Question about Sendo X Handheld
Infrared problems i have already reset my phone by dialling *#7370# my infrared does not still work what should i do.
    President:
  • 1,017 Answers
How do you know your infrared does'nt work?
You might be using it with another format so the phone wont recognise it.
Posted on Dec 26, 2007
I forget my code to reset the setting of my phone E63
Careful, it will erase your personal data on the phone.
You can try to restore to factory settings by dialling *#7780#
or you can
Reformat your phone by dialling *#7370#
or you can go to your local diller to reflash the phone
Oct 05, 2011 | Nokia E63 Cell Phone
Tip
How to make your nokia phones work smooth and fast and keep it maintained.
The usage of the phone memoy in nokia phones is the main reason for slow functioning and hanging. So always keep 80% of the internal memory free or smooth functioning of the phone. For data one can use a memory card.
If the phone memory is mostly used or full transfer the files or delete it.
the only problem for freeing space in symbian phones is it needs to be formatted because it has many hidden files of the installed applications in the phone memory. So you can format the phone by dialling *# 7370 # or by pressing the Switch on + * + 3 + call button when the phone is off.
on Jan 13, 2010 | Cell Phones
My samsung phone.. model 3850 is my phone password.. I forgot the password because of my sun...he change the phone password. Can't you help my problem???
Dear,
if your mobile gets on, then try dialling *2767*3855# in your dialling screen, it will hard reset your mobile, deleting all your mobile internal data like multimedia, virus, password etc.
so remember before dialling this number, backup all your data.
regards!
Aug 17, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
Want to reset my n72 nokia phone have tired useing *7370* forget my code plz help me
Well its not *7370*
The correct code is : *#7370#
Anyway if the code above didnt work....the code below will work:
*#7780#
Jun 12, 2011 | Nokia N72 Cellular Phone
Xperia x10 how to install voice commands for contacts
Hi
Voice dialling is already pre-installed on the Xperia X10.
Its in the main menu.
just tap the bottom of the screen and drag upwards.
Near the bottom of the icon list is "Voice Dialling"
Tap it and say "Call" then whom-ever you wish to call.
I will warn you though...
Out of 10 tries to get it to work on my phone only ONCE did it manage to select the correct app or contact.
I gave up and used phone book instead. It's quicker.
Thanks
Aug 13, 2010 | Ericsson Cell Phones
Dialling problem in Nokia N 73 mobile
remove memory card / format the phone with*#7370#12345(or the lock code) /try it if it good the memory card is having a virus so you can format it or scan it on th pc
May 10, 2009 | Nokia N73 Cellular Phone
Formating
my shoud not the format code is not accepted
Sep 04, 2008 | Nokia 6681 Cellular Phone
Replacing the Housing
i think u will start removing first the casing of ur cp then replace the one u buy????just be careful u might broke it???thnkss and hope i help u
Aug 07, 2007 | Nokia 7370 Cellular Phone
INFRA RED LIGHT IS ALWAYS ON
If it doesn't heat, and doesn't drain the battery, then I don't see how it can really be on... it takes a lot of power. If you don't have a warranty on it, or a service plan with your provider, try reseting it. just save everything you don't want to loose before. The soft-format code for Series 60 phones is *#7370# . You enter this code as you would enter a phone number in the Phone application. It performs a format of the Internal drive - All data will be lost if you use this feature. Series 60 reset The method of performing a hard-format, i.e resetting it completely to factory defaults and removing all data, is as follows: 1. Switch off the phone. 2. Hold down the '5' key, and with this held in, turn the phone on with the power button 3. Wait until a green tick appears over the right softkey, then release the '5' 4. Follow the prompt to reset the phone Note that you shouldn't switch the phone off or remove the battery when performing either of these operations, and it's advised that the handset has a reasonable amount of battery charge before performing a format/reset.
May 18, 2006 | Sendo X Handheld
Can the Axim connect to a mobile phone thorugh the IR sensor to connect to the Internet. If not what would be the recommended way to connect through a mobile.(
I can connect my Axim X5 to the Internet using my mobile phone via infrared without a problem. You need to create a new dial-up connection using "Generic Infrared" modem in the setup. The number to be dialled is a function of your mobile phone. On my Nokia 6230i the "number" is *99# for creating a GPRS connection. Your mobile phone has to be correctly set up for Internet access and obviously you have to have a data plan.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Sendo X Handheld Logo
Top Sendo Computers & Internet Experts
David Payne
David Payne
Are you a Sendo Computer and Internet Expert? Answer questions, earn points and help others
