Question about Dryers
Replaced start button, still won't start interior light bulb does work
  • rsimone Apr 20, 2009
    Thank you for your response - I fixed it though.  It was the dryer door switch that was causing the problems.
    THank you!
  • Jerome Barbin May 11, 2010
    You probably have a safety switch open. There are 4 assuming that you have an electric dryer. Do you have a meter? Something that reads ohms?
    Genius:
  • 1,122 Answers
I see it all the time it is a bad door switch,pop the top and it's right where-mike
Posted on Apr 20, 2009
2010 Honda Accord ex dome/ map light won’t come on
It may also be the door switch. Does it work if the passenger door opens?
How to Change Interior Light Bulbs Honda Accord - YouTube
2q==? 2:11 https://www.youtube.com/watch?v=gTMgZhLx1RY Mar 19, 2016 - Uploaded by Kies Motorsports Hey Everyone, Here is a quick video on how to change interior lights on Hondas. This should work for most ...
How To Change Map & Dome Lights - 2003 - 2015 Honda Acura ...
9k=? 5:07 https://www.youtube.com/watch?v=8uYaTnTvEJU
  1. Similar
Sep 27, 2014 - Uploaded by mitch cox This is an easy tutorial on how to change your interior light bulbs. ... This is on my 2003 Honda Accord but ...
How to change the dome light on Acura or Honda - YouTube
2q==? 2:27 https://www.youtube.com/watch?v=t-bkkp0jbgE
  1. Similar
Feb 18, 2012 - Uploaded by netman88 A video on how simple it is to change the dome light on Acura or Honda ... but i can turn the on manually. i ...
Honda Door & Map Dome Light Fix - YouTube
z? 7:18 https://www.youtube.com/watch?v=q4H5XVynRKA Dec 19, 2016 - Uploaded by Chris Thompson Our Honda Accord rarely has a problem, but we did start experiencing an issue with the front dome light ... change dome light 2010 honda accord Google Search
Nov 02, 2017 | Honda Cars & Trucks
What causes interior light not to come on
Could be a blown fuse, sticky door switch, or the light bulb needs replacement.
If the interior light works only when you open one door, look for a push button switch at the hinge side of the other (mind fingers). Try a squirt of WD40, or similar lubricant to make it actuate freely.
When one interior light is working, but another is not, then you may have a blown bulb. Try your nearest parts shop and let them know the exact make, model and year manufactured of your car for a replacement bulb. Ideally bring along the old one for comparison.
Remove the clear plastic lens from the light by unclipping it from the car ceiling fabric. You may need a thin flexible blade like a palette knife, or paint scraper to gently prise off the cover (make sure it's clean) like this picture of the Holden Astra TS 2001-2004.
If none of the interior lights is working, but other lights are, then maybe you have a blown fuse. The fuse panel is typically located under the front dash, or in the engine bay, but refer to your owner's guide for exact details.
Feb 24, 2014 | Cars & Trucks
Door ajar warning light/interior light won't come on
Good Afternoon bibliophilel, based on the symptoms you are describing, may I suggest resetting the refrigerator. This can be done by either unplugging it or flipping the household circuit breaker off. Wait roughly ten minutes and then turn the unit back on. If the issue persists, then more than likely the light socket and/or the door switch that triggers the bulb and alarm are faulty. In this regard, I would suggest contacting an Authorized Service Technician that will be able to assist you in the exact diagnosis of the appliance and repair.
Jul 19, 2013 | Frigidaire Refrigerators
Interior lights won't come on in GE adora refrigerator
Check that the door switch buttons are working fully. If not use a little CRC or WD 40 spray on them and exercise them a few times. If that doesn't work, the electrical contacts in the switch are corroded and the switch needs to be changed. Also check each bulb in a lamp outside the refrigerator.
Jan 13, 2013 | Refrigerators
Interior light won't come on when I open the front doors
If you have tried to adjust your interior lights with your dash light adjuster, and it didn't work, I would say you either have a bulb out, or a blown fuse. Hope it's something simple for you. GOOD LUCK
Jul 02, 2012 | 1994 Oldsmobile Cutlass Ciera
Peugeot boxer van 2007 changed interior light bulb blew fuse, renewed fuse, lights worked, but emissions lights on dash board came on and won't go out. Help
Try reading the OBDII with a code reader and see what it is then erase codes and see if it stays off ,could be more than one circuit on this fuse so the fuse blowing has thrown the light on for whatever reason ,Also try disconnecting the battery just out of interest for a few minutes and reconnect it might go out if your lucky
Feb 27, 2012 | Cars & Trucks
My head lights won't work. My running lights and dome light work and so does my turning singals.
Probably need to replace your headlight switch, it could be another problem but that is where I would start. The headlight switch is 2 or 3 switches in one, it turns on your parking lights, it turns on your interior lights and dims them too. Either that or it's your bulbs but they say you will never burn both headlights out at the same time. If you have a test light or a volt meter you could check the voltage at the headlight, that would eliminate the switch.
May 16, 2011 | 2004 Dodge Neon
I got a 2002 ford taurus and when i go to turn my headlights on the interior light dont work and the blinkers light up but they do blink when im turning, i was what it could be thats causing that thank...
Many turn signal lamps will have multiple bulbs in them. If "one" of the bulbs is faulty, the interior lamp or lamps will come on, indicating a bad bulb. You will need to turn on your left blinker and view the bulb and make sure all bulbs appear to be blinking on front and rear of the car, then repeat with the right blinker. If you find one that doesn't appear to look right or blinks faster slower or dimmer, then replace the bulbs in that turn signal. The interior light may begin working properly when you replace the "shorted" bulb for the turn signals. If it does not, check the fuses to make sure the "shorted" bulb didn't damage your fuse for the interior lights.
Jul 01, 2010 | 2002 Ford Taurus
Rear interior light and door courtesy lights not working- Jaguar
take off the cover and replace them. if you have a volt/ohm meter you can put if on the car side and make sure you have voltage and the ohm meter on the buldb should give a 1 rating if its good. it would be the cheapest and easiest to just get a new bulb and see if it works then start checking fuses if its not the bulb.
Mar 15, 2009 | 2004 Jaguar X-Type
Dryers Logo
Top Dryers Experts
