Question about Westinghouse WRS3R3EW 33" 22.6 Cu. Ft. Side-by-Side Refrigerator w/ Plastic Freezer Basket, 4-Button...
Water pool in bottom of freezer
Our freezer is gathering water in the bottom of the freezer. it seems to be coming from a hole in the bottom back of the freezer. leaking
    Guru:
  • 1,524 Answers
On the back wall of the freezer is where the cooling coils are located behind the metal. At the bottom is the drain trough through which the water from defrost flows. This drain may be clogged with debris.
Mix some baking soda and warm water and pour it down the drain. You may also need to push a piece of wire (coat hanger) through it.
Posted on Apr 20, 2009
    Scholar:
  • 142 Answers
I would recommend that you remove the lower panel in the back of the freezer section and physically remove all visible debris. Pour a mixture made from a teaspoon of baking soda dissolved a 1/2 cup of warm water into the hole. Baking soda is excellent because it helps to break down the cell walls of plant matter and removes smells, too.
Then use a long piece of pipe cleaner to push any remaining debris down into the evaporation tray underneath the refrigerator. Coat hanger wire may be too inflexible to get all the way.
Posted on Dec 23, 2012
Amana Freezer DeepFreeze AFU2067BW 19.6 Cu. Ft. ice in bottom
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Feb 20, 2010 | Amana Freezer DeepFreeze AFU2067BW 19.6...
Water leaks out the left front. Water seems to pool and freeze in the bottom of the freezer. The leak is not alot but it never stops. Have checked for level have disconected the water and ice maker. Still...
You have a plugged up defrost drain. There should be a drain hole way in back of the freezer, at the bottom. (it should be behind the panel at the back of the freezer compartment) Use a turkey baster with warm water to flush it out until water runs out the hole into the defrost drain pan under the refrigerator.
Dec 08, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water pools at bottom of freezer, freezes and water leaks out
Hello, this sounds like you have a blockage in the drain tube, remove bottom shelf from fridge and remove the styrofoam..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Aug 31, 2009 | Freezers
Refrigerator cooling but not real cold, freezer freezes ice but
***UNPLUG THE UNIT***
Take the cover off the back where the tubes go from the compressor into the freezer. If you can see into the freezer AT ALL, you have a mouse issue. Plug this hole with expanding foam. If you're getting room air into the freezer and your door seals aren't coming apart, it's usually from the rear. Make sure to melt all ice that formed in the bottom of the freezer before you plug it back in.
Jun 29, 2009 | Jason Natural Cosmetics Jason Forma...
I have a problem with my freezer, it has water pooling then freezing in the bottom of the freezer. The water also runs out onto the floor. It looks to be coming out of the opening in the back of the...
Your defrost drain line is clogged and frozen over with ice.
Turn off the fridge. Remove the bottom freezer drawer. Take a hair dryer and thaw the drain hole at the back bottom section of the freezer. After you defrost the drain line pour 1/4 cup bleach into the drain hole.
Jun 28, 2009 | Maytag MSD2454G Side by Side Refrigerator
Water in bottom of refrigerator coming from freezer (not really sure of the exact model as I'm not home to double check).
If water appears on the floor in front of the refrigerator once or twice a day, it could be due to a clog in the defrost drain tube. The usual evidence of a clogged drain in a side-by-side refrigerator is ice under the bottom basket in the freezer compartment, in addition to a puddle of water on the floor. Try watching the YouTube videos like this one:
https://www.youtube.com/watch?v=H_DKNtgd5vI
Apr 01, 2017 | Roper RT18VKXKQ / RT18VKXKZ Top Freezer...
I have water pooling on my fridge trays and than turning into ice . The water seems to be coming from the vents. How do i get rid of that.
The freezer compartment has a drain hole behind the back wall inside the freezer compartment. The drain hole has probably rusted and has gotten larger. Carefully remove the icemaker and the screws from the back wall inside the freezer compartment. Lift the bottom of the back wall and look to see if the drain hole has gotten larger. You can make a small funnel from an aluminum can to fit over this area directing the water into the drain tube. It worked for me. good luck. Dave.
May 10, 2009 | Whirlpool ET9FHTXM Top Freezer...
Water builds up in the bottom of freezer
had this happen once and my drain was clogged. in the freezer section you have to remove the rear panel. 2 1/4 screw bolts. after exposing the coils the drain hole is in the middle. i clesred the hole with my wet/dry vacuum. first sucked then blew air through it. hasn't done it again and its been 1 year so far
Apr 18, 2009 | Maytag MSD2756G Side by Side Refrigerator
Kenmore elite side by side has water that pools in the freezer.
you need to clean out the freezer drain at the back of the freezer,use a hair dryer and a hanger or maybe a shop vac can **** it out-mike
Mar 16, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water under drawers, condensation on top of freezer
Water collecting on the top of a freezer, I have to wipe it every week, it is on the outside of the freezer, on top of the formica surface. Please Help.
Jan 12, 2007 | Kenmore 72202 / 72204 / 72209 Top Freezer...
Westinghouse WRS3R3EW 33" 22.6 Cu. Ft. Side-by-Side Refrigerator w/ Plastic Freezer Basket, 4-Button... Logo
314 people viewed this question
Top Westinghouse Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
