Question about Epson Stylus RX500 All-In-One InkJet Printer
Poor printing from my printer
When I am printing, I get colored horizontal lines across my black and white photos. Prints fine on normal paper documents.
  • Epson Master
  • 705 Answers
Hi D
First off review my previous post about under head cleaning and follow the process through. Make sure you have no build up of fluff or a small piece of paper stuck below the head.
Once you have completed the under head cleaning cycle, let me know what difference is made via this post. Further wirk may be needed
Posted on Oct 18, 2007
Have put new cartridges in and only prints yellow lines
Remove all cartridges, make sure any tape has been removed from over the nozzle. Ensure that everything has been installed properly, then use your printer (prompts on device, or in printer>control panel) to print some test pages, realign heads, etc.
May 05, 2011 | Canon Computers & Internet
Problem with printing black and white photos
Probably what happen is that you are printing black and white but you have your printer on color mode, try to set the printer to grayscale or black and white before print. The printer is tring to get the black and white by mixing all three color, that is the most comon way of make black, so, when one of the color is missing you see those red lines.
Also you will solve the problem replacing the color cartridge.
May 19, 2010 | HP PSC 1510 All-In-One InkJet Printer
Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Feb 12, 2010 | Canon PIXMA MP980 All-In-One InkJet...
Prints have a thin white line across all the images printed. Everything else works and prints are ok outside of the thin white line running horizontal across the 5x7 prints.
  • Thermal head — generates heat; prints on paper
  • Platen — a rubber roller that feeds paper
  • Spring — applies pressure to the thermal head, causing it to contact the thermo-sensitive paper
  • Controller boards — for controlling the mechanism
I think that you may need to replace your thermal head, A line means there is a place that the head can not head or it cannot recieve data
http://www.youtube.com/watch?v=LWs74J7EfjM
How to matinence it and clean the head
Oct 21, 2009 | Sony UP DR100 Thermal Photo Printer
Printing black horizontal lines below text/on top of pictures
Check the waste recepticle under where the ink cartridges rest in the home position. Over time, ink sprayed into this cup during cleaning cycles builds up to form a small mountain of congealed ink. If this gets too high, it makes contact with the printhead and drags ink across all your prints. If there is a ***** of ink present, scoop it out with a spoon or a popsicle stick.
Dont get it on you, its messy...
Jun 22, 2009 | Dell 924 All-in-One InkJet Printer
Light purple cast to black and white prints
Known issue. Use QTR to print bw prints. Works great on my Epson 2200.
http://www.quadtonerip.com/html/QTRoverview.html
Dec 06, 2008 | Epson Stylus 2200 InkJet Photo Printer
My photo prints have lines across them?!
the glossy paper you are using (hp) is smearing the ink... there is now ink on the feed rollers and you need to get in there and clean it all up with alcohol...also run epson matt paper for a few prints to get the color to lay down ..good luck
Oct 08, 2008 | Epson RX620 All-In-One InkJet Photo...
Multiple Problems Printing
Replace the print head, and all should be just fine.
Jan 06, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Horizontal line on prints
Put plain paper in the printer and try to clean the nozzles.
-Start->All Programs->Lexmark 5400 Series->Lexmark Solution Center->Maintenance->Clean to fix horizontal streaks.
Steve
Sep 12, 2007 | Lexmark X5470 All-In-One InkJet Printer
Epson Stylus RX500 All-In-One InkJet Printer Logo
74 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
