We are on our yacht in the British Virgin Islands. We have a Miele 945 S WPS Washer/drier. I need instructions to remove the front panel please? I think the problem may be the rubber vacuum tube has failed??
  • alphacrucis Apr 20, 2009
    Hi Taran
    Thanks a million. Opened the Miele quite easily and without damage. Your instructions were very clear. Only slight difference was the top left side screws were 3 Star Heads, not 1 philips, on this model but that was no problem.
    Was able to fix the machine and it is now working much to the delight of my wife and myself.
    Many thanks from two Kiwis sailing the world.
    Terry Rogers
  • 10,515 Answers
Hi Alphacrucis,
If you follow the procedure below (less removing the seal), then you'll get the front panel open).
All Miele front loaders are similar in this respect), in particular the W700, W800 and W900 series. The procedure is as follows:
1. Open the machine door.
2. Turn the mains power off and unplug the machine from the wall.
3. Completely remove the powder dispenser drawer (it will come out so far (and stop), then there is a small button at the rear of the dispenser which you need to depress to remove it fully, you'll see this button once you've withdrawn the drawer to its stop position.
5. Undo and remove the 3 x hexagonal head bolts surrounding the door seal (they are at approximately the 2, 6 and 10 o'clock positions). Note these bolts actually secure the front panel to the machine chassis, they do not retain the door seal. Don't worry the front will not drop off.
6. Now look at the aperture of the powder dispenser drawer (you have of course removed the actual drawer earlier). Locate the lower left hand corner of the aperture, and you'll see a recessed philips head screw in a hole. Undo and remove that screw.
7. Now, you'll need to get on your hands and knees. You DO NOT need to tilt, or lift up the washing machine to do the next bit. Locate the underside of the front panel right at the bottom. You'll notice that it sticks out about half an inch or so and is proud of what I would call the kick plate which extends right down to the floor. You need to look on the underside of the front panel, about an inch or so in from the left hand edge. There you will see a spring loaded clip which when closed is located within a slot on the underside of the front panel. Using a flat bladed screwdriver, you need to carefully lever the spring clip open whilst gently pulling the whole front panel (from the left side) ajar. It will just suddenly pop out once you've done it.
8. Open the pump access door lower left hand side of the front panel) and unclip the drain tube from its plastic retaining clip.
9. Now carefully swing open the whole front panel, it opens like a door (hinged on the right hand side). It might be a little stiff as there are a whost of leads attached to it, but it is designed to open fully (with the leads attached) to about 90 degrees.
10. Next, unseat the rubber door seal from around the door opening area (on the chassis, not the front panel, obvioulsy), so that the seal the flops away from the chassis and lies just inside the machine.
11. You will notice that there is a thin steel band holding the door seal in place around the drum. On the right hand side (at about the 3 o'clock position), you'ss see a tensioning screw for the band. With a flat bladed screwdriver undo this completely and remove the screw (it is accessible from above with a long screwdriver). Be aware that there is 1 x washer and 1 x 'nut' type fitting that will fall out when you remove the screw. Locate these and retain them for later.
12. Now extend the steel band to its maximum opening (by moving the 2 x lugs apart where the now removed screw was).
13. You can now remove the steel band. Then pull it out through the hole/door aperture in the chassis.
14. Locate the small rubber tag at about the 12 o'clock position where the seal is attached to the drum and tug it. The seal will then come away from the drum. Remove the old seal completely.
15. Using your new seal, place this correctly around the drum (there is a lip on the seal and this has to go over the lip on the drum. Remember, the seal goes on the OUTSIDE of the drum. Ensure the 'tag' is at the 12 o'clock position.
16. Reassembly is then the reverse of removal.
17. Make sure that you do up the retaining steel band sufficiently and that you correctly locate the sela on the chassis front panel (there is a groove in the seal which will locate the seal in the aperture).
18. Finally, once you're done, put the machine through a few rinse cycles (where the water level is high) and look for leaks. If you have a leak, it is likely that your door seal has a rip/tear, or that it has not been correctly located around the drum - in which case you'll need to investigate.
All procedures carried out at your own risk of course. If you do not feel that you are competent - get a professional engineer to carry this out.
Hope that helps.
Taran
Do rate the solution as "Fixya' if 100% satisfied.
Posted on Apr 20, 2009
Miele WT945 drier removal
Hi dear.
It is very complicated work. I can suggest you should not involve doing that but if you know what you are doing try that out. See if it helps.
Common problem: Stuck drying air fan shaft.
1- Unplug machine from power. Remove top cover.
2- RHS at the back,on outer drum horizontally mounted motor,drives a belt.
3- Try to rotate motor shaft (impeller) by hand, see if it's hard to rotate. Try to make it free to rotate.
3- If you have a capacitance meter, check value of capacitor should be in range of 2.5 uF if not replace capacitor.
Beyond that you need to get tech. to assist your machine. I hope that helps so far. Thanks.
