Question about Air Tools & Compressors
Wiring a Husky brand compressor from Home Depot.
I bought a Husky brand compressor from Home Depot. It is a 3.2 HP, 60 gallon, and is to be wired for 220v. They don't come with power cables. The Depot man sold me the wire and corresponding plug. Under the pressure switch cover where it gets wired up, the motor side is already set, as the black and white wires from the motor are factory installed with spade terminals slid underneath the phillips head screws. The upper part for the power cord looks exactly like the spade terminals for the motor, but the Depot electrician said to not use any terminals, just put the wire in there and screw it down. The problem is, that the wire even when twisted tight, will not fit under the screw. I went back and he sold me some solder saying that the wires need to be soldered first. Well that still wont work, because the solder made the wire even bigger. I do not want to cut some of the strands off to make the wire smaller, since I am dealing with 230volts. I went to another Home Depot, and they said the same thing, do not use terminals on them. But the switch box is desigend for a spade terminal! Help!!
  • Anonymous Mar 16, 2014
    when wiring this compressor, does the direct black wire go on the same side as the black motor wire
  • 374 Answers
Hi! there,
you can use terminal connector like on figuresWiring a Husky brand compressor from Home Depot. - 83ba8af.jpg joint connector or lug connector
this are more convenient to use
easy to install and has insulated for connection.
insulated ring terminal connector
this is also good for connector more safe for circuit breaker suipply.
go to the nearest hardware or mall
Posted on Apr 20, 2009
    President:
  • 1,388 Answers
I do not want to add to the confusion but I have installed several of these over the years and use a piece of romax or three pieces of #12 solid copper wire inside flextube or metal conduit. I believe that this unit is designed as a shop compressor and should be bolted to the floor and hard wired to a breaker/ switch on the wall instead of using a plug/ receptical. Hard wiring and bolting to floor reduces theft and reduces chance of tipping over. The solid copper wire fits nicely on screws of pressure switch. All these parts are available at Home depot; speak to one of the electrical guys about your project. If you would rather use a pigtail, I would definately use terminals soldered to copper strands and do not remove any strands. Find a terminal for your wire gauge that fits the pressure switch. Soldering is much better than crimping. Run you compressor for a while and unplug or switch off. Remove the cover to the pressure switch and carefully feel the connections for heat. Excess heat means loose connection. If unusually hot, remove connector and carefully resolder. Good Luck with your new compressor and email if you have question.
What oil do I use for a G Force 2 HP air compressor, model 50622
  • www.air-compressor-guide.com/.../air-compressor-oil Keep your compressor in top condition by using the right air compressor oil. Make your compressor run nice and smooth. Using the right air compressor oil for your ...
  • Oil - Air Compressor Oil ' RONA www.rona.ca > ... > Parts and Accessories - Compressors Compressor oil. 473 ml. For all oil lubricated air compressors.
  • Husky 16 oz. Air Compressor Oil-HDA10700AV - The Home Depot www.homedepot.com/p/Husky-16-oz-Air-Compressor-Oil-HDA10700AV/...
    • 5/5
    • 1 REVIEW
    • $2.49
    • IN STOCK
    Air Compressor Oil from Husky is designed to reduce carbon buildup in compressor valves to ensure a longer compressor life.
  • Air Compressor Oil & Lubricant www.ecompressedair.com/compressor-oils.aspx eCompressedair is your source for Air Compressor Oil & Lubricants for major air compressors and synthetic compressor oil brands in 5 gallon air compressor oil ...
  • Oil-free air compressors - Atlas Copco Canada www.atlascopco.ca/caus/products/air-and-gas-compressors/1472896 Oil-free centrifugal compressors. Oil-free reciprocating piston compressors. Oil-free rotary tooth compressors. Oil-free screw compressors. Oil-free scroll compressors
  • Air Compressor - Oil-Free Air Compressor ' RONA www.rona.ca > ... > Products > Tools > Pneumatic Tools > Compressors Air Compressor - Oil-Free Air Compressor. Oil-free air compressor. 26 gal. Vertical, saves 50% more space. 1.7 running HP. 120 V. 15 A. Easy to operate controls with ...
