Question about Honeywell HE365 Humidifier
I have random pipe shocking heavyly.
I have random pipe shocking heavily while the fan was set at the auto. the shocking disappear when I turn off the heat system.
  • 308 Answers
It sounds like your solonoid valve on the humidifier was slamming shut cause the water hammer, no call for heat, no humidifer.
Posted on Jul 17, 2009
  • Keith Fournier Jul 17, 2009
I have a Whirlpool AD70U dehumidifier with type 3 controls. I have the fan set to auto and the humidity to normal. The unit drains into a floor drain. It seems dry in my basement yet the fan seems to run...
If it's set for Continuous Mode the fan will run all the time. It does so, in an effort to keep recycling the air. Once it senses a rise in humidity, the compressor turns ON. Check the settings, to be sure it's where you think. Also, check and clean the air filter, if necessary. Before removing the filter, be sure to turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet. If you wash the filter, it most be completely dry, before reinstalling it. Do Not operate the unit without the air intake filter installed.
Make sure you are maintaining at least 12" - 18" clear air space around the entire unit.
To further assist you, in case you have misplaced your Owner's Manual. I have included a link to it, that you can download and print for future reference.
https://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%201188826.pdf
I hope this helped you to further troubleshoot and solve the problem.
Jun 21, 2011 | Whirlpool AD70U Humidifier
How to install an ace hardware saddle valve on 3/4" galvanized pipe?
You need to turn water off. Release pressure on system by opening a faucet or something. Drill a hole in galvanized pipe slightly larger than piercing needle on saddle valve. Open up piercing valve so it extends out, that way you can see it go in previously drilled hole. Finish valve like you would on copper pipe. Keep piercing valve closed until 1/4" pipe is done being hooked up. Turn on the previously shut off water valve
Jan 26, 2011 | Humidifiers
My aprilaire humidifier is 30 years old. Put in when the original furnace was installed. The water seems to be running through it and I have had the pad replaced, but I am still getting a lot static...
If the humidifier has a 6" duct on one side, this must be open in winter you should find a handle, if there is not any label, move it so the handle is parallel to the ductwork.
If the humidifier do not have a duct on one side, it must have a fan, if you can't hear it working, probably is time to get a new humidifier, and make sure contractor check furnace heat exchanger for CO2 leaks.
Jan 15, 2011 | Humidifiers
Aprilaire 550 clunks on shut off. Never did this before. Changed the saddle valve and Solenoid. Checked copper water line for possible vibration on a pipe, nothing. I'm stumped
Thank you for contacting us regarding the "clunk" sound you are experiencing with your Aprilaire 550. The noise you have described is called water hammer. Water hammer is a pressure surge or wave resulting when a fluid in motion is forced to stop or change direction suddenly. Water hammer occurs when the solenoid valve closes at the end of a humidification call. To prevent the sound of water hammer, we recommend contacting your heating & cooling contractor to install a "shock arrestor" part number 4280. This device is installed between the water pipe and the solenoid valve and will absorb the shock and stop the banging. Please contact your heating & cooling contractor or our Customer Service Department if you have further questions. Kind Regards, Jessica Garrett Customer Service Specialist Research Products Corporation
ww.aprilaire.com
Oct 30, 2010 | Aprilaire Humidifiers
Dry house with furnace mounted humdifier
Is the furnace fan set on auto or on. You will get better humidity if you keep the fan on. It won't add much to your electric bill because many of the newer furnaces operate the fan on DC voltage. Try it!
Jan 16, 2010 | Aprilaire 700 Humidifier
Water is running thru inlet pipe but does not seem to come out of the outlet. I am unable to detect any clogging
There is a strainer that is on the inlet side of the solenoid valve you may need to pull it out to check if it is clogged. Also when you have the humidistat turned all the way up do you hear the solenoid click and the fan inside running
Dec 13, 2009 | Aprilaire 700 Humidifier
Squeeky humidifier when turn on . Squeaks at random times. Sometimes we have to completely turn it off because it is so bothersome.
Hard water particles will build up in the fan bearings and cause the squeaking. Unplug the thing, and locate the fan motor(s). Place a few drops of 3-in-1 oil on the bearings where end of the shaft is mounted on the motor. This will lubricate motor, making not only run quieter, but faster, cooler, and more efficient.
Nov 02, 2009 | Humidifiers
Looks like my humidistat calls for coil fan and for furnace heat
It sounds like the humidifier may be improperly wired.
It's hard to solve without checking the wiring, but it seems like the humidistat is wired so that as the dial is advanced, it incorrectly turns on the fan, or furnace, or both.  The contacts of the humidistat should be wired so that they turn on the solenoid only.  Also, the power to the humidistat, to turn on the solenoid, should come on only when the fan is on.
Hope this helps!
Jan 03, 2009 | Aprilaire 550 Humidifier
Humidifier won't turn on with furnace fan set to Auto.
There is a devise called a current sensing relay (a little black box that hangs on a blower motor wire that senses current from that wire) If you have such a devise it should hang from the white (common) wire. Loop the wire through twice.
Nov 23, 2008 | Aprilaire 600 Humidifier
J-
I had this problem several years ago. In order for the water to flow, the outside temperature sending unit must indicate to the controller that it is less than 60F. If not, the unit will not operate outside of test mode. Check the temp outside where your sending unit is (could the sun be heating that side of the house?) and ensure that the circuit to the sending unit is working. I had a bad wire splice inside a wire nut stopping the circuit. Took me a long while to figure it out.
If the outside temp and your sending unit circuit is ok, I wish you luck on your troubleshooting.
adx_98
Nov 10, 2008 | Aprilaire 600 Humidifier
Honeywell HE365 Humidifier Logo
77 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
jdthefixer
Bill Long
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
