Question about OKI B4300 Led Printer
Error code 173
On power up, it does the RAM check, then INITIALIZING. After about 30 sec it displays 'ERR 173' and the number 050914 cycles through on the second display line. what does this error code mean or where can I find a list of all the error codes for this Oki B4300? Thanks for any help.
  • 3 more comments
  • Anonymous Jan 09, 2008
    Have same problem. Plugs are all connected
  • Anonymous May 29, 2008
    error 173
  • megcak555 Mar 22, 2009
    i have an okidata b4300, the display keeps showing "RAM CHECK" i turned off unit and once it cycles through when i turn the unit back on the "RAM CHECK" does not go away and I can print anything....can anyone help....Thanks-
    megcak555
  • phillipt67 Apr 19, 2009
    goes through ram chk, flashes err 173. Anybody have any idea how to repair?
  • megcak555 May 11, 2010
    Correction...I can NOT print once I turn off and back on the printer.
  • 161 Answers
That error means low temperature on the heat roller. The thermistor (something like an electric thermostat) measures the amount of heat needed to work. Error 173 refers a lower temperature than required, while error 172 refers overheat. The complete error list will be of no use to you, since most errors will refer you to an authorized service center.
Posted on Sep 22, 2007
    Problem Solver:
  • 8 Answers
Having similar problem on a used printer just got today - wanting to know if it worth fixing it or just let it continue to the recyclers?
Posted on Apr 12, 2008
Thanks, The cable was not plugged in right. Solved now.
SOURCE:
Canon ir 2270 E000732 0001 tell me answare
http://printcopy.info/?l=en&mod=erc&brand=canon&model=iR2270
Quoting from link:
Canon iR2270 Error Codes List page 1 from 24
Code:
Exploded Views and Parts List Free!
  • Code: E000-0001
  • Description: The temperature of the fixing assembly is abnormally high.
    While startup control is under way, the reading of the main thermistor is less than 30 deg C continuously for 200 msec or more 1 sec after the start of power supply. While startup control is under way, the reading of the main thermistor is less than 70 deg C continuously for 200 msec or more 2 sec after the start of power supply. While startup control is under way, the reading of the main thermistor is less than 120 deg C continuously for 200 msec 6 sec after the start of power supply. The startup control does not end 30 sec after the start of power supply.
  • Remedy: Reset the condition in service mode: COPIER>FUNCTION>CLEAR> ERR. Replace the main thermistor. Replace the DC controller PCB.
Aug 09, 2018 | Canon Office Equipment & Supplies
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display Abnormality / Protection control Abnormality
Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica
tion > 1 min after starting
operation Indoor fan operation
only • Internal / external cable connections
• Indoor / Outdoor PCB H14 Indoor intake air temperature sensor
abnormality Continue for 5 sec. - • Intake air temperature sensor (detec
tive or disconnected) H15 Outdoor compressor temperature sensor
abnormality Continue for 5 sec. - • Compressor temperature sensor
(detective or disconnected) H16 Outdoor Current Transformer open cir
cuit - - • Outdoor PCB
• IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance
continuously - • Indoor PCB
• Fan motor H23 Indoor heat exchanger temperature sen
sor abnormality Continue for 5 sec. O
(Cooling only) • Heat exchanger temperature sensor
(detective or disconnected) H24 Indoor heat exchanger temperature sen
sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor
(detective or disconnected) H27 Outdoor intake air temperature sensor
abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec
tive or disconnected) H28 Outdoor heat exchanger temperature
sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature
sensor (detective or disconnected) H30 Outdoor discharge air temperature sen
sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec
tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance
• Ventilation motor H51 Nozzle lock abnormality 2 times occurance
continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance
within 30 minutes - • Indoor PCB
• Fan motor H98 Indoor high pressure protection - - • Air filter dirty
• Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro
tection - - • Insufficient refrigerant
• Air filter dirty F11 Cooling / Heating cycle changeover
abnormality 4 times occurance
within 30 minutes - • 4-way valve
• V-coil F90 PFC control 4 times occurance
within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance
within 20 minutes - • No refrigerant
(3-way valve is closed) F93 Compressor rotation failure 4 times occurance
within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance
within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro
within 30 minutes - • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor) F97 Outdoor compressor overheating protec
within 10 minutes - • Insufficient refrigerant
• Compressor F98 Total running current protection 3 times occurance
within 20 minutes - • Excess refrigerant
• Improper heat radiation F99 Outdoor Direct Current (DC) peak detec
tion 7 times occurance
continuously - • Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
Oct 13, 2017 | Panasonic Heating & Cooling
Key board not working COPIER>FUNCTION>CLEAR>ERR.
