Question about Samsung CLP-500 Laser Printer
Horizontal lines I get 2 horizontal lines when I print something, even when i print a blank page it shows up. And the lines seem to move downwards on the page every time i print something new. I've had my clp-500 cleaned a week ago, but no change. The guy i brought it to said the hardware looks fine, he said it could be a software problem. Any help would be appreciated, thank you.
  • 6 more comments
  • stefvassilou Apr 21, 2009
    1.5" and yes it's the same distance every time.
    when i print a page, the lines include all the colors. From the top, black, blue, magenta and yellow, in that order. They're not solid lines though, they are a bit wavy.
    do you want me to fax you a sample?
  • stefvassilou Apr 22, 2009
    Any thoughts?
    could it be that the transfer belt is not cleaning itself off after a print, and the lines remain on the transfer belt? Another thing i didn't mention is that the printer has been sitting for about two years in storage.
  • stefvassilou Apr 27, 2009
    It ended up being the drum, with closer inspection the drum was scratched, two lines across, exact same distance. No idea how that happened, very strange. Thanks for the help, I appreciate it.
  • adi May 11, 2010
    can you do a test page for each of the 4 colors, and tell me if its doing it on all the colors?
  • adi May 11, 2010
    how many inches are the lines apart?
    is it always the same distance?
  • 526 Answers
1.5" comes to about 38 mm, the closest thing I found to that mark is the T2 roller needs replacing.
Posted on Apr 22, 2009
  • adi Apr 26, 2009
    if it was sitting that long, it is possible that toner got itself embedded on a roller nad is stuck on it.
  • adi Apr 27, 2009
    please rate me based on your experience.
    thank you
My hp1010 printer gives horizontal white line or bars between character.
Try a different cartridge, blank horizontal would point towards a possible drum issue. Does the defect repeat down the page?
Sep 12, 2016 | HP LaserJet 1010 Printer
Transfer Belt Leaving Color Streaks on Pages
Try replacing color toner of the same color that are the lines.If the void was in the same place all of the time then I would say use a Q tip dipped in 90 proof alcohol and clean laser.
Apr 21, 2014 | Brother BU300CL Transfer Belt, 50,000...
Black horizontal stripes
Black horizontal lines ( page is held Portrait ) ,
where print is affected the print image fails to show behind Line effect but shows in between-
the drum surface has been damaged ( likely wear and tear) and can no longer maintain an even layer of electrons due to leakage/short
solution:
replace the toner cartridge which houses the drum.
Mar 16, 2014 | HP LaserJet 2300 Printer
Prints only blank pages
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 06, 2010 | Brother HL-2040 Laser Printer
Horizontal lines (red) on first 1 - 2 pages of initial print-out
Do you refill ink tank? Print blank pages. Is there horizontal lines appear? It might be caused bay ink leakage. Check respiratory hole at ink tank and rubber seal at bottom of ink tank. Print blank pages until no horizontal lines and try to use new ink tank.
Aug 17, 2009 | Epson Stylus Photo 1270 InkJet Printer
Kyocera KM1635: horizontal lines on printed documents
With this series machine, blank lines normally occur from the drum or developer units( even dirty optics). The fuser will get hot but if after only 20 or 30 copies, (if there was a problem with that unit) you would get double images which is common on those fuser units. It also depends on the total counter on the machine. Most of these yields are 150K. I am all for fixing things myself, but it sounds like you need a tech..
Apr 07, 2009 | Kyocera Office Equipment & Supplies
Printer prints white thick blank lines
1- black lines are from the drum: it has burnt out on that particular spot and rotates
2- the white horizontal gap space if it is not you skipping space is also from the drum
3-the white Vertical is most likely from the developper (unit that has the toner and is against the drum, look at the roller it should be solid black, maybe there is something on it : hair paper etc....
Aug 25, 2008 | HP LaserJet 1020 Printer
I have blank lines through my printouts
Run the cleaning cycle. If that doesn't work, try to use an alcohol soaked swab on the print head. Some of the jets are clogged.
Oct 27, 2007 | Canon PIXMA MP130 All-In-One InkJet...
Horizontal lines
Depends on whether the "lines" are colored or just blank areas missing in the print . If it is blank areas , then most likely the laser scanner is dirty and the glass needs to be cleaned . If it is colored lines , then you most likely have a defective drum .
Jul 18, 2017 | HP LaserJet 1500L Printer
Samsung CLP-500 Laser Printer Logo
2,020 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
