Question about Dryers
I have a whirlpool duet dryer model GEW9250PW1. The controls on the front of the dryer work sometimes now. There are times no lights come on. At other times the dryer would work like normal with all lights working fine. I took the dryer apart to check the connections on the touchpad board (console electronics board) and the machine control electronics board. When I put the dryer back together the LED for the touch up was the only one to light and was flashing no matter where I put the knob, and the dryer would not start when I held in the start button. I am wondering which board to replace. I am leaning toward the machine control electronics board.
  • rwest77 Apr 20, 2009
    I know that. With the symptoms described, which is it more likely to be. I would like to order just 1 at a time to see if it fixes the problem.
    Genius:
  • 1,847 Answers
The issue could be with Console Electronic Assembly or Machine Control Electronic Assembly.
Get these two check
Let me know if you need further assistance
Thanks
K
Posted on Apr 20, 2009
  • Legin Varghese
    Legin Varghese Apr 20, 2009
    I will suggest Console Electronic Assembly, that should fix fix the issue.
    Thanks
    K
What is capacity of my whirlpool duet ggw9250pw1? I don't see the answer identified. thank you
The Whirlpool Duet ggw9250pw1 looks like it has a 7.0 cu. ft. capacity. This is based on two different sources. The first has the GGW9250PW1 in a list of parts for 7.0 cu. ft. capacity Whirlpool dryer models. See http://www.appliancepartspros.com/search.aspx?model=whirlpool%20duet%207%200%20cu%20ft%20super%20capacity%20electric%20dryer .
Similarly, the related electric dryer, GEW9250PW1, is shown as having a 7.0 cu. ft. capacity at AJMadison.com: https://www.ajmadison.com/cgi-bin/ajmadison/GEW9250PW.html .
I hope this helps.
Nov 27, 2017 | Whirlpool Dryers
I have a whirlpool duet model gew9250pw1 dryer it gets good and hot put when the cycle is done some of the clothes are still damp.i not sure if it is the timer or a censer. i know when we start it the...
Look for an airflow blockage. Be sure lint filter is cleaned and if lint is accumulated in the air stream path, take a vacuum or brush and clean it out. Dirt and lint are a dryer's worst enemy.
Mar 17, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Control locked light is on? whirlpool duet dryer-mod GEW9250PW1.
Hi
Press and Hold the End of Cycle Signal button for 15 seconds, this will unlock the control. Hope this helps...please post back for further assistance.
Daniel
Sep 15, 2011 | Whirlpool GEW9250P Electric Dryer
I have a Whirlpool electric dryer, it is a Duet with a model # of: GEW9250PW1. When I try to select the the "normal" setting on the automatic side, it lights up the delicate light and has the...
Is the selector knob loose on the stem? Look on the knob to see if there is a set screw of some sort that you can tighten to set it where it belongs, it just seems it's loose and isn't pointing to where it should. Let me know if this works or not,
Please rate and comment, Thank you,
Joe
Sep 01, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a whirlpool duet # gew9250pw1 it won't
my whirlpool dryer has power but does not start
Jul 02, 2011 | Whirlpool Dryers
I have a whirlpool duet model GEW9250PW1 DRYER The display screen wont light up and there is power going to the unit I can hit the security lock and that indicator light comes on but that is the only...
sounds like the control board is out. If you remove the lower front cover a hex head screw in each corner, there should be a plastic pouch with tech sheets inside run test #1 part number for the board is 8546219
Oct 02, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool duet GEW9250PW1 electric dryer squeals
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Apr 06, 2010 | Whirlpool Dryers
Whirlpool duet dryer felt seal replacement
The drum may to be removed to install the new felt gasket but the old drum can then be reinstalled. The felt gasket seals the joint where the drum rotates at the inside back panel. It is likely that the inside back panel can be removed when the dryer is placed front-down and the outside back panel is removed. In that case the drum does not have to come out.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
63 people viewed this question
Top Dryers Experts