Feb 25, 2016 | Miele WT945 Front Load Washer / Dryer
Why is my Miele WT945 front lader washer dryer not taking water in properly or at all?
you may try cleaning the inlet screen by removing the fill hose.then pry the ccreen out with a small screwdriver.
May 05, 2014 | Miele WT945 Front Load Washer / Dryer
Main internal fuse location for Miele WT 945
Hi Dear.
As I know,your machine does not have replaceable fuse in it. Thanks.
Jan 04, 2012 | Miele WT945 Front Load Washer / Dryer
Miele novotronic wt 945 door release button not responding wash functions not responding when turned on and off only drier light is on no actual response from drier section cannot open the machine Is this...
Open the door manually.
Open the drain flap on front left bottom
The door release can be seen hanging, pull the cord, the door will open.
Close and open the door 2 or 3 times and your machine will work ok.
S. Datta
Bickley
Mar 06, 2011 | Miele WT945 Front Load Washer / Dryer
Miele novotronic wt 945 door release button not responding wash functions not responding when turned on and off only drier light is on no actual response from drier section cannot open the machine Is...
Sorry but I would strongly suggest that sending any part to Miele and paying Miele for fixing the fault would cost considerably more that a 'local' service engineer ;-0(
Also Miele would not necessarily accept someone sending parts or all of a washer to it.
'Local' Service engineers are available for exactly the purpose of avoiding customers having to send suspected faulty equipment back to the factory. Also factories are not normally set up for carrying out retail repairs.
So, sorry again. Call your local repair man who should have the equipment to diagnose and cure the fault ;-0)
Good luck,
John C
Mar 06, 2011 | Washing Machines
Can't locate plus character to put in front of an overseas contact number on my panasonic KX-TG2511ALdigital cordless phone
The "+" is merely a placeholder for the international call prefix (IDD) used in your country.
  • For example, if you live in France (IDD: 00) and need to call a phone located in Germany (Country code: 49), you would call 00 49 ...
  • If you live in USA (IDD: 011) and need to call a phone in Germany (Country code: 49), you would call: 011 49 ...
Find your country of residence in the list below and use its IDD as a replacement for the "+":
  • 00 - all countries not listed below, ITU recommended code.
  • 0 - Samoa
  • 00 ~ - Hungary
  • 000 - Tanzania, Uganda
  • 000, 005, 006, 007 - Kenya
  • 005, 007, 009 - Colombia
  • 001, 007 - Cambodia
  • 001, 007, 008, 009 - Indonesia
  • 001, 008 - Singapore
  • 001, 0060, 007, 008, 009, 1666 - Hong Kong
  • 002, 005, 005, 007, 009 - Taiwan
  • 001 - Guyana, Mongolia, South Korea, Thailand
  • 0011 - Australia
  • 009 - Nigeria
  • 010 - Japan
  • 012, 013, 014, 018 - Israel
  • 011 - American Samoa, Anguilla, Antigua and Barbuda, Bahamas, Barbados, British Virgin Islands, Canada, Cayman Islands, Dominica, Dominican Republic, Grenada, Guam, Haiti, Jamaica, Marshall Islands, Micronesia, Montserrat, Northern Mariana Islands, Palau, Puerto Rico, Saint Kitts and Nevis, Saint Lucia, Saint Vincent and Grenadines, Trinidad and Tobago, Turks and Caicos Islands, USA, Virgin Islands
  • 1xx0 - Chile, xx depends on international carrier code
  • 119 - Cuba
  • 810 - Belarus, Kasakhstan, Tajikistan, Turkmenistan, Uzbekistan
  • 807, 810, 811, 816, 818, 854, 860, 869 - Georgia
  • 810, 826, 827, 828, 856, 857, 858, 859 - Russia
  • 00, 99 - Finland
Jan 17, 2011 | Panasonic KX-T7730 Corded Phone
I would like to get some information on how to replace the door seal of a Miele Metor 4000?
Depends if washer drier or just washer...The Door boot seal is secured with two rings one on the outside of machine case the other on the inside...The tricky part is fitting the inner ring in some cases the front of the machine can be removed,greatly simplifing the job if you look on utube you will see step to step how to fit a door boot seal this may help you decide if you need an engineer to do job..Happy New year from Scotland...
Jan 01, 2011 | Miele W 4800 Front Load Washer
Miele washer-dryer
you have activated the float switch in the base of the unit due to a water leak. this could be just excess detergent or an actual leak. if you tip the unit forward with some towels in front this will drain out the water. try running again with no detergent. if it doesn't show WPS after a couple of washes then you are ok. then change your detergent.
May 31, 2008 | Miele Novotronic Premier 500 Front Load...
Help
hello i know what your problem is phone me on 07764303923
canon trained engineer
advise is free
Feb 13, 2008 | Canon CLC 1150 Color Copier
Washing Machines Logo
67 people viewed this question
Top Washing Machines Experts
