Question about Texas Instruments TI-86 Calculator
I Cant get the Correct Answers!
I am trying to calculate standard deviations with this calculator -which means I need it to display an exact answer. I keep getting 1.007 when the answer should be 1.0068. I have tried changing the mode settings around and still I can't get it to come up with the right answers. I need to complete my lab experiment yesterday, can anyone help me??!!
  • Anonymous Mar 21, 2014
    will not give the correct answer
  • 4 Answers
If you're sure the answer isn't really 1.007, check to see if the calculator is in fixed mode. You can change it to scientific notation(that'll give you lots of digits past the decimal place, or I prefer engineering, which is scientific except all powers of ten are in multiples of three).
Posted on Oct 05, 2007
I need help with my calculator settings sharp el-535 every time when calculate statistics it give me error answers and.even when I set it to a stats mode it will show a frequency table
There is a really great website called www.mathsatsharp.co.za that is dedicated to answering questions and helping people who own the Sharp scientific calculator range.
For Stats - i assume you are using the 535 with the table. Simply type in each data value, press = after each. Press change.
Press alpha and the number of the function you would like (for example 4 gives the average). Be careful with your standard deviation for population (on 6) and sample (on 5). In school we use the population standard deviation formula and not the sample standard deviation.
Sep 02, 2017 | Sharp Office Equipment & Supplies
I have 50 data points for which i need to find standard deviation on a classpad 330 , is there any quicker way to calculate than minusing the mean from every data point?
Here is one technique I used on the TI84Plus.
Create two lists list1(50) and list2(50) of equal dimension (same length)
You will have to find how to do it on ClassPad.
Fill list2 with zeros
Fill list1 with your data.
Sort the list in ascending order (if it is not sorted)
Do standard deviation calculation on list1 (or calculate the average)
The mean of the data is in a special variable (xbar)
From the command line using the list syntax calculate abs(list1-xbar) and store results in list2, overwiting the zeros.
Perform standard deviation on the new list2. You will get the mean deviation from the mean in the variable xbar.
A simple request from you. Can you please not use MINUS as a verb? By doing so you are propagating incorrect usage. There is a short and correct way to express the operation: to add.
May 05, 2012 | Casio ClassPad 300 Calculator
2nd vars 2 (normalcdf( -999999,-.1923) Just trying to get area from z value -.0.1923 keep getting errors
The normalcdf function takes three arguments: the z value, the mean, and the standard deviation. In the "standard" case the mean is 0 and the standard deviation is 1. Thus, try calculating
normalcdf(-.1923, 0, 1) .
Jun 29, 2011 | Texas Instruments TI-84 Plus Silver...
How to i do std deviation and sample mean
Example: Enter the following x variables, and determine the sample and population standard deviations.
x = {1,2,3}
  • Press [DATA] and begin to enter the data as indicated into the L1, L2 or L3 lists. To input a data point, type the value and press [ENTER]. Press the down arrow key to move on to the next data point.
  • Press [2nd], [STAT], and then choose 1-VAR.
  • For the "DATA" option, choose the listname the data is stored in (L1, L2 or L3). For the "FRQ" option, choose "ONE" since this data does not include a frequency list.
  • Arrow down to "CALC" and press [ENTER].
    Answers should be as follows:
    3:Sx (Sample Standard Deviation) = 1
    4:sx (Population Standard Deviation) = 0.816497
  • Press [2nd] [MODE] to exit STAT mode.
Oct 20, 2010 | Texas Instruments TI30XS Scientific...
Calculate Variance on Casio FX-83ES Calculator
I am happy that you found my solution helpful and even flattered that you copied it in this thread. By doing this, you gave me the opportunity to discover an error in my post. In fact, the calculator does provide a column for the frequency. If you enter nothing in the frequency column, all data items will have their frequency set to 1, by default.
Back to the current subject: How to get the variance (the square of the standard deviation).
When you finish entering your data:
  1. Press the [AC] button to exit the data editor.
  2. Press [****][STAT].
  3. Press [5:Var] to open the statistical result selection screen.
  4. Press [3: xSigma_n] or [4:xSigma_n -1] depending on what you are interested in (population or sample) standard deviation.
  5. The screen echoes the symbol for the value selected (the value displayed on the bottom line may be 0 or an old value from a previous calculation: it is not the value you have just calculated).
  6. Press [=] to display the current value of the SD chosen.
  7. By doing this you are in fact storing it it answer memory.
  8. All you have to do now is to raise it to power 2 by pressing the [x^2] key ( the one above the [HYP] key).
  9. The calculator will display Ans^2.
  10. Press [=] to display the value of the variance.
If you are not interested in the value of the standard deviation, but just want the variance, follow the foregoing procedure until step #5.
While the symbol xSigma_n or xSigma_n-1 is still displayed with the blinking cursor to its right, press the [x^2] key above the [HYP] key. The screen displays say xSigma_n ^2. Press [=] to calculate the variance.
As my motto says, I am always happy to help, but happier still when people show true appreciation.
Hope it helps.
Dec 11, 2009 | Casio fx-300ES Calculator
How to do standard deviation calculations?
M=500 and S=100 in a normal distribution, what percentage of the subjects have scores between 400 and 600
Jun 03, 2009 | Casio Office Equipment & Supplies
Standard deviation
standard deviation
calculate mean of a data set:
1. Turn calc. on or press MODE SeTUP
2.Press 3 for STAT
3. Press 1 for VAR
4.Enter values for X column
5. WHen done entering press SHIFT 1
6.Press 5
7.Press 2 to calculate the mean
8.Press =
Oct 05, 2008 | Casio FX-115ES Scientific Calculator
Standard Deviation
Texas Instruments TI-86 Statistics How-To Information The following instructions should allow you to calculate the mean and standard deviation using a TI-86 calculator.
  1. Press STAT
  2. Select EDIT
  3. Enter data into a list: [2.32 ENTER 2.43 ENTER 2.39 ENTER, etc.] Continue until all data have been entered. (use arrows keys to go to the y value, if any)
  4. EXIT until you reach the main ("blank") screen. (If you try to calculate while you're in the data menu, it thinks you're still trying to enter data!)
  5. Press STAT
  6. Select CALC
  7. Select OneVa
  8. Select LIST, NAMES, xStat(F2), Press ENTER
  9. The calculator provides Max, Min, Mean, Standard Deviation, Sum, Sigma, etc. You will be primarily interested in the Mean and Standard Deviation (sx).
Nov 15, 2007 | Texas Instruments TI-86 Calculator
Standard Deviations
This calc will do standard deviations. In the manual it is on page 2 and also on page 40.
Sep 07, 2006 | Casio FX-7400G Plus Calculator
Texas Instruments TI-86 Calculator Logo
130 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
