Question about Canon Office Equipment & Supplies
Hi my 6020 canon copier just copies part of the document most of the time. a full document is ussually made only when there is a pose after the paper is picked from the tray. I have a bit of technical know-how. please assist
  • 3 more comments
  • friday_chaza Apr 22, 2009
    That is exactly the problem i am experiencing. the paper is just pickup straight without a pose resulting into a copy being copied half way.
    There are instances when there would be a pose and a copy comes out perfectly.
    There are also times during paper pick up on the by pass when a funny clicking sound would be heard.
    I will greatly appreciate your technical advise.
    regards
    Friday Chazanga
  • friday_chaza Apr 23, 2009
    Hi Bob,
    Thanks a lot for the technical explanation. It surely sounds very true. I will work towards that and will let you know of any development.
    thanks alot.
    Regards
    Friday Chazanga
  • friday_chaza Apr 27, 2009
    Thanks a lot fixya to your highly qualified team, my problem has been cleared. Thanks to Mr. Bob in particular for his technical expertie.
    All the best.
  • hinderschied May 11, 2010
    sounds like the registration roller isn't stopping, if so the top of the copy will start somewhere in the middle of the page. Is that sound like what you are getting?
  • Angry Milton
    Angry Milton May 11, 2010
    What does the bad page look like? Does it have a clear band running portrait or landscape? Are there any odd sounds when the pickup rollers grab the page?
    Sniper:
  • 67 Answers
Hi Friday,
I'm not exactly sure what the Canon 6020 is, but they all pretty much work the same. Canon used to have NP and PC lines, IR for Image Runner and IC for Image Class, but that's not important. They all use timing to get the image on the page properly, by using a registration roller,and that's where your problem is. The registration roller is a paper feed roller in the paper path just before the image gets tranfered from the drum or cartridge to the paper. Most machines use a transfer roller, which is usually a black foam roller right under the drum or cartridge. The roller just before that is the one we are looking for. That roller is supposed to only spin a a certain time, usually controlled by a solenoid, and has a plate that grabs a plastic piece that's attached to the drive end of that roller. That plate is spring loaded on the solenoid and may have popped out of place and just may need to be reseated.
The bypass usually uses the same registration roller but the timing may still be better with the bypass. Any way let me know and good luck
Bob
Posted on Apr 22, 2009
How do i download and install my philip laser mfd 6020 printer
Go to Philips.comsupport, and click on "contact". Have the full product number available. Pose your question to Philips. Usually going directly to the source, will bring you the best results.
Jan 04, 2015 | Laser Office Equipment & Supplies
IR4570 paper jams at fixing unit whenever i try to make copies of A4 double seded. Legal is ok. problem repeats for every 6to8 copies after clearing the jamed paper.
first clean all rollers espc. below the drum unit two rollers on axis, if the paper comes out bent in the roll open fresh pack of paper because of moisture, when you open the right door above fixing unit you will see one more small door that is loosen, on these inner door you will se long plastic flapper ( ussually black plastic with small picker fingers ) that is connected to solenoid, these flapper has on both sides some kind of sponge sticker on left and right space where it touch the inner door - REMOVE THEM.
Hope that helps!
For service manual write me on emma.servis@gmail.com
Sep 09, 2010 | Canon Office Equipment & Supplies
The ink cartridge in my Canon MultiPASS F50 ran out. I replaced the cartridge correctly, but now when I try to copy a document using either the laser copier or the fax part of the machine, the papers come...
...I try to copy a document using either the laser copier or the fax part of the machine...
These isnt laser copier, you probably refer to scaner assy... but never mind.. lets solve your problem!
First, new inks are reffiled or original?
Remove inks and look for small hole, ussually on top of crg. and blow in it verry hard.After that from crg. must start to drop ink. Put the ink back in and try to copy/print something.Also run head cleaning for few times.
If now it works that could mean two things:
1) the ink was for long time on warehouse, and nozzles are clodged.
2) your purge unit is faulty and it cant drain ink from crg.Replace purge unit, wich isnt cheap solution.
Or,... buy new LASER Canon multifunctional copier that uses TONER.
Hope that helped!
Aug 09, 2010 | Canon Office Equipment & Supplies
Unable to print to canon IR7200
More than likely their is a problem with the file or that it is too large to process and has gotten stuck in the que on the copier. Go into printer set up and find restart server or clear server - it's ussually at the back end of all the settings. You want to clear the server and restart it. Then try printing a few pages of the file to see if their is an issue with it. If that prints then print half of the file, if it's has a lot of graphics pick a smaller chunk. You can also restart the server through the copiers internal web page - to get to that type the copiers ip address into internet explorer and it should bring it up.
Dec 26, 2009 | Canon Office Equipment & Supplies
Canon Imageclass D880 automatic document feeder problems
Clean the ADF rollers and pad with alcohol.
Check to see if your ADF has done over 90 000 copies and if it has, change the ADF pick up assembly only.
Good Luck
Oct 19, 2009 | Canon imageCLASS D880 All-In-One Laser...
Copy is printiny a shadow of the document also.
check your printer head try to clean or clean it..
any further question let me know ok..
thanks,
Mar 16, 2009 | Canon PC1061 Copier
Users Manual
the ADF is the automatic document feeder the part on top of the machine that you insert the paper to Automatically feed the paper in one at a time, there may already be a document on the glass lift the top and put it back down it should clear
Jul 31, 2008 | Canon PC-1060 Black and White Copier
Coping from Canon MP610
Unfortunately this model does not have document feeder on top. So you can only do it one sheet at a time. I think the 31ppm indicates that you can print 31 copies of one document in one minute. The models above this tend to have document feeders for this purpose but not the mp610.
Good luck.
Please rate my advice, good or bad.
Feb 01, 2008 | Canon MP610 Photo All-In-One Printer
107 people viewed this question
old marine
old marine
