Question about Yamaha Music
No sound when piano keys are pushed on my Yamaha dgx-620
I turned it on with the keyboard wire strip pluged in upside down,now it won't respond to the keys but still plays songs and the display seems to work ok.
  • Tom Hagen Apr 28, 2009
    Yes that is correct,It is aYamaha dgx-620
  • Michial Gueffroy May 11, 2010
    What model Yamaha keyboard are you asking about? Did you have it apart and reassemble it with theconnector upside down? In other words did you have the key assembly disconnected from the other circuit boards?
    President:
  • 1,138 Answers
I'm sorry but it sounds like you will have to have it repaired professionally.
Posted on Apr 28, 2009
Piano does not work no sound can be heard power supply is on display is proper too. if head phones are used i can hear the sound. but no sound can be heard without headphones tried to play a song through...
I could not find the schematic for this, but other Casio units use a common voltage regulator amplifier chip to drive the speaker... I would firsst check that leads to the speaker have not become disconnected.
Jul 19, 2011 | Casio SA76 44-Key Mini Personal Keyboard...
Volume on the piano is less than half the volume it should be. Demo and play along songs play at full volume but keyboard wont no matter how hard the key is pressed, Is there a fix for this...
Pianos do NOT respond to keys pressed hard... they respond to FAST presses. If you have an issue with the piano, first go on record to activate your warranty. Most of these electronics DO have a setting that adjusts the "feel" which affects the loudness versus key velocity... Now here is a secret??? Shh... The manufacturers turn up the demos just like the advertisers turn up the commercials on the TV... I would suggest looking for the adjustment of feel, and if that doesn't get satisfactory results, find another and compare yours to another... if yours is still underperforming, exercise your warranty for repair or replacement.
Jun 11, 2011 | Williams Encore Digital Piano
My keyboard keeps shutting off within a minute or two of playing. The woman I purchased it from told me that it had an auto-off battery saving mechanism if you don't touch a key for a while, but this...
If you are running on batteries, they are either depleted OR may have corrosion on the contacts in the keyboard which is COMMON problem. If using an adapter, the cords chronically work loose. A last problem is the switching for using battery or adapter can have poor contacts. If you don't have an adapter, get one and get one SPECIFICALLY for the keyboard... I don't know how many I have had to tell they have the wrong adapter and that is why their unit won't work.
May 15, 2011 | Casio CTK-720 Electronic Keyboard with...
I have a casio lk-44. I want to be able to play a song from the songbank, but just hear the background rhythm and not the melodies. I want to play the melody myself from the songbank. When I pick a song...
Not sure if your "booklet" is the full user manual... if not go to this site and go through their "hoops" and download the full user manual. It shows how to put the unit in the mode that merely lights the keys and plays the rhythm, unlike the "demo" mode.
http://www.retrevo.com/support/Casio-LK-100-Music-Keyboards-manual/id/467dj395/t/2/
Note the manual is free via the Retrevo site... just have some of those annoying hoopps like email address and entering numbers.
Mar 21, 2011 | Casio LK100 Lighted Keyboard With LCD...
The fonts on my digital interface on my keyboard are sometimes upside down
I will note that MANY of the "smart" LCD displays have the ability to turn the displayed information upside down by either a command or a jumper. I did NOT find any parameter you can set in the Juno-Gi to set this in the manual... it is a mystery... Possibly there is a cable to the LCD that is loose. You need to correlate when this happens to other events or actions to narrow down the problem.
Feb 11, 2011 | Roland JUNO-Gi 61-Key Mobile Synthesizer...
I have a CDP-100 and need disassembly instructions for access to internal keyboard assembly. Unit was dropped while unloading from car. Now some keys are akimbo and won't play as though they are off their...
I just fixed my CDP 100 which had a similar problem - dropped and two keys not working up one end.
1. Lay keyboard upside down on soft surface. Under keyboard is plastic cover held on by 17 screws. Remove all these and lift cover away. The metal key ends are all revealed.
2. Locate the disloged keys. Carefully press them back into position - they will "click" into place. Make sure the corresponding key on the keyboard isn't stuck in an "up" position - you may have to remove the metal key part and replace it again while making sure the key is correctly seated.
3. Replace cover and screws.
Feb 22, 2010 | Casio Music
I have a Yamaha YPG-525. Everything is working except the LCD screen. It turns on, but doesn't display anything... I had this problem once before when I didn't use the keyboard for a while, but it ended...
I have the same problem, mine is Yamaha YPG-625. This seems to be a common problem with Yamaha keyboards. I opened the 100 screws in the back, separated the main board from the display unit which is under it if you flip the keyboard upside down, to verify if there was any loose wires, nothing of the sort.
It is so frustrating, the keyboard is working fine but it is hard to navigate because the display is not functioning. Yamaha should do a recall as this is obviously something wrong with the keyboard happenning to a lot of people
Jan 08, 2010 | Yamaha Full-Size Keyboard
Kurzweil Mark 10 keyboard stopped working
Try the reset procedure on page 5 ( last page ) of this pdf document:http://www.dgaudiorepair.com/PDF%20Files/HARD%20RESET%20for%20Current%20KURZWEIL%20.pdf Hope this helps. Note the first procedure says highest white key. I'd do the second procedure.
Aug 27, 2009 | Music
Roland Juno D Keyboard Keys not sounding
The problem of the Juno-D is de rubber strips inside under the keysthere are 5 strips, you have to clean this rubber strips with alcohol and clean the board too, this will resolve your problem if you leave the Juno-D without playing for a long period you will get the same problem again. this is a very poor keyboard it,s a pitty that Roland Make so poor keyboard!!!!
Dec 16, 2008 | Music
Yamaha digital piano clp 170
This is a common problem with Yamaha keyboards. The problem is caused by worn-out rubber contacts in the keyboard assembly. In my old Clavinova CLP-500, there was one long rubber contact strip under the keys with two parallel strips of semiconductor material. The Clavinova circuitry determines key velocity by measuring the timing between when the key hits the first and second strips of semiconductor material. The harder you play a key, the less time it takes the key to hit the second semiconductor strip after hitting the first.
After years of playing the keyboard, the keys eventually cause tears in the semiconductor material and this messes up the timing measurement for key velocity. The only solution is to take the keyboard apart and replace the rubber contact strip with a new one.
I got rid of my CLP-500 four or five years ago and got a new CLP-170. The CLP-170 is now having exactly the same problem that the CLP-500 had. Yamaha has re-designed the rubber contacts in the CLP-170 so that there are now eight individual contact strips instead of one long one. The problem is essentially the same, though. You have to take the keyboard apart and replace the worn out rubber contacts.
Here are the part numbers for the rubber contacts that need to be replaced in the CLP-170: V8286600 Rubber Contact, 12 keys, D-C#   Qty. 6 V8286800 Rubber Contact, 11 keys, A-C#   Qty. 1 V8286700 Rubber Contact, 5 keys, D-C   Qty. 1
I suggest you also get a copy of the CLP-170 service manual, part number 001677. It has descriptions of all the steps necessary to take the thing apart and put it back together again. You'll also need a "rod" (which is just a long dowel), part number TX000670. Before you take the circuit boards off the keyboard assembly, you have to insert the dowel between the keys and the frame to keep the keys from falling back and getting in your way. A 5-foot long 1/4-inch dowel will probably work. (I haven't yet taken apart my CLP-170, and I don't have Yamaha's "rod," so I'm not sure if 1/4 inch is the right size or not. I'll report back here if it's not.)
Good luck, Howard
Sep 03, 2008 | Yamaha Full-Size Keyboard
Music Logo
947 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
