Question about Canon imageRUNNER 1023iF Black and White Copier
What to do about a bad sensor on a Canon ImageRunner 1023if?
Not loading or feeding pages correctly.
  • Jennifer Jackson Apr 22, 2009
    Nevermind, I got a local guy to come out and look at it and it was the roller which is still under warranty!! THANKS
  • eric400 May 11, 2010
    is the problem in the feeder or in the paper drawer? Is the paper crunching up or is the machine just stopping?
  • 92 Answers
From the drawer see if the shaft or the pick ups are returning to home position if not see if the spring is there.
Posted on Oct 27, 2009
ImageRunner 1023iF auto-feeder stops mid-way through document. Pick-up and feed Wheel continues to spin for a moment, then stops and gives "Check Document" error. I have fed a card through the...
It can be the problem in sensor flapper on ADF tray ( small nose that is pointing out ). Maybe it doesn't works fine or in the middle of the copy from adf the paper is too far away from the sensor.
Also can be the problem of ADF pickup clutch or You are using unappropriate paper type- try with normal A4 80g/m as original to copy from adf.
Hope that something of this helps You!
Jun 02, 2011 | Canon imageRUNNER 1023iF Black and White...
On a Image Runner 1023iF trying to print letter envelopes loaded in the Stack Bypass. Machine once it received the print job just beeps and flashes.
Hy,
did you select the correct paper size on machine display? When you put paper in baypass the copier ask you for paper size and type.
Sep 02, 2010 | Canon imageRUNNER 1023iF Black and White...
How do I scan a document to send as an attachment via email on Canon ImageRunner 1023iF
First your company must have a e-mail server.Enter the server ip address in the smtp server address in the additional funcktion,system settings,network settings page untill you get the smtp server address.
Nov 03, 2009 | Canon imageRUNNER 1023iF Black and White...
Canon 1023if auto feeder not working. Says check
The document feeder has multiple sensors in it. sometimes they hang up and stay stuck out of place. Other sensors might get paper dust on the face of the sensor. If you can open the document cover, locate the sensors and see if any are ajar or the sensor flag fell out of place. Also look to see if a paper is stuck in any of the paper path areas. Not seeing the machine it is hard to say if it fed paper and says check document, if it did, clean the feed wheels with a wet paper towel.
Oct 15, 2009 | Canon imageRUNNER 1023iF Black and White...
I need to change the date on fax confirmation pages to the current date on a Canon ImageRunner 1023iF.
1)Press the Additional Funktion button.
2)Press the arrowkeys untill 6 TIMER SETTINGS is displayed Press the OK KEY
3)Confirm that DATE TIME SETTING is displayed and press then the OK key
4)Change the date and time
Aug 19, 2009 | Canon imageRUNNER 1023iF Black and White...
Adjust volume canon imagerunner 1023iF
Press "Additional Functions" button. <common settings> should be displayed, if not press the "+" or "-" button until common settings is displayed. Press "ok". Press "+" or "-" button until "Audible Tones" is displayed. Press "ok". Walk through this submenu to locate the fax volume. Press "ok". Adjust as needed. Press ok. Press stop to exit settings mode.
Aug 13, 2009 | Canon imageRUNNER 1023iF Black and White...
Check document message
you will almost certainly have a torn piece of paper ( or small document) in the document feeder sitting over a sensor.It doesn't need to be very big to be detected.Open ALL covers on the feeder, check particularly at the edges of the feed area where you may have torn a corner off.Sometimes you can hand feed a piece of card through by turning the belt or rollers and push any obstruction out..........
Jul 28, 2008 | Canon imageRUNNER 1023iF Black and White...
Canon imageRunner 1023iF won't print--offline
change the cable, there is a bad connection once you put a new one it should say ready
Oct 09, 2007 | Canon imageRUNNER 1023iF Black and White...
Canon imageRUNNER 1023iF Black and White Copier Logo
95 people viewed this question
old marine
old marine
