Question about Kenmore 42822 Front Load Washer
Have to replace motor coupler. Need instructions.
I have to replace the motor coupler 285753A in my kenmore 11082984120. Are there instructions I can access.
  • 3 more comments
  • scottnich289 Apr 20, 2009
    I actually have the old wig wag system. Do you have instructions for that?
    Ok, I'll go with the direct drive solution. Does this model have belt. Ifound what looked like pieces of a belt on the bottom?
    Thanks alot
  • scottnich289 Apr 21, 2009
    I fixed the washing machine. Thanks for your help.
    I didn't know there was different ratings
  • 5,911 Answers
Here ya go. Click on the following link:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
Please follow the advice in the link provided. The part number is included if you need it. If you have questions, please let me know. I hope you find this information helpful.
Posted on Apr 20, 2009
  • 2 more comments
  • Jeff Rockwell
    Jeff Rockwell Apr 20, 2009
    Are you sure? The model number you provided is for a direct-drive Kenmore top loader with the exact motor coupling part number you provided. I just looked it up and confirmed it. That's what my instructions were for - a Direct Drive.
  • Jeff Rockwell
    No...the model you have listed does not have a belt. Hence, the name "direct drive". The motor coupling takes the place of a drive belt and directly couples the drive motor to the transmission. The pieces you are taking about about could be the rubber bushing of the coupler if it sheared apart.
  • Jeff Rockwell
    Jeff Rockwell Apr 21, 2009
    Congratulations on repairing your washer. I'm glad I was able to assist you. If my advice helped guide you to a successful repair, why only the "helpful" rating?
  • Jeff Rockwell
    I wasn't trying to be petty. I was just wondering if there was something I failed to provide you answers with. If you need any assistance with your washer in the future, please keep me in mind. Good luck to you and I hope you get some good years out of the repairs you made. Thank you.
My washer doesnt twist black and force
sounds like you have a belt broken that moves the drum...replace and should be ok...
Nov 27, 2014 | Kenmore 2942 400 3.2 cu. ft. Top Load...
Model 110 wont spin, just click click click.
sounds like the motor coupling....................YouTube - Washing Machine Drive Motor Coupler Replacement (part #285753A)
Mar 05, 2011 | Kenmore 22642 Top Load Washer
Washer won't aggitage or spin
Kenmore washers use a coupler to attach the motor shaft to the transmission. The coupler is designed to shear off to protect the motor.Often the repair is to replace the coupler (sears part # 285753A, $18.50) If you flip the washer over you can visually verify that the coupler is broken.Disconnect the hoses to the water pump by removing the hose clamp). Then remove the two small screws holding two clips, called retainers that attach the motor to the transmission. the two assemblies will separate at the coupler.
Jan 11, 2010 | Kenmore Washing Machines
Drum will not spin in any mode. Pump works but get a grinding with any spin cycle
replace your drive coupler
tip unit back
you will see the pump
attached is the motor
behind the motor is your coupler
part number 285753a
take the pump off by 2 clips
take the motor off with 2 clips and 2 screws or just the clips
let me know if you need more instructions
Jan 08, 2010 | Kenmore 24032\24036 Top Load Washer
I need to replace the motor drive coupler 285753A in my top loading kenmore washer -- can you give me instructions
This is a relatively easy fix for the basic Kenmore / Whirlpool washers.
Please see GURU JSROCK516 Description of how to remove cabinet and access the transmission.
http://www.fixya.com/support/r699497-replacing_gearcase
Follow the instructions for removing the cabinet and pulling the pump, motor and motor mounting plate.
The coupler has two plastic pieces with three prongs each. In between is the rubber coupler with six holes.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Sep 24, 2009 | Kenmore Washing Machines
My kenmore model # 11020802990 stoped spinning a
Check the motor coupling. Remove the cabinet, pump and motor and see if the coupling (designed to break if the transmission or motor jams) is broken. Check the Sears site
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=11020802990
for part number :
pd_0026_110_285753a?$pddetailsth$ #13 on diagram Coupling, motor Number:3364003Substitution:285753A $18.50 In stock Quantity Add To Cart
Manufacturer authorized substitution: 285753A may differ in appearance, but is a functional equivalent to prior parts including 3364003. If it isn't the coupler, it most likely is the motor.
Sep 14, 2009 | Kenmore 24902 Top Load Washer
My Kenmore washing machine Model #11082984120 will
it IS driven by belts you need to either replace the belts youself or call in a serviceman.
Aug 01, 2009 | Washing Machines
Kenmore 70 series washer, clothes are soaking wet after spinning
If it fill and motor runs but will not agitate it likely is the coupler. If you have the cabinet off and see the motor here is what you do.
there are 2 metal straps that attach the motor to the transmission. take the screws out that hold the straps on and pop the straps out of their slots. the motor will then come off and the coupler is between the motor and transmission. One section goes on motor shaft and one on the transmission shaft with rubber bushing in between.
Coupler part number is 285753A
May 16, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Mid-cycle my washing machine stopped working.
Could be one of three issues, timer, capacitor, or the most like canidate the motor assm. Usually 90% of the time, its that motor. Those motors are pretty expensive (part number 389248) and you need to replace motor coupler (part number 285753A) when you change it.
Apr 20, 2009 | Kenmore 22942 Top Load Washer
Kenmore 20722 won't spin
285753a is the part number for the motor coupler no problem hope it helps
Mar 21, 2007 | Kenmore 20722
Kenmore 42822 Front Load Washer Logo
171 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