  • May 17, 2016 | Air Tools & Compressors
    I have a husky model 947265. And it won't shut off when I turn it off manually I have to wait till all the air is out before it turns back on
    Free Husky Air Compressor User Manuals ' ManualsOnline ...
    powertool.manualsonline.com > ... > Husky > Power Tools Husky
    Husky Air Compressor Operator's Manual ... Plumbing Quincy Single-Stage Air Compressor - 3.5 HP, 220 Volt, 60-Gallon Vertical Tank, Model Q13160VQ.
    Sep 04, 2015 | Air Tools & Compressors
    How to adjust cut in pressure on husky 60 gallon
    what is the pressure switch model number, most of them have a nut with a spring under them, just turn the nut to adjust the pressure
    Oct 21, 2012 | Husky Electric Air Compressor: 60-Gallon...
    Husky 60 gallon compressor switch from 220 to 110
    Try here, very good for asking problems http://www.about-air-compressors.com/husky-air-compressors.html
    Jul 28, 2012 | Air Tools & Compressors
    Husky 2600 pressure washer with honda gcv160 engine. engine won't run with choke off.
    I bought mine at Home Depot, the pump failed after about 8 hours of use then Home Depot agreed to replace it now it failed again after aabout 10 hours of use. This is a piece of crap and Home Depot should be ashamed for selling this junk. I am sure they are in with Husky and making big dollars on a crappy product. My machine is like brand new just will not work. Now the carb has to be replaced only after less than 20 hours.
    JUNK Home Depot
    Nov 23, 2011 | Garden
    Need Manual for Husky Model 41214 Air Compressor
    You can get the manual for model 41214 from my dropbox area:
    http://dl.dropbox.com/u/54567653/husky_aircompressor_model_41214.pdf
    BTW, if you find this manual helpful consider installing dropbox using this link (full disclosure -- I do get about 0.2 GB freespace from dropbox if you install using this link):
    http://db.tt/vQycqXIW
    Thanks,K
    Dec 20, 2009 | Air Tools & Compressors
    Portable air compressor won't start
    To be honest with you your compressor is what is commonly referred to as a throw away. You can't even imagine how many times I have posted that in the past month for your compressor and similar ones, such as the 3 gallon 1.5 hp craftsman.
    The Porter Cable Is more reliable or rather it used to be. I believe that there are so many manufactures around the world pumping these things out that in order to get a reliable compressor you have to do it through the warranty. I know Senco makes a pretty good portable compressor. I believe Home Depot carries it and the cost is around $125.00.
    That said your compressor may be salvageable so don't write to Santa just yet.
    Almost all compressor,(even the throw a ways), come with a reset switch. The problem is finding it.
    If you don't have your manual then start looking. You may need to remove the plastic shroud to locate it. All it is is a small black or red plastic button about a 1/4" in diameter.
    Since you stated that there was a power outage that kind of rules out loose wiring or incorrect extension cord size. You may want to check the breaker though. You may have already but check it again. You want to turn it off and on a couple times to see or rather feel if the breaker itself has became compromised.
    I hope something here helps.
    Nov 17, 2009 | Air Tools & Compressors
    I have 3 compressors, all of them refuse to stop compressing until i manually shut them down,husky 26 gallon upright 5 yrs old, porter cable pancake 2 yrs old. and a master elite? came from home depot as...
    the regulator/switches are either rusty, clogged, or need to be replaced. if you have some machanical aptitude and common sense this should be easy, if not have a pro or someone some knowledge of this type of thing handle it for you. in the future drain your compressor DAILY to avoid this problem
    Nov 13, 2009 | Porter Cable Air Tools & Compressors
    I have a Sanborn 60 gallon vertical compressor ( Blackhawk 5 hp ). What weight oil goes in the crankcase?
    there is actually air compressor oil available at most hardware stores be sure it is compressor and not air tool oil
    Jul 23, 2009 | Makita MAC5200 Electric Powered Air...
    Air Tools & Compressors Logo
    4,606 people viewed this question
    Top Air Tools & Compressors Experts
    John Trevino
    Joe Garcia
    Joe Garcia
    Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
