GE GSL22JFPBS Side by Side Refrigerator
Problem for GE GSL22JFPBS Side by Side Refrigerator
GE PSC23NSD SS refrigerator malfunction
By jleblanc10 on Apr 20, 2009
Overnight with no prior warning, ref side very warm,(room temp or higher), like heat being added to compartment. Freezer side okay. actually too low, minus 7 or so. Moved unit away from wall and seems to be working now but suspect problem not cured. Cleaned condensor best I could in rear of unit. Circular condensor unit. Compressor running normal and condensor seems running okay. Would like to try to replace defrost thermostat on evap coils, or inspect coils for frost. How do I access through freezer? Any other ideas or directions? Thanks much.. Joe in NewOrleans..
Best Solution
posted on Apr 20, 2009
Helpful)
CongressmanT
Rank: Guide
Rating: 94%, 4 votes
Check the cover in back of the freezer for for frost build-up. I think Frost reached the evap fan-blades and stopped it from blowing cold to the ref-side. Contro;s can be confusing. The ON-OFF controls how long the compressor runs, and the other dial how open or choked the airflow from the freezer into the refrigerator. Sometimes it happens that you have that flapper shut and no air is getting moved to the reefer. If frost is on the cover you have dead heater elements on the evap coils or a faulty hi-temp limit switch, which is the disc thingee at the top of the coils. A bad timer also may disallow it going into defrost - think about it. Chris in big bEar
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for GE GSL22JFPBS Side by Side
Questions and Unsolved Problems for GE GSL22JFPBS Side by Side
Do you recommend GE GSL22JFPBS Side by Side Refrigerator?
Answer
Answer
My kitchenaid (kscs25stss01) icemaker is no longer working after turning icemaker off. Icemaker has... (More)
Answer
Can you pull up my records of all the conversations regarding my reported problem ?
Answer
GE side by side model gsl22wgpebs not cooling properly.
Answer
The ice maker works fine. But the door ice dispenser will only dispense crushed ice. It will not... (More)
Answer
The freezer is getting cold but the fridge side isnt
Describe your Refrigerators problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
