Question about Candy CDC266 Dryer
Candy condenser dryer cdc 266
The dryer makes a screeching noisy as it turns then intermittantly it makes louder metal to metal screeeching sound. dryer about 2 -3 yrs old and used quite alot
  • Anonymous Apr 11, 2009
    the dryer makes a screeching noisy as it turns then intermittantly it makes louder metal to metal screeeching sound. dryer about 2 -3 yrs old and used quite alot
Forget purchasing anything, i had the same problem. Slide the lid back and spary the belt with WD40..... noise goes and works a treat and no money spent!
Justin
Posted on Jun 25, 2009
I had this problem the belt tensions are kaput they cost me around 20.00 for a new set. unfortunately not easy to get too
Posted on Aug 01, 2008
6ya staff
SOURCE:
My dryer is a model number GLER341AS2 and when I turn it on it makes a sreeching noise. Now the screeching has turned into a louder noise almost like a rubbing thud.
The symptoms you describe indicate that your dryer drum bearings are faulty: there is usually a large 'felt' bearing around the opening which support the drum and prevent metal to metal contact (screeching noises)- The drum must be removed to get to this front bearing (which is normally glue to the dryer front panel at the drum opening): it is not a trivial job and is not normally replaceable by end-users.
Hope the explanation helps.
Sep 23, 2011 | Frigidaire Dryers
Obnoxious screeching sound when the drum turns. Short consistent screech on revolution, which turns into one long non-stop screech. Stops after 45 seconds or so, then starts all over again with longer...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 05, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Dryer turns and heats, but makes a very loud squeaking (or should I say, SCREECHING) noise. The heavier the load, the louder the squeaking.
Does it sound like a belt ?
Or does it sound like metal ?
Might need to replace the drive belt..
Or - it could be the bearings..
Hope this helps !!
Rate me good ;o)
Jul 13, 2009 | Whirlpool LEQ8000JQ Electric Dryer
My top louder washer is noisy when spinning , I want to know why
You can remove the cap but I wll be truthfull if your getting a loud roaring sound or screeching sound in the spin cycle it is the bearing call a tripple lip seal you need special tools to remove the seal
Mar 28, 2009 | Maytag Washing Machines
Screeching Drum
My machine did exactly the same thing until the belt snapped - and it's a very painful noise!! I'm about to replace my belt and if this solves the problem I'll let you know.
Dec 15, 2008 | Candy CDC266 Dryer
Candy cdc 266
your belt is probably broken, or your motor is bad, the motor and belt not only turn the drum, but also the fan that moves air out of your dryer so if it cannot move, the dryer gets hot and it thinks this is because the lint trap is full
Oct 27, 2008 | Candy CDC266 Dryer
Replacing belt on candy cdc266 reverse action dryer
i have i candy cdc 266 reverse action tumble dryer and the condenser has gone on it
Sep 07, 2008 | Candy CDC266 Dryer
Candy Nova CDC 266 tumble dryer. The tumble dryer tumbles but I have no heat and the filter light stays on constantly. Any ideas of what it could be?
hi ya this is the thermostat at the back of machine external,take the fan housing of it is nomaly the top one .beware change like for like do not exceed the temp rating of the stat.
hope you solve it
andy bird www.shropdive.co.uk
May 05, 2008 | Dryers
Screechy Dryer
Hi yes i have a candy 6kg tumble dryer. It also screeches when turning. I have taken it apart and found its the bracket at the bottom holding the drum. It has deformed due to the weight of the drum and also the wet clothes added to it increases the pressure on this bracket. Dont know if its a design fault or really how to fix the problem?. Any solutions would be most welcome..
Aprior7
Nov 14, 2007 | Candy CDC266 Dryer
Candy CDC266 Dryer Logo
640 people viewed this question
Top Candy Dryers Experts
Gerry Harvey
Gerry Harvey
colinjhought
Marvin
Marvin
Are you a Candy Dryer Expert? Answer questions, earn points and help others
