Question about Kenmore Dryers
How do you replace a broken belt on the Kenmore 80 series dryer?
  • richard_bent Apr 20, 2009
    Many thanks for your reply. I think we are close, but, I do not see how the front of the dryer comes off. It is all one piece, sort of a metal box. There doesnt seem to be any way to get to the motor pulley. Still confused. Are there any manuals available with diagrams? It would help is there were illustrations that I could looke at.
  • 547 Answers
The belt is acessable from the front of the dryer you can remove it by popping the top up then taking off the front of the dryer off the drum will come out now place the belt around the drum and put back in now the belt goes around the drum the motor pulley and under the tentioner pulley replace front and top and you are good to go thank you
Please rate me
Posted on Apr 20, 2009
How do I take the top off of a Kenmore 80 Series?
You remove the back panel that is how your get to everything. once the back panel is removed you will be able to put the belt and the idler pulley on. Please rate
May 24, 2010 | Kenmore 64852 Electric Dryer
Kenmore 80 series dryer. was working fine, now
Hello. When ever a dryer will not turn the first thing to suspect is a broken dryer belt. lift the top on your machine and visually inspect the belt. If it is broken, it is easy to replace. Joe
Apr 21, 2010 | Dryers
Kenmore series 80 dryer . Drum does not spin, even when empty.
Good day,
If runs and heats, then the most probable cause is a broken belt.
Not hard to change. Below is a tutorial on how.
The Kenmore line is manufactured by Whirlpool.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Thank you for using FixYa
Dec 19, 2009 | Kenmore Dryers
I have a kenmore 80 series dryer and when i try to start it it makes a loud noise but doesnt start i have replaced the switch and still have the same problem
have you checked the drive belt that turns the dryer drum it may be broken and need replacing can you hear the motor..does it sound like it is working if it is and drum not turning this is probably your problem
Dec 15, 2009 | Kenmore Dryers
the buzzing noise sounds like the motor is turning,so then your belt is broken.take apart inspect clean and replace worn parts
Dec 31, 2008 | Kenmore 63942 Dryer
Dryer wont turn
Yes, it will save you alot of money and work just fine. You will have to shut off the dryer, turn off the gas and/or electric(disconnect it to be sure it is power free). Look at dryer carefully as you may be able to access the belt from the lower front. The belt is easily available at Sears Parts Stores. Do not use it until fixed as it might overheat!
Dec 09, 2008 | Kenmore 63942 Dryer
Kenmore 80 Series Heavy Duty Dryer won't work
hi thanks for the question the belt has probably broken there should be a bottom panel use screw driver to pry the front on each side pry outwards remove panel now you should see a broken belt replace thanks the appliance dod
Sep 25, 2008 | Kenmore 63942 Dryer
Broken Kenmore dryer 80 series
Hi Dave. The problem is the drive belt. They aren't that difficult to replace and can be done with just a few tools. I'll need the exact model number off of the dryer to explain how to gain access to it, though. The number can be found behind the door on the cabinet (it'll start with 3 digits then a decimal point then more digits, like this; xxx.xxxxxxx)
The part number for the repair is 4392065. This is a complete maintenance kit for your dryer. I recommend it because since your belt wore out, there are other parts that should be taken care of at the same time. Here's a picture and a place to order if you can't find it locally.
Oct 18, 2007 | Dryers
Dryers Logo
379 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
