Question about Music
Replacement for an akai 10.5v 300ma adapter
I picked up an akai u40 riff-o-matic with no power cord. I knew that 10.5v was odd but i didn't think it would be this hard to find a suitable replacement.
  • Anonymous Apr 23, 2009
    American style adapter.
  • Starfish Phoenix May 11, 2010
    Uk or american or european mains?
  • Music Master
  • 5,603 Answers
The voltage won't be that critical... 10 to 11 will work. Just make sure the type (AC or DC) matches AND the polarity for the DC units.
Often these can be found at thrift stores.
Posted on Jul 26, 2009
Usb cable broken
Yes, you need to have midi in/out on your computer. Also you would need the optional AC adapter, which can be purchased separately from akai, in order to power your controller
Jun 18, 2013 | Akai Professional AKAI MPK88 USB MIDI...
I have noise occasionally from my headrush 2 can i have someone modify it seems to click on and off at times
Most common cause is loss of power due to poor connection. These are usually turned on by plugging in the inout cable and a worn plug from the guitar may be intermittent. The sleeve of the inserted plug usually turns on the battery or the adapter power to the unit. Adapter plugs are notorious for poor connections. Another common problem is broken solder at the external jacks into these as cords get yanked and stepped on resulting in force on the jacks breaking the solder. A momentary power loss will trigger the unit off.
Jul 19, 2011 | Akai E2 Head Rush Headrush Guitar Effects...
G1x zoom guitar effects no power even using an adaptor
if you're using an adaptor other than the original zoom, make sure it's 300mA or more and try switching the polarity.
Jun 20, 2011 | Samson ZOOM G1x Guitar Effects Pedal
I was playing away with my EZ-200 keyboard and before I knew it, the power went off. When I tried to switch it on again, the light came on for a second then went off again. I haven't been able to play...
It is UNCLEAR if the utility power went off or the keyboard just turned off. Assuming the latter, things to check are that the power cord is seated. They chronically come part way out. Verify power from adapter is good. If by chance you are running this on batteries, the action you describe is what hapens when batteries are exhausted. They recover enough for a brief flash and that is it. Also if using an adapter, it may store a little energy and if your wall plug happens to lose power the action would be typical. Plug a lamp into outlet to make sure it is hot.
May 16, 2011 | Yamaha Survival Kit B2 for PSRE223,...
I have an allen and heath Xone 22 Mixer. Its great, except due to the lack of a power switch I pulled the ac adapter/power cord out too many times and now it has a really bad, loose connection. It works,...
Usually the connector that is board mounted is the problem. I would OPEN the unit as there may just be broken solder at the connector inside. If the connector requires replacement, find one at Digikey.com by searching for "power connector coaxial".
Hint: In the future install one of those little lamp switches that are in a little plastic box with knurled knob sticking out the sides. ONLY break ONE wire from the adapter to avoid getting the connections reversed. Since the wires are smaller than lamp cord, tack solder the wires to the piercing points of the switch .
Apr 11, 2011 | Allen & Heath Xone-22 2 Channel Dj Mixer
Using generic battery adaptor on Digital recorder
Others have had problems doing so. I would get one specifically for the unit. One person got an adapter with an "S" suffix and that DID NOT WORK.
Get the exact replacement for this particular device as called for in your manual.
Mar 07, 2010 | Boss Micro BR Digital Recorder
Music Logo
330 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
