Question about Maytag Atlantis MDE7400AY Electric Dryer
I HAVE A OLD MAYTAG DRYER 25+YRS AND I CANT GET THE TOP TO POP OFF. ANY SUGESTION ON HOW TO GET IT APART?
  • 1,543 Answers
If it is that old, look at the bottom of the front panel, about three inches off the floor for a phillips head screw on each side. Remove the screws, swing the front panel up a bit and unhook it from top and set to the side. Now, you can remove the screws holding the top onto the side panels and swing the top back.
Posted on Apr 20, 2009
Maytag bravos gas dryer exhaust belt came off
Probably because the exhaust ducting is clogged. A common problem on these.
Pop the top just like the old models and remove the front then the shroud and then clean her up.
Nov 06, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
3 yrs old stopped in the middle of a cycle .
need to change thermal fuse,when dryer gets filled with lint they pop,it is a safety device that pops when dryer over heats
Nov 03, 2009 | Maytag Dryers
How do i open the dryer to replace the belt?
use a putty knife slide it between the top and dorr panal
on each side you will feel a stop thats the "dog"
push it back with the putty knife
when both have been popped, the top will pop open
onecs inside you will see two 5/16 bolts holding the front on
2 things, remember how the tumbler sits on the back of the door, for reinstall
unplug before you open
once open it should be fairly easy
Oct 15, 2009 | Maytag PYE4558A Electric Dryer
The on line instruction for replacing Maytag dryer belts say " insert a flat screw driver under the top panel and it will come off. Problem is: on my older model, there are two large metal screws...
My 1955 edition of the Maytag top popped off because it used the spring clamps you refer to. If there are screws there, you will have to remove them. Once the top is up, you will see how to remove the front. If you can get this far, the rest of the job will become self evident (I think) .If you need more help, let me know
a
Sep 30, 2009 | Maytag Performa PAV2200
I have a maytag dryer(the lesser quality one) about 5 yrs old. stopped mid cycle. now i get nothing.dead as a doornail.I tried different positions of settings to see if it might be timer...nothing.....
Thermal fuse LA-1053 runs $25,pop the top using a putty knife,two spring clips in front about 4 inches in from the side,tstat sits on the heater duct behind the drum...
Sep 20, 2009 | Maytag PYE4557A Dryer
Pop the top off the dryer
Check the door switch. To remove the top there are 2 spring clips or screws located inside door opening going up into the lid. Remove and you will be able to see in side nd check the door switch
Sep 20, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
How do you get them apart. I have an old Maytag washer/dryer combo around 15 years old. I am trying to get them apart to remove them from and old house without hurting someone.
I have the perfect website for you problem "appliancepartspros.com" You enter your model number and woola......the have complete breakdowns in picture form as well as "how too" instructons and all the parts needed. They also have a blog you join and ask questions where an expert in appliance repair responds with and answer. The prices for parts cant be beat. You will find all your anweres on the wesbite, and with the picture breakdown you will probably be able to figure out how it comes apart by yourslfe. but again, the have all the intructions on "how to" available for you.
Jul 22, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag electic dryer noise
First, pop up the top of the dryer -- use a large slotted screwdriver under each corner of the top. There will be screws holding the front of the dryer -- take these out and take the front off. The squealing is coming from roller bushings which need lubricating. Apply machine oil to all the axles/bushings -- this most likely will stop the squealing -- and don't forget to unplug it first.
Apr 23, 2009 | Maytag Dryers
Kenmore elite front loading wash & dryer-5 yrs old: should i buy?
all kenmore named washer will have 110 as first 3 digits of model #..the he washers are usually good washers..like all front loads they have their quirks ..if you read reviews from other consumers they indicate problems ..most of which are easily remedied by reading owners manuals..mold /mildew usually a bleach clean every few months ..vibration need real solid floor..oversuds use HE detergents only..just a matter of changing mind set from top loads with 25 gals of water each fill to a front load with 5-6 gals each fill..top load with 750-850 rpm spin speed to front load 1000-1200 rpm ..if willing to learn proper use and what to expect they can best investment..just don't let opinions of those unwilling to adapt affect your decision
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Loud squealing noise
on the maytag you need a putty knife use the knife and slide it across the top slit on the front you will fell it stop pull the knife out and push in on on that spot do the same thing on the other side and wala the top will swing up
Jan 08, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
60 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
