Question about Sony Office Equipment & Supplies
How do you reset lamp hours on a vpl px21, just replaced lamp and it is still telling me to replace lamp, unit works fine.
  • randy_consta Apr 24, 2009
    Thank you , Thank you for the assistance, I could not get my hands on the manual. Thanks for all you know...........
    President:
  • 1,073 Answers
Hi!
Here is the manual in PDF, on page 33 you can see how to reset the lamp hours.
http://www.roscorrentals.com/equipment_manuals/Sony%20VPL-PX31.pdf
Nic
DONT forget to RATE me
Posted on Apr 22, 2009
  • Nicolas
    Nicolas Apr 24, 2009
    Anytime my friend:) dlad that i could help you solve your problem:)
    Good luck with your Projector!
    Nic
Need to reset lamp hours on sony vpl px31
1,Connect the power cord
2,The On/Standy light is red.
3,Press the following keys on the Remote Commander or on the projector in the following order for less than 5 seconds :Reset,left,right,enter.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Jun 29, 2014 | Sony Replacement Lamp for VPL PX21, VPL...
I have a Sony VPL-CX61 Multimedia Projector. I just changed the lamp and I cannot get the "please replace lamp" message to go off.
When you use a projector it automatically keeps a timer of how long the lamp has been used for. The message that comes up on screen saying "please replace the lamp" comes up not because it's some how sensing that the lamp is getting old, but because the lamp hours gets to a certain number (usually up around 1500 hours). Because of this when you replace the lamp you need to reset the lamp hours counter, or the projector doesn't even know you've changed it. Every projector does it this way, and they all do it a different way, I googled the model you gave us and found this set of instructions on how to do it, so give it a go.
Reset the lamp counter hours of operation for the projector SONY VPL-CX61
Using the remote commander while the unit is powered up, press "ENTER", "ENTER", "LEFT"
and "ENTER" in sequence. A prompt will appear on the screen asking if you wish to enter the factory mode.
Press the "UP" key on the remote and the unit is now in service mode. This sequence will add two new groups
to the customer setup menu. Press the "MENU" button to view.
Whenever the lamp is replaced, the lamp timer should be reset. With the unit in the "factory" mode, press
"RESET", "LEFT", "RIGHT" and "ENTER" on the remote commander. Verify the lamp hours have been reset to
zero in the service menu.
Hope this worked for you,
Mar 23, 2011 | Sony VPL-CX61 LCD Projector
Reset lamp hours on vpl-fx52
The unit must be on Standby and then you press the reset, <,> and enter. I would recommend doing it a couple of times. You can do this from the remote. I would assume it can be done on the units control panel also. The main thing is to have the unit in standby. It doesn't work if the units not in standby mode.
Nov 02, 2010 | Sony VPLFX52 Multimedia Projector
I just replace a lamp on Sony vpl-cs20 and lamp timer is still high
You should turn on the VP-CS20 with the button on projector, NOT THE REMOTE or the instructions wont work.
"RESET", "LEFT", "RIGHT" and "ENTER" on the remote commander. Verify the lamp hours have been reset to zero in the service menu.
Hope it helps,
FVazquez
Sep 22, 2010 | Sony VPL-CS20 Multimedia Projector
DIRTY LAMP FOR VPL-CS5 SONY PROJECTOR (USED)
to clean the lamp: no chemicals, nothing abrasive. you can touch the outer glass (not with your fingers), but do not touch anythjing inside the bell. best thing to use is a microfiber cloth. your lamp is nearing or has passed 2000 hours of use. the projector is telling you to replace it before it blows (and sometimes shatters). after you replace it, reset the lamp timer (through the menu).
Dec 17, 2009 | Sony VPL CS5 Multimedia Projector
LMP-H150 reset hours on sony cineza VPL-HS2
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS2
1st thing to check - is the cover properly/completely closed - this can stop the projector from working.
Connect the power and set the projector to standby mode.
Press these buttons on the remote control in this order, for less than 5 seconds each.
Reset - Left Arrow - Right Arrow - Enter
This is required, to reset the lamp timer.
Also, something I found interesting from the internet - lamp life isn't when the bulb dies, but when a bulb has lost 10% of its brightness - so you might well be able to reset the timer and get much more use from the bulb - the image just wont be as bright.
Jul 04, 2009 | Sony Cineza VPL HS2 Multimedia Projector
VPL-CS4
Projector on Standby, press RESET, <<=, ==>, ENTER to reset lamp timer.
May 14, 2009 | Sony VPL CS4 Multimedia Projector
Reset Lamp Hours
hi have vpl-es3 i changed the lamp but i have massege replace the lamp
May 11, 2009 | Sony VPL-CX80 Multimedia Projector
Lamp time resetting
HI
Not sure if its in the handbook but you can download a copy from here
http://safemanuals.com/user-guide-instructions-owner-manual/SONY/VPL-CS5-_E
Feb 21, 2009 | Sony VPL CS5 Multimedia Projector
Need asistent
my sony vpl ex3 will not light up, has a lamp/cover light on all the time can somebody help
Jun 21, 2008 | Sony VPL-EX1 Multimedia Projector
2,516 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
