Question about HP Computers & Internet
My HP laptop will not start up.
Ive had my HP laptop for about 2 years now and it had been working fine up untill now, whenever I turn on my laptop, the fans and stuff start and the lights go on as usuall and then all of a sudden it resarts all by it's self over and over again without anything showing up on the screen, completly blank black. a month ago It took about 10 minutes of the resarting cylce before it finally turned on but now it takes from 45~60 minutes before it starts to turn on, THEN my laptop works like normal.
Hp wireless keyboard not working
exact key board driver install then try
what keyboard model?
download load driver for keyboard
update keyboard driver
May 16, 2012 | HP Computers & Internet
HP Mini 110-1012NR PC power button stuck. Its not sliding to the left to power on. Worked yesterday shut it down as normally do and slide power button off now its like something is preventing it from...
Possibly a broke power switch, if inclined I'd start with finding a service manual on the mini and disassembling it until you reach the power switch from the inside and can get a better look.
Sep 09, 2011 | HP Mini 1000 Netbook
Hp pavilion a1210n disk boot failure, insert system disk and press enter. how do you boot in save mode
Turn your computer off, turn it back on, as soon as you do that, start pressing F8 repeatedly until you get to a screen where you can access safe mode. If it's saying disk boot failure, you most likely have a dying/dead hard drive.
Jul 24, 2011 | HP Computers & Internet
Wireless quit working, reinstalled windows and worked until i uninstalled a few "junk" programs(preloaded from manufacturer). will not see card in device manager. replaced card, updated driver and now when...
If your internet is working wired using the laptop , i would advice you to download a drivermax , its a free program you can use to check if the laptop is missing some drivers. Ive been using it for quite some time now and its been very helpful whenever i format my laptops and desktop
Cheers,
KJ
Jul 04, 2010 | HP Compaq Presario F730US Notebook
I fixed the dc jack and resoldiered it to the mother board but when i turn it on the screen doesnt respond.this is a friends laptop that hasnt been used for aprox 3 years before i fixed it.i also tried...
As it hasn't been used for 3 years I suggest you replace the bios battery. I notice some computers work fine with an absent or discharged battery but I have encountered a couple that were completely dead and refused to do anything until the battery was replaced.
An old Toshiba laptop I had would eventually start and boot up but it took the best part of an hour to do so - a lot of waiting...
Aug 26, 2017 | HP Pavilion ze4145 Notebook
Hp Compaq nx5000 Laptop selft boot / restart when plueged
You need to replace the power supply, don't continue to use it for it would cause damage to your computer.
Nov 02, 2009 | HP Media Center PC 873n (P9875A#ABA) PC...
My HP Pavillion DV100 notebook shuts down whenever it feels like. What could be causing this.It is 3 years old now so off warranty. It will work just fine for a little while and then voila! shut down.
Sounds like classic overheating, check your power supply fan, or the fan of your heat sync that seats over your CPU as well as the heat resistant insulation thermal lubricant that's there to keep it cool.
When fans starts to go the bears or motor starts to stick and will intermittently stop. When when it goes altogether it ceases to turn and can cause serious overheating damage to your circuitry.
Jul 27, 2009 | HP Pavilion dv1000 Notebook
My laptop will not boot up
Try soft resetting the laptop .
1. Disconnect the Ac adapter
2. Remove the laptop battery
3. Press and hold the power button for 10 seconds
4. Reconnect the power adapter only and power on .
5. If the laptop starts fine , reinsert the battery back
Thanks
Proton
Jan 10, 2009 | HP Pavilion dv4000 Notebook
HP dv4000 battry not charging.
I had my lap for about 2 year and Iwanted to use my bluetooth driver but Icannot found it. So , Ineed help very quq.
Oct 26, 2008 | HP Pavilion dv4000 Notebook
Yahoo webcam
i have built in camera in my laptop HP pavilion dv2000, its not working
Feb 19, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Computers & Internet Logo
219 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
