Question about Sony Playstation 3 (PS3) Console
When you press the power button it goes green and then yellow and then start to flashing red
  • Anonymous Apr 20, 2009
  • pc3644 Apr 21, 2009
    I have the same problem
    Problem Solver:
  • 15 Answers
Your system has overheated. In many cases anyways there is really nothing you can do about it either.. Usually the fan stops working and the thermal paste between the heatsink and processors gets dry and causes the chips to burn up..
Posted on Apr 22, 2009
After pressing the on button it turns green for 5 seconds then it flashes yellow/orange for a second then it flashes red.
Yellow Light of DeathThe "Yellow Light of Death" or YLOD is the common phrase people use to describe the following sequence when they try to turn on their PS3:
  • Press Power Button
  • Red Light Flashes Three Times
  • Yellow Light Flashes
  • Green Light Flashes
  • Beeps Three Times
  • Red Light Flashes
The sequence above may vary a bit but you do see the flashing yellow light (sometimes shows up as orange) that normally you would not see when operating your PS3. The YLOD is a general hardware fault that can mean a lot of things. However, one of the problems is cracked solder that leads the PS3 to think one of its internal chips is not connected or is broken somehow. Cracked solder can happen when the chips get too hot (RSX most likely) and leads the motherboard to start bending, which may crack the solder. Changing the power supply (lower the average wattage going to the chips to lower the heat) and better thermal compound (heat dissipates faster to the heatsink) may prevent this error from occurring. However, if your PS3 has already had the YLOD, then you can reflow your motherboard every few months to keep it working (but it is not a permanent fix as the YLOD usually comes back).
Oct 09, 2010 | Sony Playstation 3 (PS3) Console
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
PS3 wont start up has a flashing red light
That happend to me and i gave it a rest for a couple of days and it worked again
Jan 01, 2010 | Sony Playstation 3 (PS3) Console
Turned the power button on turned yellow and flaSHED RED
You will need to have the motherboard reflowed. The processors have probably come unseated from overheating.
Oct 07, 2009 | Video Game Consoles & Games
Wii Console will not turn off. After pressing the Power off button the console light goes from green to yellow (not red.) After about 5-10 minutes the blue light will start to cycle on and off and the game...
try turning it off on the console and not with the controller. turning it off with controller turns it yellow. press and hold the power button on console for 5 seconds it should turn red.
Jun 30, 2009 | Nintendo Wii Console
PL-CS55 headset lifts receiver but only get buzzing sound in
Try a system reset:
1. Lift the headset off of the charging cradle (the base).  Make sure the headset is turned off.  The green light on the base won't be on if the headset is turned off. 2. Hold down the call answer button on the headset at the same time as mute button.  The mute button is found on the little black wheel on the top of the headset.  Use the tip of your finger to push it straight in. 3. Hold both buttons until you see a green light on the headset flash.  It will be right below your thumb.  Hold both buttons until the green light flashes for a series of 2 flashes.  Then let go of both buttons. 4. Put the headset back on the charging cradle and wait 30 seconds.  Lift it back off and try again. 5. If this doesn't work repeat the process once more or try a resubscription.
Resubscription procedure:
1. Put the headset back onto the charging cradle.  Make sure the red light on the base is on and the yellow light is flashing. 2. On the back of the base there are two buttons for the microphone adjustment that can be pressed down.  Press both of those down until the red light and yellow light on the front of the base start flashing. 3. While the headset is still on the charging cradle press and hold the mute button until the red light on the base goes solid, and the yellow light stays flashing. 4. Unplug the power to the base and then plug it back in. 5. Wait 20 seconds and try.
Apr 22, 2009 | Plantronics PL-CS55 Wireless Headset
Powering on
OK ... after a lot of trial and error, I got mine to work. I think it may be a really low charge or something. I had to press the power button until it was completely dark ... no flashing faint green or any colors. Then when I plugged it in, I got a solid red and left it for awhile. Then when I pressed the power button I got yellow, red and green ... the computer recognized it and then got a solid yellow.
Before when I had it plugged in, I'd get a lot of red random flashing ... and it just didn't seem to charge at all ... even after a full day.
I think the issue was that it was in this "flashing state (red when connected, very faint green when disconnected)" It wasn't easy to get it to turn off completely. Most of the presses of the power button didn't change the state at all. But if I got it just right, I could see the faint green light go off. That's when I plugged it in and got a solid red light, and eventually a good charge.
Hope this works for some others.
May 23, 2008 | LeapFrog FLY Fusion Pentop Computer
Sony Playstation 3 (PS3) Console Logo
97 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
