Question about Macromedia Flash MX
  • 293 Answers
Re: Create Flah Audio Player with...
Try here
Posted on Sep 21, 2007
0 characters
3 Points
1) File > New > Presentation > Create (new presentation with all default settings)
2) Panel at right: Slide Transition > Modify Transition > Sound = "apert" (fourth in the drop down list)
You should hear a short (~2s) sound at this point, as the effect is "previewed". If you don't hear it, try the "Play" button at the bottom of the Slide Transition panel. If that doesn't work, then OOo is not able to play sounds and you have to fix that before proceeding.
3) Slide Transition > Modify Transition > Sound = "Other sound" > (select your long music file).
You may or may not hear the preview for this, it depends on whether your music file has a quiet leader at the beginning. If the audio starts right away, you should hear it. If the audio starts after 1-2s of silence, you won't hear anything.
4) Click "Slide show" (bottom of the Slide Transition panel) or F5.
You should hear the music start. It will continue to play even after you advance to the next slide (which is the black "End of show" screen. Advance again to end the show and the music should stop.
Jul 29, 2015 | Graphics Publishing, Design & Multimedia...
How do you add the music to the slide show?
Dear annettesamto
First do the photos. When you have finished that, click on the "Next" button at the bottom of the window. Now look for your music files by clicking on the "Select Audio Files" button in the "Soundtrack" section. For example, go to "My Documents" and then select the "My Music" folder and click on "Open". Select the music file you want and once again click on "Open". The track you have chosen should now appear in the white area in the "Soundtrack" section. Repeat this to choose more music tracks until you are satisfied with your selection. To delete any tracks from the list, select it in the "Soundtrack" section and then click on the little dustbin to the right and just above the white area where the names of the music tracks are.
Hint: Try to get the combined length of all your music tracks ("Total audio time") close to the "Duration of Slide Show". Then decide how long (in seconds) you want every photo to be displayed before the slide show moves on to the next photo. All your photos will be displayed for the same amount of seconds. In the "Duration" section, at "Set Duration", type in the amount of seconds you would roughly want your photos to be displayed for (for example 8 seconds). If the "Duration of Slide Show" and "Total audio time" is the same or very close, you can ignore the part where it says "Auto-Fit to Soundtrack". However, if the difference is several seconds or more, click on "Auto-Fit to Soundtrack". This will ensure that your slide show (photos) ends when the music ends. It means that your photos may now be displayed for slightly less or more seconds than the amount you indicated, but at least the soundtrack and the photos will end together.
When you are satisfied with your soundtrack, click on "Finish" at the bottom of the window. If the computer asks you if you want to replace an existing file, click on "Yes". The soundtrack window dissapears. Now click on "File" at the top left of the window and choose "Save Project".
You can listen to your soundtrack by clicking on tab 3 ("Produce") and then on the "Enter" button on the remote control.
You should be aware that some music files may not work with SlideShow Expressions, particularly some files that have been downloaded from the internet, for example through iTunes. This has to do with copy-protection and causes some tracks not to play properly. As a rule, though, mp3 files should work fine, as well as tracks ripped from CDs, like wma files. The User Guide gives a list of all the supported music files. The User Guide is on the install disc. To find it, insert your install disc and click on the relevant link that appears, or you can go to "My Computer", right-click on the CD/DVD drive and click on "Explore" to look for it on the install disc; it is a pdf file.
I hope this was helpful. The best of luck to you.
Hendrik Uys
Oct 07, 2012 | Individual SlideShow Expressions
I cannon figure out how to add music from my computer to the slide show....please help me....I have 5 songs on my desktop and I cannot seem to figure out how to get them to slideshow...
Best jbannon257
There could be a number of reasons why you're having trouble adding music files to your slide shows. First I'll lay out the procedure and afterwards I'll give some hints / a link to where problems with audio files are discussed.
The procedure (adding music files using SlideShow Expressions):
The programme opens and you are automatically in tab 1: "Add Media".
Click on "Create New Slide Show". Click on "Add Photos"; tell the programme where the photos are, select them, insert them, change their positions if necessary.
1. Click on "Next" at the bottom of the screen.
2. At "Soundtrack", click "Select Audio Files", then tell the programme where the music files are located on your computer, click to highlight a specific music file, click on "Open". The music file you selected now appears in the Soundtrack window. Repeat this until all the music files you want appear in the Soundtrack window. (You can delete any of them by clicking to highlight any specific file and then click on the little rubbish can icon.) As you go along, the total audio time for the slide show / chapter is displayed as well as the "Duration of Slide Show".
3. In the "Duration" section, you have the option to set the length of time you want per slide (seconds) - usually 8 to 10 seconds is best. (All your slides will follow this instruction; you can't set the duration of individual slides to a different time.) At "Auto-Fit to Soundtrack", you alter the duration of the slides to fit the length of the soundtrack. (This cancels out the previous seconds-per slide setting.) You must therefore choose music tracks that, when added together, will approximately span the whole length of the slide show and then you can fine-tune this by clicking the "Auto-Fit to Soundtrack" option.
4. When you are satisfied with your choice of music tracks and the length of your slide show, click on "Finish".
Issues with music files when using SlideShow Expressions
According to the User Guide (section 3-3) - included on the install disc as a pdf file - the supported audio formats are: mp3, wma, wav, ra. Make sure that your computer also meets all of the requirements (on the box).