Do you mean the LCD display is not responding , or that the number keys do not work, or both? I suspect that the keypad and display do work but your real issue is that you cannot enter service mode to reset an error code. Entering service mode can be a little tricky on that model. Hit *(Add. Functions, not the * on the keypad). So , to review, * then the 2 and 8 key simultaneously, then * again will get you into service mode. A screen will pop up that says Copier and other stuff. Select Copier. Then hit function tab at top of display. Then Select Clear (CLR) Then Error(ERR) then hit ok at the bottom of display. Then cycle power, if the error resets, you are done. If the error comes back, you need a part. Important----do not randomly clear any other items in service mode. You can cause a lot of problems if you do. Only clear that error code. Hope that helped. If not, you need to call a technician.
Sep 03, 2014 | Canon Ir 3300 Black & White Copier
Error 173 050914
Error 173 indicates an problem with the fuser / heater unit.
Jan 06, 2014 | Oki Electric Industry B410D Laser 30PPM...
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occurred
Right click on the error message select properties you will see all details about the error
or click start type in event viewer press ENTER
this should give you some sort of understanding of the error and
you might be able work your way through the problem
Title : E003-0000 is displayed upon recovery from sleep mode
Error :
Workaround :
When a machine is in sleep mode and is recovered an error code "E003-0000" was displayed.
It is caused during the fixing temperature control at recovery from sleep mode, electrical noise affected the thermistor.
In order to increase the length of time for idle rotation of the drum (by 30 sec) at start-up and prevent electrical noise from affecting the thermistor, make the following selection:
Service mode (Level 2)> COPIER> OPTION> BODY> DRM-IDL = change the setting to '3'
Note: The length of time for idle rotation is being increased by 30 sec.
This mode will delay start of the machine by 30 sec.
or
Product : imageRUNNER 7086 imageRUNNER 7095 imageRUNNER 7105
Title : E003
Error :
E003-0000 Error Code can be displayed when the reading of the main thermistor is below 70 deg. C for 2 sec. after it has exceeded 100 deg. C.
Workaround :
1. Although the fixing heater or the temperature-detecting thermistor may be faulty, before replacing these parts, check J508 on the DC controller PCB for poor contact and refit it if necessary.
2. Make the following selections to clear the error code: [Service mode > COPIER > Function > CLEAR > ERR > OK]
Jul 18, 2013 | Canon imageRUNNER 5000 Copier
Canon Ir2318 error code 00003
the code is related to the fuser section.If the machine is new then enter the service mode by pressing additional function and then * and clear it in error clear , if it is old machine then check the fuser for open thermistor,broken element .
Aug 24, 2011 | Canon imageRUNNER 2200
ERROR 173 050914
Low fuser Temperature Error - Replace fuser or thermistor in the fuser - per Oki Svc Mnl
Fuser error. Replace fuser or if no-go, Main board.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 27, 2011 | OKI B4600 Printer
Initializing... RAM CHK
Power supply is defect.
Probebly 2 ELCO's are exploded or ball.
Greatings,
Wim
May 27, 2008 | OKI B4350 Laser Printer
Error message on screen E000001-0002
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode: press"Additional Functions" button (looks like a picture of a head with a star inside) press the #2 and #8 at the same time (simultaneousley) press "additional functions" again The display should show a choice of copier,feeder,sorter,fax,or board service modes Select copier select clear select ERR press OK Turn power off & back on. ****IMPORTANT**** After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair. Good Luck!! I can be reached @ [email protected] if you have any questions.
Sep 21, 2007 | Canon imageRUNNER 2200
OKI B4300 Led Printer Logo
6,301 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
WTF Chuck.....
WTF Chuck.....
Clive
Clive
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
