Question about Quinny Baby Gear
I am just lokkin to see wer we could get other back tire for f buggy can noy repare the tire so real just wonderin wer can we pick up other one
  • 60 Answers
Go to this link for Quinny Parts and you can either fill out the form or call them directly at their 800 number shown.
http://quinnybaby.com/info_replacement_parts.asp
I hope this was helpful, DutchTexan
Posted on Nov 06, 2009
What is the huming noise comeing from the front of my avenger while driving down the road.
Tires out of alignment can make a humming noise but so can a water pump or alternator before it goes out. A parts store can hook up to your car and test the alternator quickly and eliminate that.
Jan 18, 2015 | 2011 Dodge Avenger
Blue led not coming on
A model number off the back might allow me to give you some real answer.
Mar 16, 2012 | JVC LT Televison & Video
The left back tire on my Phil and Teds Classic buggy keeps coming off the rim. I have fixed it by letting the air out of the tire, resetting the tire inside the rim and then refilling the tire. Each time...
What tire pressure are you inflating to? It should only be 22psi. Here's some advice from philandteds.com/support:
First, deflate all of the air from the wheel. Once the air is removed, reposition the tyre tread so that it is even all the way around the rim. Once in place, reinflate the innertube (while holding the tyre tread) and it should allow the tread to stay in the correct location to allow the stroller to roll smoothly. It may take a few tries, but this will almost always fix the issue.
Aug 12, 2011 | Toys
How much air should you inflate into the mountain buggy strollers rear tires?
Between 1 bar / 15 psi to 2 bar /30 psi. Easier to push the higher you inflate softer ride with less.
Jun 19, 2011 | Mountain Buggy Terrain Single - Black...
There is a wire hanging from underneath (drivers side) has stalled while drivin............the wire has 3 prong connecter at end wonderin where it is suppost to connect to
That wire probably came unpluged look on the inside fram rail look for a plug end in the wireloom or secured to the underbody turn the key on without engauging the starter and you should hear a werring sound by the left rear tire thats the fuel pump it turns on for 3 seconds after the key is turned on if no sound that wire probably hooks to the fuel pump.
Mar 01, 2011 | 1996 Dodge Caravan
Car won't move when put in drive. when put back in park, car makes grinding sound. Tires were replaced the day before.
do u have the proper fluid level in trans-chec it while runnin-make sure its a clean red color-if not thinc about changin it along with new filter--it cud be just a linkage problem that u can fix with a haynes manual or since its old many other--Im wonderin if someone played with it at the shop so u return!
Nov 29, 2010 | 1991 Oldsmobile Cutlass Ciera
I have a phil and ted sport and my stroller strongly pulls to the right when trying to go straight. How do I fix it. I just put air in the tires so it isn't that. I don't know what to do. Or is there...
hi
my first suggestion is to remove the front wheel clean and inspect for damage, clean inside ahere the wheel slots into buggy frame if all seems ok spray with a lubricating oil like wd 40 and put it back together
if you have an problems after this please leave the detail and i will get back to you
which country are you in?
Oct 18, 2010 | Phil & Teds Phil Teds Apple Sport Buggy...
Thanks in advance. Our E342n Lexmark printer stops printint 3/4 of a page from the end consistantly since I removed a paper jam. I accessed the back panel as directed and removed the jammed paper and since...
It's a possible worn out pick tires, bad pick arm or fuser issue. For the pick tires, you can use the other side of the tires by removing it flipping it. To remove the pick tires, refer to the guide below: 0c29f53.jpg If it's the pick arm or the fuser, it calls for a replacement. But I hope that the pick tires would resolve the problem. If you need more assistance, just leave a comment so I can get back to it.
Apr 12, 2010 | Lexmark E342n Laser Printer
My puma is getting very noisy in 5th gear making a werring sound, any ideas what this is at it only kicks in after 50mph
Sounds crazy, but it could be tire balancing on a rear tire. While the car is parked, run your hand over the surface of the tires and see if they're smooth or choppy feeling.
If they're not smooth, you could simply need a rebalance or if the tire is real bad, replace and rebalance. Also check tire inflation...
Nov 26, 2009 | 2001 Ford Focus
Baby Gear Logo
Top Quinny Baby Gear Experts
Jennifer Rock
Jennifer Rock
Oloyede Monsuru
ray gallant
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
