Question about RCA P60921 60" Rear Projection Television
Blurry picture and arched at bottom
Picture is blurry and at the bottom of the screen it arches and the arch is black
  • NahomyDiaz Oct 29, 2008
    I was watching TV yesterday, and the TV just arched at the top and at the bottom, and it went blurry picture. The sound is still good, but I can't watch it without getting tears in to my eyes.
We have a Proscan 50" Projection TV. A T.V. repairman told us it was the HV (Horizontal Vertical) Splitter causing this problem and tried to find the part for us. The part for our TV was too hard to find though and we ended up not having ours fixed. Our T.V. is 8 years old though, and Proscan is discontinued. Maybe you'll have better luck finding an H.V. Splitter for your TV. Of course, you'd need a professional to install it for you. Good luck.
Posted on Oct 02, 2007
SOURCE:
Top and bottom of picture is arched and picture is blurry
convergence IC,s bad, may have blown fuse in power supply also.
Jun 24, 2009 | Sony KP-51WS500 51" Rear Projection...
Picture Falling with arch
It is your convergence IC's going out, they cost about 40 $ for both, if you know someone that can solder, i would have them do it, once you see the new parts it is prity easy to find them on the board in your tv, repair shops usually charge 4 to 5 hundred
Jan 08, 2009 | Sony KP-46WT500 46" Rear Projection...
There is a arch at the bottom going to the left
Covergence needs to be fixed replace Both of your ICs they are big black ICs with STK on them for example STK392-110 if this the # on yours use 180s better ics.For parts Call 1-800-223-3205 www.electronix.com.
Dec 26, 2008 | Toshiba 57H82 57" Rear Projection...
Color distortion and arched picture
It is problem of failure of convergence ICs or related circuit. Please confirm model number of your TV that is Sony KP-57WS500 to help you out.
It would be nice if you could past TV snap shot here for easy understanding.
Thank you.
Oct 02, 2008 | Sony KP-57WS500 57" Rear Projection...
Krazy colours
Hi if picture is of it could be convergnce ic and that would require a tv tech cost is 250.00.
But the arching noise is usually your high voltage arching from fly back or spiltter you could take off back be careful it is very high voltage only do if you now this stuff, and you will see it arching when it is on and where ever the arc is coming from is the problem the fly back is a large transformer and is black with red high voltage lead coming out of it the leads could be bad to.
the splitter is where all the leads go into from tubes. i hope this helps cost to fix for tv shop is 350.00. thanks doctor video
May 04, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Arch on top and bottom of screen
I read that these sets have a problem with the yokes on tubes sliding down some- there for causing this problem make sure yokes are all the way up on neck of picture tubes,this may fix your problem!
Dec 27, 2007 | Philips 55PW9363 55" Rear Projection...
Arching in Picture tube socket
ok! the arching line is for screen grid, make sure your spark gap is in align! or much better replace a new one CRT socket then clean all CRT board area with laquer thinner...
Sep 26, 2007 | Televison & Video
Rca tv picture blurry and arched up at bottom
Replace the Sanyo I.C. chip on the heat sink of the power supply convergence board STK730-XXX. Last 3 could be 130/010/020, any will work.
http://www.electronix.com/catalog/product_info.php/cPath/6_308/products_id/9541
Sep 20, 2007 | RCA P60921 60" Rear Projection Television
Sony kp-46s25
It sounds like you are going to need to have the convergence IC's replaced. Not really a hard job, but the job requires the proper tools, soldering skills, and a service manual to get the proper part numbers and to perform convergence alighnment in the service menu after the IC's are replaced. Good Luck
Mar 28, 2007 | Sony KP-46S25 TV
RCA P60921 60" Rear Projection Television Logo
158 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
