Question about Creative Labs Zen Touch MP3 Player
My creative Zen has froze aswell have tried the pin but it is still jammed, When I turned it back on it said it was rebuilding but it is still the same?? ( It is jammed on a track and the top right hand corner has EQ and an arrow symbol? Dee
  • kathyj79 Apr 21, 2009
    I have the same problem and the only way i can turn it off is to take the battery out. Everything problem that you have even the arrows in the right hand corner with EQ by it. I would love for someone to solve this problem. No it was not dropped i just turned it on and this is what happen. Thank you. Kathyj79
  • 728 Answers
If a reset does not work using the reset hole, then try this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
Posted on May 24, 2009
My creative Zen mozaic ez100 is stuck on the rebuilding screen. it has been like that for hours the battery died then i recharge it again to see if it will work but it didnt it turned on and froze on the...
this happened to me just a few days ago what i had to do is take evrything off it all my music and videos turn it on then let it rebuild its self this will realise that there is nothing on it so will rebuild its self easlie because there is nothing on it to slow it down then once that is done and u have the main screen up put everything back on it using the creative zen software from the starter pack in ur mp3 player mine works great down :)
Aug 18, 2010 | Audio Players & Recorders
My creative zen freezes up while shutting down
Mine froze while trying to add radio preset stations. Had to put a pin in the reset hole to recover.
Have tried to understand 'playlists' without success!
Mar 05, 2009 | Creative Labs Creative Technology Zen MP3...
Creative Zen Rebuilding Problem (Freezing)
Hold the reset button with a paper clip AND the play button at the same time while flipping the power switch. The ZEN should go into recovery mode. You probably want to do format all but you can try the different options. You also may need to download/update the firmware here.
Feb 07, 2009 | Creative Labs Zen Digital Media Player
Creative Zen Freezes on Rebuilding
My Zen locked when I turned it on. It wouldn't play the track the screen was on so I pressed the reset button and turned it on again. It was then still locked on the same track so I tried turning it off which then froze as it was shutting down. After another reset it went through the rebuild screen then locked again. I then used the above fix (pin in reset, then hold play and power switch down). Taking me into the kind of bios screen I formatted the contents. Then added my library again. It's now working fine.
This is the second Zen I've had because the first one had the same problem so I took it back without trying to fix it. Both times the problem occured when I had my Zen plugged into my car stereo auxiliary jack whilst switching the ignition on in my car. I can't understand why this would cause the problem but I'll avoid doing that in future.
Dec 27, 2008 | Creative Labs Zen Digital Media Player
Creative zen froze
Try sticking a safety pin into the reset hole. It's tiny and it should be at the bottom I did this with my other creative when it froze and it worked.
Jun 16, 2008 | Creative Labs Zen Digital Media Player
Creative Zen V does not boot.
You can take it apart and unplug and replug in the battery. this will void any warranty. BE SURE YOU DONT LET THE SCREEN DISCONNECT FROM THE PLAYER. Mine did and i can't get it hooked up and have damaged it in the process. Darn thing works/charges/everyhting though. Just no screen...
Jun 04, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative zen v problems-frozen
I Recently bought a Zen, and it works great. The only problem I found was that it freezes itself from time to time, and the best solution to this problem is on the bottom of your Zen, there is a very small Reset hole. With a needle or a toothpick, gently stick it in, and push lightly. This will allow the Zen to unfreeze, and return back into it's regular mode. All your files will be saved, and kept on to the Zen, so you don't need to worry about losing any of your files.
Any additional help, I'll be glad to answer!
-bananaboy101
Dec 04, 2007 | Creative Labs Zen V MP3 Player
Froze in the middle of a song.
Thank you thank you thank you a billion times, you just saved my life (well, at least my zen's). Did as you said, my Zen Touch 20GB is rebuilding it's library right now. Oh, now it's done. Everything's still there, awesome. Thank you!
Mar 03, 2007 | Creative Labs Zen Touch MP3 Player
Creative Labs Zen Touch MP3 Player Logo
140 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
