Question about Dryers
Looks like a belt broke for the drum.
Does anyone know how to replace a broken belt for the drum? The motor starts but the drum does not move. can hear a sound like a broken belt when I turn the drum manually.
  • 77 Answers
Not knowing what model you have. To reinstall most belts you must first remove the front of the dryer. Once the drum is exposed, then you can retrack the belt around the drum. You'll see where the other one passed. then you will have to place the belt around the tensioner and pulley. If you still have the manual, it should show you exactly what to do. Of course, shut the power off before making any repairs. But first i would take the back off and look at the motor down below. You can see the belt from this angle as well and it's a lot easier than taking the front off. Good luck.
Posted on Apr 20, 2009
Maytag gas dryer mdg9306awa anits sounds like it wants to start but doesnot
that is the motor,try this,open the door,push the door switch in with one hand and spin the drum with the other hand while someone else pushes the start button,if by moving the drum the motor does start to run the motor is bad,also you have the neptune style maytag and i don't think there's a belt switch in the model so if the belt broke it could be jammed in the motor,try spinning the drum to help it start if that doesn't work unplug the dryer,open the door,remove the two screws that hold the door on and then remove the other two screws on the opposite side,grab the top of the front panel and pull forwards to remove the front panel,you can leave the door on or lift it up and pull out to remove the door,now look to see if the belt broke,if the belt is rapped around the center of the drum then it isn't broke and it will be the motor,that's a good dryer and worth changing the motor on it.
Jan 25, 2014 | Dryers
The dry heats up great but the drum does not turn. Is the alot to fix and is it worth the money to fix this dryer
Good Morning, If the drum will not turn you may have a broken belt or one that's getting to the point of breaking. You can unplug the unit or turn the breaker off and remove the back. This will give you a view of the drum and belt. You can the plug it in being careful not to touch the wiring and see if the motor is turning or you will see the belt as it is rapped around the drum. If the motor pulley is not turning with the belt on, the motor is faulty. If it is turning and the belt is broke or having a rough time moving the tub it more then likey could be the belt, if it is not broke. If you determine that the motor isn't turning, then it may not be worth the $ to replace with labor + Parts. If it is the broken belt only, it may be worth the cost, you can call around.Take into consideration the age of this dryer also. I Sincerely hope this has given you some direction to follow.
Shastalaker7
Nov 27, 2009 | Frigidaire GLGR331A Gas Dryer
When pressing the start botton it hums but will not spin. This is on a Kenmore dryer
Remove the rear panel and check to see if the belt is broken. If it looks ok, try to turn the motor by hand. If ok, watch while the machine is tried--if the motor turns, but the belt doesn't move, then check the belt tensioning idler for a broken spring. If the tension device is pulled to it's stops and the belt is still loose, replace the belt. The front panel must be removed to access the belt which passes over the top of the drum. Hope this helps.
Oct 28, 2009 | Dryers
Past few days, dryer got very noisy. Then drum
The noise is coming from a moving part. There are only a few that normally cause a problem. Also the dryer drum not turning freely is what broke your belt. Here is what I would replace. Drum rollers, Drum slides and idler pulley. You can check these parts before you replace them. If the drum rollers don't spin real easy, replace. If the idler pulley does not turn easy, replace. If the drum slides are worn, replace. Your model may be one with a front drum bearing. If it looks worn, replace.
You may be able to take dryer apart, try turning drum. Listen for the noise and notice if the drum is hard to turn. If so, you may be able to determine if the problem is in the front or back of drum. Keep on mind that the noise might have been the belt slipping due to the drum being hard to turn. Either way, when you have it repaired, it should run with the noise. Good luck.
Oct 16, 2009 | Kenmore 400 6943 Dryer
Gas dryer doe not rotate
It could be that the motor/drum belt has slipped off the pulley, or has broken.
You can unplug the dryer and pull it out from the wall and remove the rear access panel to see if you can see the belt and whether it has broke or slipped off the motor pulley.
