Question about Whirlpool Refrigerators
Water accumulation in the bottom of our refrigerator
Our refrigerator is a ET18VK top freezer. we got it with our house, where we've lived for the past 17 years. lately we've noticed an accumulation of water in the very bottom, below the produce drawers. I sponged up about a quart of it today. What could be the cause of this?
    Guru:
  • 1,524 Answers
There is a drain line on the back of the refrigerator. Trace it out to find where it empties into the drain pan on the bottom behind the grill. Take a piece of stiff wire (coat hanger) and gently push through it to remove any blockage.
Posted on Apr 20, 2009
Water collects in refrigerator which is below freezer
use air from bottom of fridge, but you will have to clear top drain eventually
May 04, 2012 | Maytag MTB2176HR Top Freezer Refrigerator
My refrigerator's model is FRS22PR. I do not know where the drainage pain is. I've check from the front but can't find it. Water leaks once a day, not to mention water has accumulated in...
There is a drain in the freezer in the back under the evaporator coil. If you are accumulating water in the freezer then the drain hole is plugged with ice or material. you will probably have to pull the cover in the back, then clear the obstruction and pour some hot water down it. The water will drain down to a pan under the unitwhere it is supposed togo. good luck!
Jun 22, 2011 | Frigidaire Refrigerators
Started leaking water accumulated on bottom shelf in lower level. now top freezer takes 2 days to freeze ice, bottom freezer vent clogged.
The drain is clogged. When the drain clogs it can also clogs the airflow vents. Remove the back wall of the freezer to access the drain. Remove all the ice blocking the drain and the vents. Then use a trukey baser to force hot water down the drain until water flows freely. Then mix water with baken soda and pour it down the drain. http://www.appliance-repair-it.com/refrigerator-leaking.html
Sep 27, 2010 | Kenmore Top Freezer Refrigerator
Water collecting in bottom of freezer
Your seal may be bad letting in moist air that provides a source of water to condense on parts of the freezer.
Jul 24, 2010 | Kenmore 53703 / 53706 Stainless Steel Side...
Water from freezer dripping into fridge freezing and accumulating in the crisper drawers.
Maytag , MZD2752GRW; Water accumulating and is freezing in bottom of the freezer, then runs out the door on to floor.
Jun 10, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water accumulating in bottom of freezer and leaking onto floor
Yes the drain is clogged and the water that supouse to go through became ice so it make it worse.Put hot water in the drain hole until it runs through,it'll go to an evaporative pan on top of the compresor to keep it warm and vaporize the water.
Apr 04, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Kenmore Refrig
It appears the defrost drain inside freezer is blocked or the drain tube leading to pan near compressor is clogged I would unplug refrigerator and remove the back panel in freezer to examine the drain and get back with me to let me know what you find, also get model number for your refrigerator so I can help you better. Sea Breeze Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
Mar 27, 2009 | Refrigerators
Refrigerators Logo
107 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
