Question about Microsoft Xbox 360 Console
Two rings on xbox
What can cause this and how can it be fixed? Already sent xbox360 away in january for three rings now we are getting two rings!! Please help us!!
    Novelist:
  • 174 Answers
This is due to overheating but cleaning dust out wont help you much, this happens when the machine overheats and the mainboard warps, because of this the lead free solder cracks and causes exactly the problems you are describing. if the machine is quite an old one and this is a common fault, we can get the machine back to normal again for you for £40 which includes return delivery.
We reflow the mainboard which in turn re-seats all of the lead free solder recifying any problems. We add heat conducting pads to the memory chips and we totally replace the X-clamps because the design is a flawed one.
All of this is covered in the price.
www.fixmyconsole.co.uk
Posted on Apr 21, 2009
My 360 has 3 rings the rings are red and it wont turn on
The three red lights mean that your XBOX360 is experiencing hardware failure. This is caused by overheating of your XBOX. Contact Microsoft and have them fix the problem. They have given free extended warranty for three red light problems. If you have bought your xbox360 within 3 years, you're in luck.. They will fix your console for free...
Mar 13, 2010 | Microsoft Xbox 360 White Console
Three red rings on xbox360
  Can u pronounce good English? Read along: woof, roof, loof, shoof, shoof, woof,  loof, poof, woof, woof, hoof, loof, roof, shoof,
  Test results: U r a good dog. Now stop barking.
Oct 02, 2009 | Microsoft Video Game Consoles & Games
Rings of death
the "3 rings of death" or the so called "3 red lights" is actually caused by GPU overheating and mainboard flexing. When you need to do is open your xbox360 (warning, this will void your warranty) add more cooling fan inside your xbox360, you'd want to use 80mm fans coz they fit perfectly. you can fit up to two 80mm fans inside your xbox360.
Also, if you notice that your xbox360's mainboard is warped you need to fix this by disconnecting all the connections from the board. then place the board on a flat surface. then use a hair drier to heat the board and flat it out. its kinda complicated. hehe, at least you now have an idea on whats causing the 3 red lights...
May 01, 2009 | Microsoft Video Game Consoles & Games
Xbox 360 3-red lights may be caused by DVD drive? Help please!
your 360 is a first run off assembly. they were junk from the start. my warranty expired also but called microsoft and they said if the ring of death is related to the first run of 360s they willextend the warranty. exactly what happened to me. 8 days later they sent me a brand new 360 cause problems with the first run 360s can't be properly fixed. contact them tell them the problem and you will get a new one. hope this helps Tadster
Apr 15, 2009 | Microsoft Xbox 360 Console
Ring of death on xbox360
turn it in to xbox. they will fix it.
Dec 23, 2008 | Microsoft Xbox 360 Console
Xbox360 repair price
Hey Javon,
From my experience you only have to pay to get it repaired if you're out of the warranty. However, I don't believe you should have to pay regardless if the problem you get on your xbox360 is a problem caused by Microsoft's design. IE.. The overheating issue.
But, if your laser goes bad, DVD drive door isn't opening and things of that nature, it's not out of the question since alot of those problems could be caused by something the owner of the xbox has done.
Dec 18, 2008 | Microsoft Xbox 360 Console
Xbox360 and the 3 red lights
Three of the lights on the Ring of Light on the front of your Xbox 360 console flash red View products that this article applies to. if (!loadTOCNode) {var loadTOCNode = function(){}} Expand all | Collapse all if (kb_page_object) { kb_page_object.kb_imageExpandHoverText = 'Click to expand this image'; } SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Dec 06, 2008 | Video Game Consoles & Games
THREE RINGS
I'm sorry to hear that this is the fourth time this has happened, but you have just been unlucky. Like everyone else who has experienced the Red Ring of Death, your system is too damaged for you to fix. You will have to contact Microsoft and have it replaced. You can either call 1-800-4-MY-XBOX (1-800-469-9269) or go to their support page (posted at the bottom) and click 'repair console.' Again, terribly sorry this has happened to you and hope that it doesn't happen again.
http://support.xbox.com/support/en/us/xbox360/default.aspx
Nov 15, 2008 | Microsoft Xbox 360 Console
Ring of death
You can try fixing it by taking out all of the plugs in youre xbox 360 and then plugging them back in but it very rarely works.But this happended to me and my problem was my hard drive wasnt in all the so that might be youre problem.but what my best sultion is just to call 0800 587 1102 for were to send youre xbox to get it fixed.It sucks that you have to send it away but it will be fixed it will take about two to three weeks to get fixed and sent back but it is worth it.
Sep 12, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
133 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
