Question about Toshiba TEC B-452 Thermal Label Printer
We have the font break problem on the Toshiba B452 machine having 600 dpi. What could be the reason ? What is the best ribbon we can use to print the labels on film base. What are the reasons for font breakage which occurs to the tune of 5%. We want to reduce it to 0.5 to 1%. I shall be thankful if some one mail the solution to nrj1945@gmail.com Thanks Jayaraman
  • 1 more comment
  • nrj1945 Apr 20, 2009
    Some other suggestions may also be given apart from the one given.
  • nrj1945 Apr 22, 2009
    The ribbon is not old and work with other labels normally. Therefore what are the other possible reasons?
    I will come back after analyzing the base film.
  • 628 Answers
If the film is old, the "ink" dries up and won't stick to the paper, causing the characters to be broken up. Try buying a fresh ribbon and see if the problem goes away.
Posted on Apr 20, 2009
  • Joe Fine Apr 22, 2009
    You say that it works with other labels? Then your problem seems to be related to the particular label stock. Perhaps it's too thick or thin, or there is a coating on it which will not allow your ink to stick.
How to print envelopes
Please specify your machine's model
Mar 20, 2015 | Canon imageCLASS MF8280CW Laser...
Which laser printer is best for screen/butter prints for extra dark black print outs ?
Dear You can choose any printer having printing resolution more than 600 DPI. For screen printing the jobbers prefer for resolution from 300 DPI to 600 DPI.
Thanks.
Jan 14, 2015 | Laser Office Equipment & Supplies
Hallooo ... sp, what's the difference with the IR5570 IR 6570 .. thanks
-IR5570 : 55 page/mn
  1. 20 GB Hard disk drive
  2. 512 MB RAM
  3. Scanning resotion 600*600 dpi
  4. Copy resoltion 1200*600 dpi
  5. Print resoltion 2400*600 dpi
IR6570 : 65 page/mn
  2. 512 MB RAM
you can use this brochure to see more: http://www.usa.canon.com/cpr/pdf/Brochures/copier_ir_6570_5570_5070_brochure.pdf
Dec 07, 2010 | Canon imageRUNNER 5570 Copier
Font height is big in printed barcode. how can I adjust the size of the font?
check if the setting FORMAT CONVERT is with some numbers, please change for NONE.
This seting change the resolution from Printhead 200dpi or 300dpi or 150 dpi or none, none mins, if you have 200dpi printhead, print 200dpi resolution(small fonts). if have 300 dpi, print with 300 dpi resolution, if have 300 dpi(very small fonts) printhead, can print 150dpi(big fonts) if change this setting.
if ok, check the driver or your software.
Dec 05, 2010 | Zebra Z4Mplus Label Printer
300 dpi in canon 2900B
I cannot understand how will print picture 300x300 dpi in CANON 2900B. There is solution but not working.....
Sep 13, 2009 | Canon LASER SHOT LBP-2900 Printer
Can't figure out how to adjust darkness/tone for printer output
Below you can see a step by step procedure on how to change the print quality of your work....you need to make test printouts in order for you to see the results....at the end there is a link to the manual for your printer...GOOD LUCK!!!
Print-quality settings affect print resolution and toner usage.
Use the following procedure to change print-quality settings:
1. Open the printer Properties (or Printing Preferences in Windows 2000 and XP).
2. On the Paper/Quality tab or the Finishing tab (the Paper Type/Quality tab for some Mac drivers),
select the print quality setting you want to use. The following options are available:
● 1200 dpi: This setting uses ProRes 1200 to provide fine-line detail at 1200 x 1200 dpi.
● 1200 dpi effective output quality: This setting provides 1200 dpi effective output quality
using FastRes 1200.
● 600 dpi: This setting provides 600 x 600 dpi output with Resolution Enhancement technology
(REt) for improved text.
● EconoMode: Text is printed using less toner. This setting is useful when you are printing
drafts. You can turn on this option independently of other print-quality settings.
Manual
Apr 13, 2009 | Office Equipment & Supplies
Ribbon spool does not turn, TEC B452
If you are working with the driver, change in stock page direct thermal to thermal transfer.
Mar 13, 2009 | Toshiba TEC B-572 Printer
Need to get scanned photos to between 300 and 600 dpi
What I saw first off is that although the resolution indicates 96 DPI, the file size itself between the 2 examples are drastically different. You are putting raster images into MS Word for publication work, and that is a NO NO. Word was not created for any kind of high resolution printing. It's a glorified text editor that people seem to think is an option for printing. YOU WILL NEVER GET 300 or 600 DPI images out of Word. Ever.
To create your project for printing, you need to use software more suited for the task. InDesign and Quark are examples, but they are very expensive. In my opinion, Publisher would be better for this kind of project and I hate myself for saying that.
Talk to your Printer, find out his specifications for Applications and Linescreen for Printing. The minimum requirement is 280 DPI, but if the image is placed at 100%, 600 DPI is overkill.
Oh, and try to never scan a scan... you are looking for trouble... a little thing called a Moiré pattern comes into play, and it will make you images print NASTY!
I could go on about your post all day long, but if there is anything else I didn't explain, please post again.
Jan 21, 2009 | MGI Software PhotoSuite SE V4.0
Printing not dark and bold.
Well, I can tell you that on Microsoft's Notepad application, I changed the default font to Courier >Bold< and that seemed to help the problem for that application. Font looks like a normal font when printed on the DCP-7020 now. However this is, admittedly, a very limited solution, sort of last-ditch workaround. Haven't noticed the problem particularly with web pages. You might also try looking at the "Text" option. That helps sometimes..
Dec 20, 2007 | Brother DCP-7020 All-In-One Laser Printer
Print out is too small
To resolve this, try the following actions:
* Check the default fonts within Microsoft Windows.
* Select your entire document and set it to a larger font.
* Make sure all your fonts are loaded properly.
* Change the resolution to quick print at 600 dpi. To do so:
1. Click Start, Settings, Printers.
2. Right click the Lexmark printer icon and choose Properties.
3. Choose the Document/Quality tab and set the resolution to 600 dpi quick print/draft.
* Change the Spool Data Format to RAW. To do this:
3. Select the Details tab and click Spool Settings.
4. In the Spool Settings screen, set the Spool Data Format to RAW.
5. Click OK and then Apply.
Nov 19, 2007 | Lexmark X2350 All-In-One InkJet Printer
Toshiba TEC B-452 Thermal Label Printer Logo
185 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
richie46
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
