-50 Zoom Digital Camera
Olympus 795 sw lens moisture
There is a watermark in the lcd or lens, its there i took pictures, how can i remove it?
    President:
  • 919 Answers
Exterior:
• Wipe gently with a soft cloth. If the camera is very dirty, soak the cloth in mild soapy water and wring well.
Wipe the camera with the damp cloth and then dry it with a dry cloth. If you have used the camera at the beach, use a cloth soaked in clean water and wrung well.
• If any dirt, dust, sand, or other foreign material adheres to the periphery of the lens cover after use, or the lens cover does not move smoothly, wash the camera using the method described on P. 66.
Monitor:
Lens:
• Blow dust off the lens with a commercial blower, then wipe gently with a lens cleaner.
Battery/Charger:
• Wipe gently with a soft, dry cloth.
Note
• Do not use strong solvents such as benzene or alcohol, or chemically treated cloth.
• Mold may form on the lens surface if the lens is left dirty.
Posted on Apr 22, 2009
My Olympus 1050 SW looks like it might have a little water inside the camera. The lens is foggy. I didn't take it very deep the last time I was in the water with it, but I did store it in a cooler and...
You can TRY and dry out the camera, but I can pretty much guarantee you that there is corrosion inside and it will eventually fail if it hasn't done so already. The Olympus Stylus Tough cameras are not very tough or waterproof unfortunately. I have seen dozens of them with smashed LCD windows or that have leaked water.
Don't buy a waterproof camera, cause they aren't waterproof. Buy an underwater case and put your camera in that.
To try and dry out the camera, some people suggest putting it in a ziplock back with rice to pull out the moisture, it's not a bad thing to try. The fog in the lens MIGHT go away, but it will most likely leave spots or a big ring which will show up on all your pictures.
Your camera is most likely a goner, sorry to say.
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 25, 2011 | Olympus Stylus / mju 1050 SW Digital...
Olympus Stylus 850 SW LCD screen will not turn on. The camera itself will turn on and take pictures but i must do it blindly. i cannot see the pictures nor can i see through the lens.
If you camera is built with a viewfinder there is usually an option to de-activate the lcd screen. Usually if you press the display or play button on the back it will re-activate. Also try to access any of the menu's by pressing the menu button. If this does not work also then the LCD is probably bad or not making connection. You would have to find a local service center for repairs. www.phototech.com is the local service center in NYC or you would have to send directly to Olympus in Woodbury Long Island.
Good Luck
Paul
Jul 05, 2011 | Olympus Stylus 850SW Digital Camera
After taking the camera into the water, it won't stay on.
Remove the battery and then immerse both the camera and the phone into a pound of dry uncooked rice for at least three days. The dry rice will **** all of the moisture out. After three days put in the battery and try it. If it works. problem solved. If not, remove the battery and stick it all back into the rice for a few more days.
Nov 18, 2009 | Olympus Stylus 770 SW Digital Camera
Moisture on the lens
If moisture is in the lens, it is inside the camera.
Best to remove the battery or batteries and let it dry out in a warm area for a few days. This may not remove the moisture like taking the camera case off. This may be a job you may not want to tackle.
Corrosion will eventually cause problems within the camera.
It may be that the moisture inside may already have damaged some parts or components or caused a short.
Oct 04, 2009 | Olympus ? 850 SW Digital Camera
770SW Olympus needs a factory reset, lens stuck open
Contact Olympus for the factory reset code.
Sep 01, 2017 | Cameras
Olympus 770 SW Digital Camera
I think you have to wipe the lens from the inside. humidity must have caused that cloud. take out the lens module and wipe it with a lint free cloth
Jul 19, 2008 | Olympus Stylus 770 SW Digital Camera
Black spot on pictures, and lcd viewing
Hey cj17,
Since this spot is both on your lcd and your pictures the lcd is most likely not to blame. This spot is probably caused either by dirt on the lens or the sensor, or it could be caused by a dead pixels on the sensor. You can try cleaning the lens, and if this doesn't work you should have it looked at by an authorized service technician.
Sincerely,
Allan
Go Ahead. Use Us.
Apr 28, 2008 | Olympus Stylus 720 SW Digital Camera
Olympus mju 795 SW - English Manual???
Not much help here, just to say that my U 795 SW came with a multi-language manual (incl English).
you can try this manual on the Olympus site at it seems to be the closest one to the model we have bought...
http://www.olympus.co.uk/consumer/208_manuals.cfm?prodID=P_N2915892
Jan 16, 2008 | Olympus Stylus 770 SW Digital Camera
Lens stuck
I had an Olympus 725 which I bought in Dec 06, this xmas I went home to see my family in Ireland (I live in Australia) and stopped in Thailand on the way back, the camera broke when I was snorkeling, 4 days out of Warranty!!!! Same issues as you guys had. When I got back on the 16th Jan I brought it back to the shop, the guy told me my best bet would be to get onto Olympus directly and explain the situation. I did and they told me to send it in. I wrote a letter of complaint and sent it in with the camera (I also had problems with my XD corrupting itself, and I lost a lot of pic's). Yesterday when I came in from work there was note in my letterbox from Australia airmail saying they had tried to deliver a package to me but there was nobody home. Just found out awhile ago it's a new camera, a 795:) so I'm well happy. Will buy an extended warranty aswell tho, just in case. Sooo my advice is to deal directly with Olympus and not with any shops or agents.
Dec 16, 2007 | Olympus Stylus 770 SW Digital Camera
Lens
The very delicate and fragile lens mechanism has been skewed by that knock. Try Olympus for a repair price but I suspect you will be buying that new camera once you see the price
Sep 30, 2007 | Olympus Stylus 720 SW Digital Camera
Olympus Camedia C-50 Zoom Digital Camera Logo
85 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
