Question about Dometic Rooftop RV Air Conditioner
Roof top air won't come on
I turned my roof top air on and it started to blow. I went into my house to let the unit cool the rv but when I returned the unit had stopped working. What should I do?
    Guru:
  • 587 Answers
Check the breaker for the AC
Posted on Apr 26, 2009
How can I tell if the compressor is coming on on my Coleman 13500 roof top A/C unit? It blows air but not cooling. Thanks
When the compressor starts you will hear the unmistakable noise associated with it...there is a definite hum from the compressor...check the t-stat on the unit... they often go bad..
heatman101
May 19, 2011 | Dometic Rooftop RV Air Conditioner
I have a Dometic Duo Therm rv Roof Air Conditioner Model# 59516.531.The fan is blowing and the compressor is kicking on but it is not blowing out cold air. Someone said it must be out of freon. Why would...
These are a closed system.(meaning that there is no fill valves for recharging) But a heating & cooling technician can solder them on and re-charge the system. Only problem there is to get an estimate up front, and compare it to buying a new roof unit which also comes with a new warranty, as well as keep in mind that the freon went somewhere, so there is an obvious leak that will need to be addressed as well. Most times it's wiser and cheaper in long run just to buy a new roof unit.
Are you sure that the compressor is kicking in? Did anyone remove cover on roof and check lines from compressor to see if any cooling is occurring?
These don't often leak, that's why I'm asking. Any idea how old the unit is?
Perhaps in fairly new, it's a warranty issue.
Jun 25, 2010 | Dometic Rooftop RV Air Conditioner
Have a Quick Cool RV roof unit compressor:
Try ( www.dometicusa.com) site and they have dealer locator on there site for wherever you are.
May 17, 2010 | Dometic Rooftop RV Air Conditioner
Have roof top air conditioner that blows air but soon trips breaker. any suggestions? Henry
check the condensor fan in the rooof unit. It's the fan blowing on the cpil on the roof.. If it failed, the head preasures can becme excessive andwork the compressor hard causing the breaker to trip. Let me know and good luck, Ned_
Sep 13, 2009 | Dometic Rooftop RV Air Conditioner
My roof top RV air conditioner is dripping water inside my RV
Check run-of on roof & see if it's been reduced lately, it may just be a plugged drain at base of unit on roof.
Jul 29, 2009 | Dometic Rooftop RV Air Conditioner
RV Roof Top A/C not cooling
Try turning the unit off for 24 hours and try again. It's possible that low voltage may be preventing the compressor from starting.
If no luck, the compressor should be checked to see if it's damaged. Also check any start/run capacitors and the controls in general.
Jul 25, 2009 | Dometic Rooftop RV Air Conditioner
Both roof top units on RV cool for awhile the go off
May be low voltage problem or bad connection this may cause controller to shut one or both down. Need to talk to RV dealer for assistance on this system.
Jun 28, 2009 | Dometic Rooftop RV Air Conditioner
If you are running the AC on an extension cord it can cause such voltage drop that a fuse or breaker can blow, in extreme conditions it can damage electrical connections. Always use extension cords that are as short as possible and replace the cord ends (especially the female end) whenever they lose clamping force. A heavy duty cord end takes much more effort to plug in the male end and to plug things into the female end. Over the counter extension cords for your purpose should be no less than 12/3 with heavy duty (20 amp) ends and no more than 50' long, if you must go farther you should use a 10/3 cord.
May 26, 2009 | Dometic Rooftop RV Air Conditioner
Seal for roof top ac unit
I just spoke with the mechanic at my RV dealership and he said the sticky side goes on the a/c unit. You only have to turn it on it's side to do this. Just wait 1 hour after re-installing the unit on your RV before turning it on.
Apr 17, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
316 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
