Question about Panasonic PV-P1 VHS-C CASSETTE ADAPTOR
CASSETTE ADAPTOR VW-TCA7E tab won't retract when I place the video camera cassette in the adaptor and close the cover. The triangle-shaped tab is on the left side of the adaptor and when it has not retracted prevents the adaptor from being inserted into a vhs tape player. The rest of the processes seem to occur normally as the cover is closed (the electric motor whirs and a small roller swings into action placing the tape into a new position).
I had a similiar problem, or so I thought, but my son has just found that it needs a battery, which I did not even know, so maybe yours just needs a new battery? the cover is near the tab, hope this helps
Posted on Jun 07, 2009
  • manuelacgard Jun 07, 2009
    , could you jhust sellotape the tab in if everything else works OK
  • zenalowe Mar 28, 2011
    No for some reason, the tape won't even go into the cassette when I taped the red tab?? Kinda strange though, I hoped that would work.
The cassette door to this camera will not retract when I try to close it. as you probably know you close the door partially, the casstte holder retracts and then you can finish closing the door. When i...
Hi.
My name is Rick and I am the owner and technician of Discount Camera Repair. The problem you are experiencing can be repaired fairly inexpensively but will require disassembly by a qualified technician. The camera will need to be disassembled to remove the tape mechanism and then the tape mechanism will need to be disassembled to repair. If I can be of any help please call or email me and I'll get the camera working for you.
Dec 27, 2011 | Sony Handycam DCR-IP5 Micro MV Digital...
E06 SAFE GAURD MODE
Have you tried cleaning the camera with a cleaning cassette.
You can buy one wherever they sell cameras and you just run it in the machine once or twice and it should start working.
Please let me know if you need any additional help
Thank you for using Fixya and Good luck
Apr 15, 2008 | Sony Handycam DCR-TRV330 Digital Camcorder
Hi Donald. not sure how many calls you get from
The fault seems to be in the sensor and the mode switch of the loading system which is connected with the main controller processor and loading driver.
This can be a failure of the tape end detector which is a IR - infra red- emitter which is placed in the center of the tape tray and MUST feed continuous signal to the END IR detectors placed at either ends.
Also the tape seems to load with a false detection of the cassette within when the tray is closed for this reason of the failure along with a possible misplaced mode switch settings. This triggers to make the loading move without a reason and so can be due to failure of the the mode switch or unbalanced settings.You will need some experience to remove the tray unit, then check on the IR sensors and also check the settings of the loading drive and mode switch.
Nov 27, 2011 | Cameras
I need a replacement Cassette Adaptor VW-TCA7E thanks Roy
This does the same job as the original Panasonic version. Note that the link is for example only, there are other suppliers of VHS-C to VHS adapters.
You'll be very lucky to find an original one these days, they're long out of production and used examples may also be nearly worn-out.
If the above hyperlink didn't work, cut and paste the following into your browser:-
http://www.amazon.co.uk/Electrovision-VHS-Camcorder-Tape-Adapter/dp/B000LB0QIY/ref=dp_cp_ob_ce_title_0
Please take a moment to rate my answer.
Jul 11, 2011 | Panasonic Cameras
Were can you find a panasonic VW-TCA7E
Although this one is hard to locate there are other ones that can be used that are copatable such as the one at this link below from amazon.
http://www.amazon.com/Motorized-Vhs-c-Cassette-Adapter-Panasonic/dp/B0013CMXTA/ref=sr_1_6?ie=UTF8&s=electronics&qid=1261975765&sr=1-6
Mar 05, 2011 | Panasonic PV-P1 VHS-C CASSETTE ADAPTOR
Where do I buy a Panasonic cassette adaptor VW-TCA7E VHS
You can get a cassette adaptor that will except any VHS-C tapes and play them back on any standard VCR from Maplin www.maplin.co.uk.
They are £14.99 plus post! It's unlikely that you just have to have the Panasonic one!
Jun 17, 2010 | Panasonic PV-P1 VHS-C CASSETTE ADAPTOR
My sony trv37 cassette door won't close.
If this condition only occurs with as cassette inserted to load this may indicate a condition where the cylinder which holds the video heads is not spinning up when requested by the system control microprocessor.
If the door will not latch closed with/or without a cassette inserted this can indicated a mis-timed condition of the tape loading mechanism.
Try closing the door without a cassette loaded whilst the unit is powered from its AC Adaptor - under certain conditions this may allow the mechanism to reset and may allow the door to then close.
I trust that this information is of assistance! RHN
Jan 02, 2010 | Sony Handycam CCD-TRV37 Camcorder
No sound
dear
clarification need
question not have sufficent info.
give me full detail about your exact problem.
Oct 23, 2008 | Panasonic PV-P1 VHS-C CASSETTE ADAPTOR
Electronics - Others Logo
2,897 people viewed this question
Top Panasonic Electronics - Others Experts
 Grubhead
Grubhead
Tom Chichester
Are you a Panasonic Electronics - Other Expert? Answer questions, earn points and help others