Photo & Video Expressions is not compatible with audio files that have been protected by Digital Rights Management (DRM) functionality. Most audio files purchased online through Internet music retailers like iTunes, Urge, or Rhapsody are encrypted with some form of DRM. Similarly, audio files that have been extracted from a CD or DVD (the process known as "ripping") using certain media applications (iTunes, Windows Media Player, etc.) often have default settings that encrypt the files extracted.
There is no way to used DRM audio files purchased from online music retailers with Photo & Video Expressions. However, if you want to used music and audio files that you have extracted from your CD collection, then all you have to do is change the ripping setting in your media application before you extract the files to your computer.
Go to the following site to read about how to change your ripping settings:
Type your question OR (below):
"Photo & Video Creativity": choose "SlideShow Expressions" from drop-down menu, click "Go".
A window appears with options on problems, e.g. "Why aren't my audio files showing?"; "Why won't my music files work?" Click to read.
The best of luck to you. From: 11407336.
PS. Try
May 30, 2011 | Individual SlideShow Expressions
Creating youtube video in flash for only play and pausethe video
try downloading and installin flash player 8 or update ur graphic accelerator.......thn q...
Sep 12, 2009 | Macromedia Graphics Publishing, Design &...
Lost audio during edit videoStudeo 10 plus
audio track in ulead video studio 10 plus -attribute volume is set to zero and grayed so i cant activate it.checking it. checking duplicate audio track activates audio by track but mutes again when i play the project-used to work.system dell XPS M1730
May 21, 2009 | Ulead VideoStudio 9
Burning DVD from Windows movie maker and audio is funky!
after copleting save it in u r system as .dat format.
then use nero n select make video dvd
ur's kishore
for more help catch me on +919985064600
Feb 10, 2009 | Roxio Easy CD & DVD Burning
Are there any iTunes controllers?
Hi simply just uses iTunesKeys which is designed to control iTunes and will allow you to configure it to allow your media keys on your keyboard just fine. For more go to:
Jan 23, 2009 | Apple iTunes
Multi track recording
I suggest that you should pause recording every after since it will overwrite the previous songs.that's it!!
Feb 05, 2008 | Magix ENTERTAINMENT Music Studio 10 deLuxe...
Flv player
hi rananjay is here. try this script....
// flv player..
// developer.. Rananjay Singh
// video instance name = thevideo
var nc:NetConnection = new NetConnection();
var ns:NetStream = new NetStream(nc);
//made control on new layer button name = Rewind button,play button
rewindbutton.onRelease = function() {;
playbutton.onRelease = function() {
// made new symbol named loader with strock
// inside this select the fill color & make new mc named loadbar
var videoInterval = setInterval(videstatus, 100);
var amountloaded:Number;
function videostatus() {
 amountloaded = ns.bytesLoaded/ns.bytesTotal;
 loader.loadbar._width = amountloaded*217.9;
 // 217.9___ width of loadbar
// flv setting-- framerate = 1.1,,, frame every 30
// make anew mc for seekbar named scrub
// then it place on loadbar
var duration:Number;
ns["onMetaFata"] = function (obj) {
 duration = obj.duration;
 loader.scrub._x = ns.time/duration*208.9;
 //208.9 width of loadbar
// scrubbar firs see what area cover loadbar 0 to x
var scrubInterval;
loader.scrub.onPress = function() {
 scrubInterval = setInterval(scrubit, 10);
 this.startDrag(false, 0, this._y, 208, this._y);
loader.scrub.onRelease = function() {
function scrubit() {*duration));
//buffering---- made a videosize blackmc & inside that give text alpha animation,, named buffer
ns.onStatus = function(info) {
 //if(info.code ==)..... see netstream class in help & compleate it
// custom ontextmenu..
var themenu:ContextMenu = new ContextMenu();
themenu.hideBuiltInItems(); = themenu;
var i1:ContextMenuItem = new ContextMenuItem("video controls", trace);
var i2:ContextMenuItem = new ContextMenuItem("play/pause video", pauseit);
var i3:ContextMenuItem = new ContextMenuItem("replay video", replayit);
var i4:ContextMenuItem = new ContextMenuItem("copy right", trace);
themenu.customItems[0] = i1;
themenu.customItems[1] = i2;
themenu.customItems[2] = i3;
themenu.customItems[3] = i4;
// after that create two functions for context menu
function pauseit() {
function replayit() {;
// and now prepratin foe volume control
//make a four stage movi clip for sound .. named normal,onover,mute , muteover
_root.createEmptyMovieClip("vsound", _root.getNextHighestDepth());
var so:Sound = new Sound(vsound);
// button name = mute
mute.onRollOver = function() {
 if (so.getVolume() == 100) {
 } else {
mute.onRollOut = function() {
 } else {
mute.onRelease = function() {
 } else {
Oct 29, 2007 | Macromedia Flash MX
Flash audio player in a website with multiple audio in Library
Take a look at these sites: and a free one at...
Sep 20, 2007 | Macromedia Flash MX
Macromedia Flash MX Logo
130 people viewed this question
Top Macromedia Graphics Publishing, Design & Multimedia Software Experts
Sunny Solanki
Sunny Solanki
Are you a Macromedia Graphics Publishing, Design and Multimedia Software Expert? Answer questions, earn points and help others
