Question about Rolex Explorer II 16570 Wrist Watch
I have rolex datejust that looses time, i do not wear it to bed.
  • Anonymous Mar 31, 2014
    didnt wear it for awhile now not working after wearing it all day
    Problem Solver:
  • 7 Answers
Hi Sggann. You shouldn't need to wear a Rolex automatic watch all the time for it to be kept wound, and you can in any event manually wind it 30 times to top-up the mainspring. You don't say how long you've had the watch, or when or if you've serviced it, but it sounds like it might need a clean and service; this replaces the oils which can thin out over time and effect the timekeeping of the watch, and the watch will be tested to ensure it runs well. Get Rolex to do it, unless you know a capable and accredited watchmaker - it's not cheap (around £250), but then again the watches cost a lot! All the best; Eagle58
Posted on Jul 05, 2009
I usually shake my Rolex (Datejust Oyster Perpetual) because it slides to one side, but when I shake it, the second hand sometimes stops. Once I shake it again, it begins to tick again. I have tried...
What's the question? From you description of the troubles you are having I suspect that your watch may on the outside look like a Rolex, but it certainly does not behave like one. I have never had such erratic behavior even with my much cheaper, but authentic Casios.
Sep 26, 2013 | Rolex Watches
Watch keeps running but cant move hands to set time on rolex datejust
Debbie is the watch definitely genuine?
It is a common fault on fake Datejust's..is the crown completely out?
Mar 29, 2013 | Rolex Datejust SS
Fast running how to adjust to normal movement
Rolex is mechanical timing, not really accurate. Phone watch is timed by quartz crystal and may even be corrected by atomic clock on the internet.
Feb 07, 2012 | Rolex Datejust SS
How to set rolex datejust turn-o-graph 116263 time
Unscrew the crown, pull it out and set the time by turning it. After setting the time push crown back in and screw it back on flush with case. Rate me, plz.
Mar 15, 2010 | Rolex Datejust SS
How do you open the latch on a Rolex datejust watch
If I understand right, by the latch you mean bracelet clasp. You just pull it by the crown. Clasps on ROLEX watches can be very tight, so, have to pull it with appropriate force. Rate me, plz.
Feb 08, 2010 | Rolex Datejust SS
How do i remove the bezel to my rolex datejust
RECOMENDATION:
Contact a local official Rolex dealer to address the problem.
GOTO:
http://www.rolex.com
To find a local dealer.
Hope this tip helps.
R/
David
Oct 24, 2009 | Rolex Datejust SS
Does anyone have a manual for a datejust rolex
No, there isn;t any downloadable manuals for Rolex watches, but operation of Rolex Datejust is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in date setting position,
3) when you pull the crown further out to the second click, it is in time setting position.
To find the daytime or night time on the watch: pull out crown to the second click and advance watch hands forward till you pass the 12 mark on dial. If the date changes as you pass it - it is the night time (midnight). If the date do not change as you pass it - it is the daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
Feb 03, 2009 | Rolex Datejust SS
Rolex oyster perpetual datejust time/date setting instructions
Depending on how old the watch is, It may be quick set or older models are not quick set. In older models you need to unscrew the crown, pull out the crown and rotate the crown to set the time, and in order to set the date rotate the hour hand past 12 twice in order for the date to change. Set the date first and then set the hour and min. For quick set models unscrew the crown and pull it out to the fist click this position you can "quickly" set the date by rotating the crown. Set the date and then pull out the crown to the second position out. Rotate the crown to set the hour and min. Then push the crown back in and screw it down.
Dec 12, 2008 | Rolex Datejust SS
Rolex datejust
What you have is an older model Datejust -- or at least an older model movement. During the 1950s, many Rolex Datejust models had an alternating red/black date wheel. Tudor (Rolex's second brand) also had movements with the same red/black date wheel.
BTW, those watches are becoming more and more collectible. Sounds like you may have a nice classic on your wrist! :-)
I hope this helps!
Regards,
CharlieJ
[Please rate this solution, if it helps you.]
May 19, 2008 | Rolex Datejust SS
Rolex Explorer II 16570 Wrist Watch Logo
201 people viewed this question
Top Rolex Watches Experts
Dudeman321
Are you a Rolex Watch Expert? Answer questions, earn points and help others
