Question about Brother IntelliFAX 4100 Laser Fax
We can send faxes but we can not receive faxes. The fax machine that sends the fax tell it that our line is busy. Is that a machine problem or a phone line problem?
  • 1,959 Answers
Problem lies in your Receive Mode setting. If you don't have a dedicated phone line for the fax machine, you need to set it up for either Manual where you answer every call or Fax/Tel whereby the Fax machine determines if the incoming call is a fax or phone call. Instructions per Intellifax 4100 Manual.
Select a Receive Mode
Choose the mode that best suits your needs by pressing the Mode button
repeatedly until the FAX and FAX/TEL lights show the setting you want to use.
Manual
You must answer every call yourself.
The Brother machine must be started manually
to receive faxes.
Fax
For use with a dedicated fax line.
Every call is answered as a fax.
Fax/Tel
For receiving fax and voice calls on one line.
The FAX answers every call and receives a fax or
double rings for you to pick up a voice call.
TAD
For use with an answering device.
The TAD answers every call and stores voice messages.
Fax messages are printed.
Posted on Apr 20, 2009
Cant receive faxes. constant busy signal when dialing in.
Hi Janet
Try using a standard phone to call your Fax Line
Connect a phone to this Line to test for voice
Disconnect Fax Machine from Phone Line
Reset Fax machine
The Fax machine is supposed to respond to the right tones being sent down the voice line
If it is not responding & all else works then check your Fax settings for "Receiving"
Nov 30, 2015 | Panasonic UF-5500 Fax Machine
We have two fax machines hook up to one dedicated fax line. When we send a fax from wither machine it is not faxing to the phone we fax it only sends the fax for the second fax machine that is in our...
Yes, you must set up your fax machines like this: The receiving fax must be set to auto receive and the telephone line must be inserted in the "line" input. A line must then be connected from the "Tel" to the "Line" of the Transmitting machine, which must be set to "manual receive." This is not really a satisfactory way of doing things as you can't send and receive 2 machines on the same line together. A much better way is to have 2 lines. with a machine attached to each. Get the tel company to put "No answer transfer" on the line as an accesory. Give them the number of the fax machine that transmits. Make it "manual receive" Now you have a versatile system that you can also use the office telephone with.
Oct 05, 2010 | Brother Office Equipment & Supplies
I can receive faxes but, not send. I immediately
Your line is out of credit, recharge and try again.
Dec 01, 2009 | HP FAX 1250 Fax Machine (Black)
Receiving faxes
Certainly not your fax machine problem.
The client needs to verify your fax number.
Oct 03, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
A particular business can receive faxes from me sometimes, but other times I get a strange beep and it doesn't go through. They receive faxes every day with no problems. I send faxes every day with
This is a problem on ther side. A lot of high volume companys dont admit this, insurance order etc most use pc based fax products to filter junk this can also cause probs
May 11, 2009 | Brother IntelliFax-2820 Laser Fax
Receiving a fax from a certain number
Does the other party have a DSL phone line?
Aug 09, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Invalid number
Fax machines do not work well or at all on digital lines. They are designed for analog lines, like the standard phone company line. You may have to install a dedicated fax line from your tel. company.
Jun 11, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Vonage vs Brither 4100
Have you called your own fax line and just listened to the fax hand shake? might sound simple but I have called fax lines before and it just rang, or it was busy or static, if your not getting a clear fax hand shake, then it is the phone line, if there is no answer you may have turned your fax to manual receive mode, If you don't know how it should sound call a friends business fax line and listen to it. I have actually gone out to businesses that reported send or receive problems just to call the line and listen to a disconnect message, that would make it difficult to fax.
Jan 13, 2008 | Brother IntelliFax-4100e Fax
We can't send or received faxes
Just a suggestion. This effect can happen if you have plugged the line cord into the tel jack instead of line jack.
Oct 30, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
1,479 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
