Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
17 hp briggs hard to start and blows back through the breather
I have a 17hp briggs on a 42 in cut JD riding mower that is 4-5 years old. hard to crank but will start. will not throttle up and very weak. makes a poping sound and is blowing back through the intake. gas filters and carbarator look to be ok. though it might be timming but the key in the fly wheel looks to be ok have not pulled the fly wheel off. any suggestion before i pull the flywheel.
  • 246 Answers
Hello rfrazierL
>>From your Description it Sounds like the Valves Require Adjusting.
>>The Following is a Basic File I made for Setting the Valve Clearances. Any Input is Appreciated.
>>**I Do Not Use the Setting Called for by the OEMs. I have Found that the Following Works Best.
>>Remove the Valve Cover (on the Dead Cylinder for Twin Cylinder Engines).
>>Check the Push Tubes and make Sure they are Not Bent.
>>Set the Cylinder you are Setting the Valves on to Top Dead Center on the Compression Stroke When Setting the Valve Clearance. Now Loosen the Valve Adjuster Lock and Using a Blade Style Feeler Gauge, Set the Intake Valve Clearance to .004in -.006in and the Exhaust to .006in - .008in. Loosen and Tighten the Rocker Arm and the Feeler Gauge is Placed Between the Rocker Arm and the Valve Top where the Rocker Arm Pushes on the Valve.
>>***BE SURE TO TIGHTEN THE ADJUSTER LOCK AFTER YOU HAVE THE PROPER VALVE CLEARANCE***
>>I have had Better Performance Out of the Mowers and Less Burnt Valves Using these Settings. Be Sure the Piston is at TDC on the Compression Stroke.**
>>If you Remove the Valve Cover and then Turn the Engine by Hand, you can Watch the Intake Valve Movement. When the Intake Valve Closes, the Piston will Just Starting the Compression/Power Stroke.
>>On Some Engines you can Us a Straightened Coat Hanger and Feel the Piston.
>>Be Careful and Don't Jam the Wire in the Cylinder. Usually the Piston will Push the Wire Out of the Spark Plug Hole with No Problems.
Respectfully
John
Posted on Apr 21, 2009
Briggs and Stratton 17 HP Riding Mower
Hi Lawrence.
There should be a few more numbers/ letters to your model number. I added a link to a website for you to check out. Click the link or copy and paste it. Hope this helps.
https://www.repairclinic.com/Shop-For-Parts/a22b303d782009/Model-42A7072653E1-Briggs-Stratton-Small-Engine-Parts
May 30, 2017 | Briggs & Stratton Garden
Looking to buy a yardworks riding mower 42" cut belt
take the old one to a mower repair shop and that will have all the details
if you don't have the belt go there anyway as they probably will have a catalogue
Aug 28, 2016 | Optics
17hp briggs and stratton blowing oil out of dipstick
looks the rings are stuck.when you have head off check piston. john.
Mar 10, 2014 | Briggs & Stratton Garden
I am trying to get a JD riding mower with a 17 HP Briggs to run that has been parked for a couple of years. Ive replaced gas & filter, cleaned carb and verified fuel pump is working. It will only run if...
You need to soak the carb in a good carb cleaner for a couple of hours then blow all passages out with compressed air, this should dislodge any junk.
Aug 20, 2013 | John Deere Garden
I GOT A SEARS CRAFTMAN riding lawnmower 17 hp 42 inch cut kohler engine.and when i start oil come out of my exhaust what causes that
Either over filled with oil, valve stem seals leaking, engine breather blocked, or the engine is badly worn.
Mar 13, 2012 | Garden
Craftsman 17hp 42" cut riding
Sounds like its not getting enough fuel. clean the fuel system and the carby. The valve clearances also need to be checked.
Apr 07, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 18.5 briggs/str 42''
flop the seat forward, push the connector firmly onto the seat switch [in the middle of the seat underside], should solve your problem, or the switch could be bad, but not likely unless you're 300lbs
Mar 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
1,178 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
