Question about Xerox WorkCentre XD155DF Laser Printer
Toner Cartridge The toner is leaking/spilling out of the cartridge and ends up on the inside of the machine and on the edges of the copies. I have tried emptying the excess toner from the overflow chamber of the toner cartridge. I have also vacuumed out the excess toner from inside the machine. It seems to work for a few copies, but then the problem returns. What else might you suggest trying. Thank you.
XEROX TONER 5821 as soon as reqrements pleas sent the dealer rates
DUSHYANT BANSAL
32,radha bazzar near bishnoi mandir,HISSAR
email id:bansalsonu44@yahoo.com
phone no:01662272473
Posted on Mar 06, 2008
  • 163 Answers
CHANGE THE DEVELOPER IT HAS OLD,AND ALSO CHECK THE DRUM
Posted on Sep 22, 2007
Toner spills on papers, how do i solve it?
Is the toner still loose or is it fused to the paper?
If it's loose, you need to clean out the inside of the printer because toner was spilled inside. Don't use a regular vac, because you need a heppa type filter
If it's fused, there may be a couple reasons:
1) It could be a dirty fuser
2) It could be a failing toner cartridge, replace it
Based on your post, I would suggest replacing the toner cartridge first, as if the copies are faint, you are running out of toner.
May 10, 2016 | Office Equipment & Supplies
Change toner
Step 1 Check the top of your Canon fax/copy machine to see if your specific model has a protruding extension piece from the plastic delivery tray. Push the extension piece down if one is present on your model.
Step 2
Grip the bottom edge of the paper delivery tray at the front of the machine. Lift the tray upward to reveal the rectangular, plastic toner cartridge inside the machine.
Related Reading: How to Add Toner to a Canon X25
Step 3
Grab the handle at the top of the current toner cartridge and lift the cartridge upward. Pull the toner out of the machine and set it aside.
Step 4
Set your replacement toner cartridge over the empty space in the fax/copy machine. Ensure that the arrow near the bottom of the cartridge is facing down, and line up the protruding guide piece on the left side of the cartridge with the groove inside the machine. Push the toner downward until it snaps into position.
Step 5
Push the paper delivery tray back down, and lift up the extension piece if your model uses one.
May 06, 2015 | Office Equipment & Supplies
How do I clean spilled toner from the inside of a Kyocera mita copier?
Try using a small soft brush to brush it off while using a good hepa filter vacuum to remove the toner at the same time. Wear a good breathing mask to protect your lungs!
Aug 06, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
My Sharp AL1530CS Copier is sick. I have a Sharp AL1530CS Copier. It has been great but has gotten sick. I replaced the AL110TD cartridge recently with a generic cartridge and toner leaked from it
Your machine is jamming (flashing p) because the toner that spilled has made the rollers slippery and they cant pull the paper out of the paper tray.
Apr 07, 2017 | Sharp Office Equipment & Supplies
Sharp AL-1631 coper - toner problem
the problem in your machine is on the drum unit there is a arching on the mc unit.located in the upper portion of the drum unit.if you have an old drum unit try to install it again just for testing.and check if ther is a dumping toner again.
Nov 05, 2008 | Sharp AL 1631 Copier
Average useful life of Sharp AL-1661CS
With that machine the toner cartridge also contains developer. Without getting too in depth, it sounds like maybe your toner cartridge is leaking a bit of developer which takes with it a bit of toner. Developer is made up of tiny metal particles which are supposed to stay inside the developer unit. As the seals wear in the developer unit (which is part of the cartridge) it allows a little to leak out causing the problems you are seeing.
When you take the toner cart. out, at the rear side (part that goes the furthest into the machine) you'll see a white foam seal. If you notice some excess toner (and probably developer) sticking straight out from that, it could be that the seal has a jagged edge which is dragging developer off of the magnetic roller and depositing it on the drum making the line you speak of on the left hand side.
Also check to make sure the copier is sitting level, if it's not then the concentration of toner at one end of the developer unit is too great and some can be allowed to spill out.
So in short, it's probably not the drum that's at fault, it's more likely the toner cartridge.
Is it worth replacing? There's no easy way to answer that. If the machine is used in a fairly high volume workplace, it's probably worth replacing. If you could get by with a smaller cheaper machine (brother, HP, lexmark etc.) that does printing, scanning, faxing and copying you may be better off.
Oct 16, 2008 | Sharp AL 1631 Copier
Change of toner
I have a brother mfc 7840w
I first used the electrical tape trick and that worked for a while. Then got the toner low message again. I then tried the *00 trick, which works as follows:
1. lift lid and open front cover
2. press clear/back. "Replace Drum?" will appear on the screen.
3. Press "*00" it will then read accepted and the toner low error (End of Toner Life) should go away.
4. close it all up and your done.
Jun 08, 2008 | Brother MFC 7420 All-In-One Laser Printer
Printing line on the right side of paper
I am unsure of one thing in this post, Is the new toner cartridge still spilling out ink and developer?
Now, from there, you need to get a vacuum with a crevice tool and vacuum the inside of the machine very well. There are ridges and stablizer brackets formed into the frame that the toner and developer fall into and sift out onto the paper.
If your cartridge is still dumping the developer and ink from the same end, I highly suspect the machine is not level from front to back and as the machine runs the toner and developer are moving to that end of the cartridge. Once that happens that cartridge will spill the contents out into the machine.
A thorough cleaning is needed, and even at that, it may take some time for all of the contamination to run itself out. It is difficult to remove all of it.
Mar 25, 2008 | Sharp AL-1655CS Copier
BLACK SMUDGING
Hmm... This sounds like it is a toner problem. If your roller is getting too much toner then it just globs it onto the paper even though the drum is not asking for it. Are you using a new toner cartridge or a re-filled one? Is it from Brother or a 3rd party? I suggest you remove the toner cartridge and check inside the printer. Clean any spilled toner. Check the toner cartridge for leaks .. give it a good shake and see if it is leaking. If you have another toner cartridge, you can replace it to test. You may need to pint a few pages to see a change. Another test could be to print a few (2-5) "BLANK" pages. The printer should not be depositing any toner. If no smudge or the smudge stays the same, then the toner cartridge is the likely problem. If the smudge is there, but gets smaller, then clean your printer.
Jan 10, 2008 | Brother HL 2700CN Laser Printer
Xerox WorkCentre XD155DF Laser Printer Logo
302 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
