Gps wont work it is frozen
I only used the gps once and it worked fine. The second time it said error and the screen froze. I took out the map chip, unplugged it and waited and a few moments. It still is froze. Please help. Thank you, sprinkler
    Genius:
  • 1,153 Answers
Well Sprinkler, I have one also and had a similar problem. But I took SD card out and Batt. for 1 hole day and put back in first the batt and tried power up and it come on. I think my SD card caused the problem. Hope this helps!
Posted on Sep 21, 2007
It started working fine when leaving Disneyland, then just outside Las Vegas the screen froze. It said it was aquiring sat., but now it is frozen with LV map, arrival time, but no other information on it...
Have you tried holding down the power button for 10 seconds. You don't have listed what type of GPS it is so this is my only suggestion at the moment. My next suggestion would be to contact the manufacturer of your unit if its still under warranty Im sure they will make it right by you.
I hope this helps you out if it does please leave me a YES that I did try and help you. Thank you
Apr 08, 2011 | GPS
Garmin froze with a "Map Update Notice" the screen
The unit isn't frozen. If you tap the power button you will hear it beep and change screens. What has happened is your touchscreen has failed. This is a common problem. Your touchscreen needs replaced. If you want some troubleshooting info, please see this link. There is just too much info to retype here:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Mar 20, 2011 | Garmin Nuvi 660 GPS Receiver
Wont stop loading maps
If your garmin nuvi wont stop loading maps, then you need to reaet the unit to get it to work perfectly fine once again. Try to hold down the power button for about 15 seconds and the gps receiver will restart, this time it will load normally and show you your maps.
If that does not solve the problem, then you need to back up your maps then format your gps receiver from a computer then restore the software and maps back on, that should do the job for you.
Hope this helps.
Dec 23, 2010 | Garmin Nuvi 465T Car GPS Receiver
While using my Magellian GPS 1200 the screen froze up and when I went to restart it the following messang appeard.SD card has been removed.Program will restart.Please insert SD card with map. I tried re...
More then likely when the screen froze up on you it it had a little power glitch as well, nothing serious but it did wipe out some of the information in it's memory about the SD card.Power the unit up and let it come up with the error, then use the reset button. Might be hard to find since it's just a little hole with the word reset around it, using a paperclip push in the button and see what happens. If the error comes up again then i am thinking that you will need a new SD card. Quick test for this, remove the SD card from the gps unit and try rebooting, it should come up with an error, no SD card or no map, stick in an SD card from another device, 2gb, see if the gps can find the card, it should give you an error that says unable to find maps. If you get these error codes then most likely the gps unit is fine but it pooched your programs on the SD card.
Hope this helps
Apr 27, 2010 | Magellan Roadmate 1200 Car GPS Receiver
Froze and Fading Fast!
i have a nextar x3-08 i got problem like when i start gps then 4 icon display but i click on car icon its getting frozen i can't do anything with it. Another 3 is working like cd,camera,and setting icon. so, please anyone solve this problem
Aug 30, 2009 | Nextar X3 GPS Receiver
I just upgraded to 2009 US maps and the GPS voice has worked once
I had the same problem. I had to have the dealer reload the GPS software once I got back to the states. It took two tries, but once actual GPS software was updated with the U.S. software version it worked find.
Jul 26, 2009 | 2006 Volvo XC90
Turn on tomtom and it freeses screen with no maps found.
try doing a reset,hold button in for about 15 seconds,then try again if it still doesnt work try a hard reset,go to tomtom.com for instruction on hard reset
May 11, 2009 | Tomtom GO GPS Receiver
Frozen screen on Magellan RoadMate 2200T
Press the button to turn it off but hold it for about 10 seconds. Let go and then press it to turn it on. This resets it.
May 22, 2008 | Magellan RoadMate 2200T GPS Receiver
89 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
