Question about Garden
25 bushel pto driven manure spreader squeals when engaged regardless of the load. Seems to get better once running a while. Don't want to wreck it though. I have adjusted the bed cleaner chains and ma
125 bushel pto driven manure spreader squeals when engaged regardless of the load. Seems to get better once running a while. Don't want to wreck it though. I have adjusted the bed cleaner chains and made sure they were even and at the reccommended tension. Any suggestions?
3 Suggested Answers
lindsay836
  • 677 Answers
SOURCE: I have a Roda 25 bushel manure spreader, the fins
Check and make syre you have not sheard the pin on the chain sprocket, and the that the chain is still on.
Posted on Feb 05, 2010
emissionwiz
  • 79186 Answers
SOURCE: I have a model 33 John Deere manure spreader that has the beater gear box with worn gears that won't engage. I cannot get replacement gears due to age of unit. Is there a way to repair the gears by we
There is no way to repair a worn gear, this is due to the heat treating of the metal to toughen it against wear and tear of use, otherwise it wouldn't last but a few hours of operation, this precise heat treating of the steel can only be done with special equipment and requires special skills to pull off correctly, so no you will need to get new gears. I know from personnel experience that you can get parts for these old farm implements, call around and see what you can find out. I will say that worn gears are not the common reason for hard gear engagement, that would be worn shift dogs and synchro ring cones or worn gear shaft bearings.
Posted on Dec 13, 2011
Cub cadet runs fine until I start the PTO, then it stutters and dies. If I shut off the PTO blade, it will pick back up and run again
I had a similar problem with my cub Cadet. It turned out that the Ignition Module on the engine was cracked. Motor started OK - but died as soon as a load (such as engaging the mower) was put on it.
These are not terribly hard to check, and/or change, yourself. Easy to get to once the motor shroud is removed.
My 25 HP Kohler engine has 2 modules. EXPENSIVE from the dealer - found MUCH better prices online.
Aug 30, 2013 | Cub Cadet Garden
JD R-1 spreader controls
www.deere.com
Ask them, they made it.
Aug 18, 2013 | John Deere Model "r" Manure Spreader...
Troy bilt RZT 50
Is this a twin cylinder motor if it is it sounds like a bad spark plug
Oct 15, 2017 | Garden
PTO engages, but, keeps becoming disengaged on LT1042.
Cub Cadets have one of two types of PTOs. The most common is gear driven. The gear teeth of the PTO shaft are very small and thin. If the PTO is engaged without proper clutch action, the gear teeth grind together, trying to engage. A little wear on these gears will cause the surface of the gears to become beveled, and when the PTO comes under load, the beveled surfaces of the gear teeth force the gear lock to disengage. The only option is to replace the worn gears...
The second type of PTO drive is electric clutch. This is a disc type clutch that is engaged by energizing an electromagnet built into the clutch pack... any disruption of electrical power to the clutch pack while under load will cause the clutch to disengage and then possibly try to engage while under load and casues the clutch pack to slip and will overheat almost instantly...
Sep 08, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Clutch for johndeere 870
That is normal for a live pto. If your tractor has a two stage clutch you should be able to stop the PTO with clutch all the way in (as in push the pedal all the way down). It should be transmission independant, meaning it will work even though the transmission is not turning AND if you are running something that has a lot of inertia, it won't push you around by driving the rear wheels even though you have the clutch in.
Aug 25, 2012 | John Deere 760 790 850 870 Flail Spreader...
John deere 2210 engine dies when engaging pto, seat switch good
are you sitting in the seat or have you jumped the safety switch under the seat before you engage the PTO I believe our tractors use an electric solenoid to apply hydraulic pressure to a wet clutch inside the trans axle I would think it would be OK with your chipper I have a 450 tiller that was built for the older 400 models 425 445 455 that I now use with my 2210 If I hit a large root or stone when using it with my old 445 it would stall the tractor at full power. Now with the 2210 it will actually slip the clutch on the tiller s PTO shaft I think the correct approach would be to increase your RPM s gradually or start increasing the power just as you trip the PTO switch. You want enough RPM s to create enough hydraulic pressure to run the PTO circuit so that you don t slip the wet clutch anymore than necessary and you want the RPM s low enough so that you don t shock the mechanical systems too severely at start up
Let me know how it works
Feb 02, 2012 | Garden
Dec 13, 2011 | Garden
Garden Logo
70 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