If you need to get a replacement belt, you can get locally or online at several sources. If you want to attempt the repair yourself, you might want to look at how your dryer is put together. Go to searspartsdirect.com and enter in the full model number of your dryer and you'll see what it looks like and see a list of all available parts,
Just so you know, it will take some time to disassemble the dryer in order to get the belt installed and you'll likely need a hand getting the belt onto the drum once you get everything taken apart.
Hope this helps and best regards!
Aug 01, 2009 | Whirlpool Dryers
The drum doesn't turn on my dryer, why?
A couple of possibilities:
There is a belt that goes around the dryer drum. It may have broken or slipped out of place. If you remove the top of the dryer (usually pretty easy), you will probably see the belt going around the middle of the drum. (If not, maybe it broke.) It is loose? If so, it probably slipped off the motor or is broken (as you may find if you pull on it). If all this seems ok, you need to remove the front of the dryer. That's usually a little more complicated, but not too bad. Now you'll probably see the motor. On mine, it is on the lower right. Does the belt go around the motor pulley and the drum and is tight? If so, maybe the motor is broken.
At this point you need to know if the motor works, but that may not be really easy because opening the door usually breaks an interlock switch that stops the motor from turning. But if you are careful, especially with electricity, you may be able to bypass enough things to see if the motor turns. Alternatively, note the exact position that the motor pulley is in (mark it if necessary). Then reassemble the dryer, try to run the motor, and then open it again. Did the mark move?
At this point, you probably have enough information to see what needs to be fixed or replaced. One additional problem I had was that the motor pulley was slipping on its shaft. If a plastic/nylon part has broken, you may need to replace it. Of course, if the motor isn't turning, make sure that nothing is jamming it somehow (like a stray sock tightly caught in the belt). Hope this helps.
Jun 21, 2009 | Kenmore 62602 Electric Dryer
Asko superior 7004 heats, but drum will not rotate.
Sounds like the belt is broken. See if there is a trouble door in the back so you can inspect the belt. If it is broken, get a new one from the dealer, and ask for instructions for replacement. If you can only get the belt, google your unit for more help.
May 07, 2009 | Asko Dryers
Dryer won't start
Same thing happened to my same model. Pull out from wall. Remove lint filter. Take out two screws holding top to lint filter casing. Pry up top at the front (pops out of two plastic retaining dowels and is hinged on the back so you can tip the top up. Remove front panel by taking out two screw-bolts at top of backside of front panel and lift up -- careful to support drum as you do as the front part of the drum is supported by the flange built into the front panel. Check:
1) Is belt broken (the incredibly skinny belt that runs around the middle of the drum, not the rubbe track at the back of the drum). If belt is broke, replace. New belt at internet parts stores is about $10 bucks.
2) If belt is not broke, get down on belly with flashlight and find the spring-loaded wheel that keeps the belt snug against the motor pulley -- put the spring-loaded wheel and slip the belt off.
Now try to spin the motor pulley by hand. If it turns freely in both directions, it is probably good and the problem might be in the start switch (don't know how to test that).
If the motor pulley does NOT turn -- or is very hard to turn and binds -- the motor is dead. Probably the bearings burnt out (that's what happened to mine after only 4 years of light use). You have to remove the back panel to replace the motor, but it's a simple job if you know what a screwdriver and socket ratchet are for. New motor at internet parts stores is about $80 bucks.
Mar 27, 2009 | Dryers
Ge Cloths dryer will not stay running or turn drum
probably broken belt some dryers have broken belt switch that shut dryer off if belt broke
Nov 25, 2008 | GE Dryers
Maytag MDG3000AWW drum moving slowly
If the belt looks worn you should replace it. But it sounds like the idler pulley has gone out of position or possibly broken. The idler pulley adds tension to the belt and keeps it from spinning on the drum surface. Check the path of the belt on the bottom of the dryer. That is where the idler pulley is.
Feb 01, 2008 | Dryers
Dryers Logo
47 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
