Question about Toshiba Satellite Satellite 5200 Series 15 SXGA LCD Display-LQ150F1LH16-P000353350 CD-ROM Drive
Blurred monitor image to black only..
A few days ago my monitor had been blurry so i tried pressing some spots around it to see i there was something loose. i got i fixrd eventually but just a while ago i pressed the spot again my monitor just went black but i can still hear the window's welcome sound and everything. i tried turning it off and on but still the same black monitor. mwah should i do??? help me pls
  • 56 Answers
There is an issue with the screen as you say that the sound is coming from the system.I would suggest to contact the manufacturer and get the screen replaced.
Posted on Dec 27, 2007
Camera image blurred Motorola V3 razor
I would take the tip of a chop stick or a closed pen, put it in a cloth. Preferably a lens cloth. get right into the tiny depression that the lens sits in. If its still blurry my guess would be that there is moisture in it. Short of taking the phone apart, let it sit in a warm dry place for a few days. when it dries there will still be minerals left behind from the water. Still might have to dismantle the phone. not really that daunting once you get going it get obvious have they are put together. Good luck.
Aug 02, 2010 | Motorola Mobility RAZR V3
Blurry spot on bottom left of picture
It sound like you have some dust particles or a smudge spot on the CCD screen (actually on the low-pass filter in front of image chip). To leave an image on CCD, the dusts must be closer to the image plane to be registered so it should be somewhere closer to the screen or right on it. Take a look at the screen with "CCD Clean" mode and blow out any dust. If the smudge is on the screen, I recomend trained tech should clean it. good luck. For further assistance by email, go to www.camerarepairjapan.com
Mar 26, 2009 | Nikon D40x Digital Camera
Syncmaster 2232gw led blinking.
Change the screen resolution. The video card or video display may not be compatible to the supported video setting of the monitor. Try changing the video resolution to a lower setting such as 1024x768 and bit depth to 32 bit.
Mar 15, 2009 | Computers & Internet
Dell E193FP Problem
Probably a failing power supply
Apr 17, 2017 | Dell E193FP 19" Flat Panel LCD Monitor
Problem with image stabilization?
hi there
It is a regular problem with cameras that have a lot of zoom; optical or digital. a very little shaking of hands can really blur the image.
Image stabilization actually supposed to help. But if you are Ok with it off, that's great.
i would recommend resting your elbow on something solid (like someone's shoulder or a wall or anything like that.
One more thing - try inhaling and holding your breath at the moment you press the shutter release.
The best solution would be to buy a Tripod; even better would be to buy one which has a remote wired control.
take care and enjoy blur free images..
Jun 28, 2008 | Kodak EasyShare Z612 Digital Camera
Blurred images at start on samsung monitor
This is CRT Base Problem Simply Replace it
Thank You
Mar 09, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Hi I just experienced the same problem.Could NOT figure out what went wrong.The LCD screen image was blurred and as a result the pics I took were blurry:(
My husband then took over and simply cleaned off the front lens and POOF! It is back to good!Hope this helps!
Dec 05, 2007 | Fuji Cameras
JVC camcorder with blurred images
It could be an issue with the dioptre adjustment: 1 Set the Power Switch to ?A? or ?M? while pressing down the Lock Button located on the switch. 2 Make sure the LCD monitor is closed and locked. Pull out the viewfinder fully and adjust it manually for best viewability. So slide the rubber eyecup toward you. 3 Turn the Dioptre Adjustment Control until the indications in the viewfinder are clearly focused. The control is a litttle knob on the sied of eye-piece. While looking through the viewfinder, turn the knob until it is focused. Hope this helps. NewMediaMan
Jun 25, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Blurry pics
If it is a moving image that is blurred- them up the shutter speed or the ISO settin. What about Flash Do you 'Pan' your shots?
Jun 21, 2007 | Canon PowerShot S2 IS Digital Camera
Blurring of images and text
mt, the 6 to 8 lines you were seeing were most likley the prelude to the end of the monitor. If the problem only occurs when the screen saver comes on then I could say the driver maybe being corrupted by a certain screensaver picture or program. When the monitor warms up to a certain temprature the electronics start to fail. You may want to turn off the monitor while your not right in front of it to cool it down and prolong its use.
Jan 27, 2007 | LaCie Electron 22" CRT Monitor
Toshiba Satellite Satellite 5200 Series 15 SXGA LCD Display-LQ150F1LH16-P000353350 CD-ROM Drive Logo
57 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
