Defrost heaters are not coming on. Check with multi meter..is it frost, or ice freezing under the fan-blades. That my friend is a blocked drain hole. Otherwise ohm out defrost heater should read 30to69 ohms of resistance. Timer may be stuck, or a hi-temp safety switch is not closing (a small disc at the top of the coils) when it comes out of defrost. Carweful with that gun, Jim! Too much heat warps all that chinese plastic. Chris in bigbEar
evaporator
fan is building up ice
