Akai pt 5598
I turned my akai pt 5598 off last night and this morning it would not turn on. The led power lamp only lights when I turn on the tv with the remote in the vcr setting. Either case there is no blue screen and I can't pull up the menu. I am not technically adept but I can effect a repair if it is unplug and replace. Thank you for any assistance.
  • 2 more comments
  • eneg Oct 04, 2007
    This particular unit does not have a single projector lamp. It has three independent tubes red yellow and green. Now the led lamp does not light when you turn power on.
  • eneg Oct 05, 2007
    I don't know that. The unit does not power up. There is absolutly no indication of power anywhere. The led power indicator does not even light.
  • eneg Oct 07, 2007
    sounds like a job for a qualified tech
  • eneg Oct 07, 2007
    The problem is who can you trust to give you the honest solution and the right price. The mainboard of this unit is over $400.00 dollars not including the labor
  • 790 Answers
Ok so your problem is power right? check the power section in un reguated power supply, and the secondary power in hot side! os maybe you have abnormal power oscillations in oscillation circuit.
Posted on Oct 07, 2007
  • carlos fernandez Jr.
    carlos fernandez Jr. Oct 08, 2007
    i think you have to find a qualified technician!
    Sergeant:
  • 279 Answers
So the screen shows nothing, you just see an LED? It's likely just a burnt out bulb in the projector lamp. These should be easy to check and replace, it's really no different than changing a lightbulb in a lamp.
Posted on Sep 22, 2007
  • John Goodman Oct 05, 2007
    So the yellow and green do light? Maybe I'm misunderstanding you, but it sounds like it's just the red tube that needs replaced then.
  • John Goodman Oct 08, 2007
    I'm not sure we can help you with that question. One of the disadvantages of the internet - nobody's local.
SOURCE:
When turning on the tv by either remote or switch on side screen will flash blue then turn off. Have unplugged tv still won't turn on.
Search Results
    Samsung TV Keeps Shutting Down - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETWhen I turn the TV on for the first time each day it shuts itself off within 30 ... There is ablue kill switch there, but you don't want to fool with that. .... The tv will not turn offwith the remote or the side buttons on the tv. .... I replaced the lamp but the tv screen will have a momentary flash of light on the screen then it will turn on and ...
    Philips/Magnavox Tv Problems ? - Home Forums
    ths.gardenweb.com > Home Forums > Electronics
    Mar 26, 2005 - I turned the tv on then off a few tims then eventually the piture would come on. .... time, the LED will flash continuously along with the volume going up to max. ...... You can use the remote to turn the tv off and on but nothing else. ... If you press the power button over and over it stays on a blue screen but as ...
    Top 208 Complaints and Reviews about Akai ' Page 3
    www.consumeraffairs.com > Electronics > Televisions
    Rating: 1.9 - ‎37 votes
    The screen will not turn on with the remote, side switch or rocker arm. .... It will flash for a second and the blue Akai screen will display very briefly, but then .... Akai LCT3201AD TV does not turn on using either remote or power button. ... I turned itoff one night and the next time I turned it on, the green light came on, but it did ...
    Get help with audio, video, or power on Apple TV - Apple ...
    https://support.apple.com/en-us/HT200197
    Apple
Jan 28, 2016 | Televison & Video
Will not turn on
Probably a spontaneous power supply failure.
Jan 07, 2014 | LG 42" 5400 Series LED HDTV - 42LN5400
WD57732 purchased 12/06 and has worked fine. Turned off at 11 pm last night. No indication of trouble. Tried to turn on this morning and nothing. Did TV Reset, green light flashed for a minute like it...
Now,tv on?.Tv "LAMP" LED light indication flashes or stay on?How long the Lamp been inside this tv,been inside like 1 1/2 or 2 years and tv been on each day like 4 or 5 hours a day in used.The lamp life are over.Should replace another lamp.
Dec 10, 2010 | Mitsubishi WD-57732 Projection Television
AKAI CFTD2052 Doesn't turn on
I can repair your power supply, write to [email protected] for more info.
Jan 07, 2009 | Televison & Video
Tv won't turn on
I had a similar problem when there was a power outage or the lights went briefly out. I unplugged the TV and left it for a few days/weeks and then plugged it in and the TV worked. I think newer TVs should be treated like a home computer and put them on surge protectors.
Jul 08, 2008 | Televison & Video
Akai pt 5598
The Solution posted by "Guest" on March 18 2008 worked exactly as he said it would. The part was delayed a week or so due to back order, but it arrived yesterday and, once installed, fixed the problem for under $100. THANKS "GUEST"!!!
Sep 21, 2007 | Akai PT5598HD 55" Rear Projection...
Turning on problem with Panasonic Viva PT-43LC14
Sounds as you have a bad ballest. The ballest is the power supply that turns your lamp on. You can check your lamp by removing it and it should be clear and no broken pieces of glass. With the lamp removed install the cover and turn it on you should hear no noise and when the power light turns red you should see a LAMP red led blink every 5 seconds. If no noise then the lamp is bad. If you do hear noise you have a bad ballist. Hope this helps. Frank
Sep 05, 2007 | Panasonic PT-43LC14 43" Rear Projection...
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Ekse
