Question about Fuji FinePix S3000 Digital Camera
High voltage blew out camera
I put a 9v plug into a 5 v camera and it won't work anymore what do I do
  • 70 Answers
Sounds like you blew the main circuit, which can be replaced. You may send it to Fuji in Edison, NJ or an AUTHORZIED service center. I know of one in Florida, they can be reached at 305-653-7355
Posted on Apr 20, 2009
Do I need to replace the battery and buy a converter, or buy a completely new one? Is it completely broken?
Normal the high input voltage should influence the output voltage. The120V AC to 9V DC will be blown, but with a bit of luck, your Crosley cruiser will be ok. Only if the power convertor is poorly made, the high voltage could have gone through the convertor and then it damaged everything in the cruiser. Try a new 9V power supply and see what it does.
Jan 19, 2015 | Crosley Audio Players & Recorders
ASDA durabrand radio model no. LEDAB0701 information bar has stopped working
Hi - As per original question, NOT A TV, the LEDAB0701 is an ASDA Durabrand DAB Radio, so no remote! Just hit this problem - and found a work-around. Sound always worked - display and backlight failed. Could not spring radio apart - as well as the screw in the battery compartment - there seems an anchor the other end that defeated me. I run off the supplied Power supply and rechargeable batteries. The batteries ran down and I plugged the psu and display came back - for a few minutes! The sealed Power Supply unit (psu) is probably unregulated non-switched mode type. It gave 15.6v unloaded. Unregulated psu's normally run 1.4x nominal voltage with no load and are pulled down to the nominal voltage as the load current is taken (i.e. ASDA psu should have been 9v x1.4 =12.6v not 15.6v).
Seems the radio is sensitive to high psu voltage as when I ran off a regulated psu - problem partly went away. Regulated means you get whatever voltage you set whether no load, half load or full rated load.
Also once switched off fault appears the internal batteries were keeping the display off setting. I used a 12v 1A variable regulated psu. It has 9v, 6v, 5v settings. 5v is too low. 6v works when already running but it needs 9v to start. However the problem is that the display will still switch off if I run for a long time on 9v, so I have to switch down to 6v. Alternative, start on battery and plug in 6v works [6xAA=7.2v nominal, range: 8.5v down to 6v]. Seems some internal components of radio or psu have drifted/become faulty.
You need a positive center/hole polarity. Ideally aim at 500mA or greater replacement psu. Ideally use a variable one so it can be used for other things if your problem is different and this is not the solution. If you have an unregulated variable psu (400mA or greater) try running at 6v (will be higher but perhaps not too high) then switch to 4.5v or 5v (again will be 1.4x higher) but make sure it is set to positive centre/hole.
Apr 12, 2014 | Televison & Video
I plugged wrong adapter (dock's proper voltage was
Doubtful, you've plugged it into a voltage of nearly twice its rating. My guess is that you've blown it up.
Oct 30, 2013 | Altec Lansing - IMT320 - inMotion Compact
Headlight keeps blowing out 1996 yamaha virago 1100
Hi, Anonymous if your headlight is not working, only one beam works, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chaffed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty wiring between battery positive and headlight bulb socket.
9. Weak charging alternator/generator.
10. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Headlight globes keep blowing
Yamaha Virago XV535 1100 1981 1994 Service Manual
OEM parts for Yamaha
Yamaha Virago XV1100K Owner Manual
Jul 22, 2012 | Yamaha Motorcycles
Whistling sound
This tv whistling sound are causes by a high voltage currents flow from it is tv power supply board it self not functions properly anymore.That the board where the power a/c cord plug into it.Those high voltages tranformers have gaps in it solders joints and now it not letting high voltages currents flow smoothly anymore,that where the whistling sound came from.Tries take the tv aparts,tries to put some kind harden or supper glues to all those high voltages tranformers,might help or soften the whistling sound alot.If that did not help all or alot.Try website like Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Jul 28, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
We ran the battery down when we were filming when we put in a new charged battery it won't turn on anymore
Possible that the new battery voltage/current is low. If this is the recharge-able type , as you have not mentioned then have it charged for a long time. Check the voltage on the battery and then try. If the camera does not work then it is possible that some errors have crept into the control board. leve the camera without battery for few hours and then try. if not you must take opinion from the service center.
Jul 06, 2011 | Cameras
I have a HT-3000 Casio keyboard. I can't get any power when I turn it on. The power indicator light does not come on. Is this keyboard worth fixing? or can it be repaired at a reasonable cost.I am not...
Of course, don't try higher voltage. Something wrong with your transformer, it should be 9V as an output. Parts of component inside transformer have broken, such as resistors, capacitors or even IC. I'm affraid it cause your kboard power circuits have broken also.
Oct 14, 2009 | Computers & Internet
Atari 2600 Console Power Adapter
The Atari 2600 adapter has the following information on it:
Input: 120V AC 60Hz 12W
Output: 9V DC 500mA
Positive tip
Make sure you test the power supply before you use it. I have 2 original atari power supplies, and they are both putting out about 15V DC, which may be why my atari's aren't working anymore!
Anubis
Jan 05, 2009 | Atari 2600 Console
Dark Picture
I'm not sure how to help you with this one as the unit you describe does not match the one listed in the thread. You talk about a WTV1903 TV but a Sony KV-27S42 is listed. One thing is for sure no matter which model you have you should never exceed the manufacturers rating for the fuse (which is not meantioned). You stated that a 4 amp fuse (12V) blew so you put in a 5 amp. You never raise the fuse rating. Larger means more current draw and the possibility of a fire. First put the correct size fuse in. It should be listed on the circuit board or in your literature. If the picture is dark either the CRT is bad or the High Voltage or screen drive is low or both. The fact that it is blowing fuses indicates that something is not working properly. You need to check the CRT with a tester. If good, check the High Voltage for the correct value. If this is good you could have a partially shorted flyback. If you are not qualified to work on these circuits, (they are dangerous) have a qualified tech do it. Good luck and don't put larger fuses in in the future!
Jun 25, 2006 | Sony KV-27S42 27" TV
Fuji FinePix S3000 Digital Camera Logo
64 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
