Question about Vodavi Lands Phones
Take auto attendant off lines
Want to deactivate the auto attendant from lines 1-6 - line 7 is the only line to answer the auto attendant
  • 27 Answers
You need to go in to system admin of the phone system and remove the lines from preset forward that goes to voice mail group 440 or if it is set for delay remove preset forward destination.
Posted on Apr 23, 2009
How do you erase and change after hours greeting?dhalman
Call voicemail by pressing the Intercom button then dialing 777, when it answers login by dialing 99# followed by the password(default is 1234#) then press 9 for system features menu. Press 3 to choose Automated Attendant, the system prompts for the Auto Attendant number(1-4), start with Auto Attendant 1,if you do not know which one is being used by pressing 1. Press 2 to choose Night Menu, press 6 to change the Night Menu prompt. Lift the handset, press 1 to record your new Night Menu prompt using the handset, press 1 at the end of your recording. To listen to the new recording press 23, to immediately re-record press 21, to save the recording press *#. Press # to save all programming changes and activate new recording. Press *7 to return to system features menu or hang up to end programming session.
Changing the Auto Attendant prompt should be done when you are able to do a test call on each line to verify that you have changed the correct prompt(in your case after hours or by putting the system in After Hours mode manually to ensure the After Hours prompt is active) for each line being answered by the Auto Attendant. By default all lines are assigned to Auto Attendant 1, if your system has been modified to use a different Auto Attendant for some or all lines, you will need to repeat the above procedure for the Auto Attendant being used. If at any time you get lost or confused while in the voicemail programming, hang up and start over. Once you get comfortable with navigating the voicemail programming, it gets easier. If you have trouble send a comment, I will try to help.
Feb 10, 2011 | Lucent PARTNER18 Corded Phone
I have Partner mail vs release 5. When someone calls in they get the receptionist voice mail(10) instead of the day menu prompt of the automated attendant. How do I get messages to go to the automated...
You are going to need to get into programming.
#206 group 7, line 01, change from "3" to 2 assigned
You need to do that for all lines. That will make it go to the Auto attendant instead of the mailbox.
Jul 16, 2010 | Avaya Lucent Partner 616 Phone
Call display won't work as the phone system M7310 keeps picing up on the first ring. I have changed the Auto Attendant and the CCR # of rings but that doesn't help
It may be that you have the forward no answer parameter set to 1 ring on ANY of the phones you have programmed to ring on those lines. Make a call to your system from your cell and see what answers....the auto attendant (you can dial another ext) or a voice mail box. If your system is equipped, we offer remote programming services.
www.dyna-tech.us Hope this helps . Bill
Mar 22, 2010 | NorStar M7310 Phone
How to turn on/off AA Auto Attendant
feature 982 password:67372867, press next til you see answer lines:y, change to n, press release
Sep 01, 2009 | NorStar T7316E Corded Phone
Night ring change the number of rings
Auto Attendant
Answer Lines
1 – Feature 983
2 – Log: Dial 1020000 (3-digit DNs) or 120000 (2-digit DNs)
3 – Press AA
4 – Press LINES
5 – Line number: Dial line number (001-xxx).
6 – Line:xxx Ans:No Press CHNG to AA if auto attendant will always answer theline. If a Night Service key will be used to activate auto attendant answering, leave Ans: at No.
7 – If line has been changed to Ans:AA, press * then press TABLE.
8 – If Table:1 is OK press RINGS. (Table 1 is the default greeting table. Change to a different table (1-4) if alternate answering is required on the line being programmed.)
9 – Rings:0 – Press CHNG, dial number of rings before auto attendant answers the line, or leave at 0 for immediate answering. Allow at least 2 rings if CLID is in use.
10 – Repeat for each line to be programmed.
Notes For Night Service Mode Auto Attendant Answering
If the auto attendant will only answer lines in night service mode, line answering should be set to No as per step 6 above. Using night service will cause the AA to answer lines immediately.
Feb 11, 2009 | NorStar M7324 Telephone
Automated Attendant not on everyone line
The below texts should help you.
**Found on page 9-8 of "Partner R6 Install and Upgrade Manual" so your system may vary slightly:
Use Line Assignment (#301) to assign all the lines that you want the auto attendant to cover
to extension X.
**Found on page 4-47 of "Partner R6 Install and Upgrade Manual" so your system may vary slightly:
To assign lines to a specific extension:
1. Press [Feature] [0] [0] [System Program] [System Program] [#] [3] [0] [1] at extension 10 or 11.
2. Enter the extension number to be programmed. For example, to program extension 15, press [1] [5]. The red light next to each button that has a line assigned is on steady; the red light next
to each button that has a pool assigned flashes.
3. To remove all existing line assignments, press [Remove] before selecting a line.
4. Enter the line number to be assigned. For example, to select line 1, press [0] [1].
5. Do one of the following:
■ If you want to assign the line to the first available button with lights, press [Next Data] until the
display reads:
Line Assignment 15 L01
1 Assigned
1 Assigned is the factory setting.
■ If you want to remove a line assignment, press [Next Data] until a display like the following
appears:
2 Not Assigned
■ If you want to assign the line to a specific button, press 3. A display like the following
appears:
3 Select a Button
Then press a button with lights to assign the line to that button. If you use option 3 after a
line already has been assigned, the line moves from the old button to the new button you
select.
6. Do one of the following:
■ To program another line for this extension, press [Next Item] or [Prev Item] until the line number
appears on the display. Then repeat Step 5.
■ To program another extension, press N P and begin at Step 2.
7. Select another procedure, or exit programming mode.
Feb 05, 2009 | Avaya Corded Phone avaparp18d
AT T 984
I was told by an AT&T rep that the auto attendant can forward calls to another 984 phone to leave messages for that person. Your original OGM (out going message) on the designated Auto Attendant phone should state greeting and the names and the extensions. The caller presses the buttons for the person they want to reach and their call is forwarded to that extension. That extension, if unattended, will have an OGM telling the calling who they have reached and to leave a message. This feature can only transfer calls to other 984 phones only.
Jan 06, 2009 | AT&T 984 Corded Phone (att00148)
Number of rings before answering system goes on
You can adjust the Answer Delay time by going to Menu then DTAD. Adjust the Answer Delay under this menu... 6 seconds per one ring.
If you have auto attendant set up to answer for you in a multiline system, set that delay accordingly. That will be the first system to pick up, You should set up one auto attendant for every voice line coming into your phones.
Dec 18, 2007 | Lands Phones
Lands Phones Logo
445 people viewed this question
Top Vodavi Lands Phones Experts
george  peters
george peters
Matthew MacWilliams
Are you a Vodavi Lands Phone Expert? Answer questions, earn points and help others
